This is a sticky topic.
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #561
    Originally posted by SIDMX
    +1
    I've never seen Teapos with that Jamicon-like vent and i'm not aware of TEAPO being inconsistent with the vent marks in their caps so they do look fakes to me.
    I have seen that before:
    https://www.badcaps.net/forum/attach...4&d=1287520598
    https://www.badcaps.net/forum/attach...5&d=1287520598
    https://www.badcaps.net/forum/attach...6&d=1287520598
    https://www.badcaps.net/forum/attach...7&d=1287520598
    • SIDMX
      • Nov 2010
      • 165
      • Mexico
      #562
      Oh, i see now, you are right.
      And those pics remember me that i do have seen blue Teapos with those vents before in a very old compaq PSU.
      Still this is my first time seeing the green ones with those vents.
      Teapo used to use those vents on those dates? ...Or that was just a rare event ?
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #563
        Maybe it is related with the merge with G-Luxon. G-Luxon use those vents.
        • Behemot
          • 4845
          • CZ
          #564
          Yeah Teapo and CapXon bought half of the world's crappy brands. Thats the only reason there is less of them than used to be:-D
          • ncovert
            • Feb 2011
            • 291
            Got some more units to show:
            Pic 1: VERY OLD Lead Year Enterprise TG-200X 200W ATX power supply
            Has a bridge rectifier and input filtering, unknown cap brands. It's so old, the 92mm fan blows into the PC case instead of the power supply.
            Pic 2: Achieve AX250 250W ATX power supply
            Has 4 diodes, one filter coil, "VIVA" caps everywhere. I'm guessing it's an L&C.
            Pic 3: Thermaltake Purepower ISO-400 300W ATX12V power supply
            Has a bridge rectifier and input filtering, JunFu caps everywhere. It's probably one of the best built Channel Well's I've ever seen.
            What do you think?
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #566
              The first one is definitely overbulit for 200W. I am impressed.
              • ncovert
                • Feb 2011
                • 291
                Interesting. Do you think it could do a little more then that?
                • ncovert
                  • Feb 2011
                  • 291
                  Got another unit in...
                  It's a Dell/Hipro HP-P1457F3 145W power supply from 1999. Yes, it has the goofy non-standard Dell pinout on the ATX connector. Caps are all Teapo.
                  • ncovert
                    • Feb 2011
                    • 291
                    DVE Electronic DSP-1454P 200W AT power supply
                    Has 4 diodes , but input filtering. Matsushita primary caps, and a mix of Jamicon and CapXon on the secondary.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #570
                      The transformer seems capable of doing 350W+. The input caps are big enough. If they are 680uF the can do 350W.
                      The total power depends on the switching transistors, the secondary rectifiers and the output caps.
                      • ncovert
                        • Feb 2011
                        • 291
                        Primaries are 470uF, so what do you think it can do?
                        Also, how do you tell what a PSU can do by the primary caps?
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #572
                          2x:
                          220uF ~ 100-200W
                          330uF ~ 200-240W
                          470uF ~ 240-275W
                          560uF ~ 275-300W
                          680uF ~ 300-370W
                          820uF ~ 370-430W
                          1000uF ~ 430-500W+
                          depending on the design
                          Those values are without Active PFC.
                          • ncovert
                            • Feb 2011
                            • 291
                            2x:
                            220uF ~ 100-200W
                            330uF ~ 200-240W
                            470uF ~ 240-275W
                            560uF ~ 275-300W
                            680uF ~ 300-370W
                            820uF ~ 370-430W
                            1000uF ~ 430-500W+
                            Thank you. Is there any way to swap out caps or would that kil it?
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #574
                              I replace primary caps with bigger ones all the time without any problem
                              • ncovert
                                • Feb 2011
                                • 291
                                So you think I could swap out the 470uf's with 680uf's?
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #576
                                  That psu has a label of 200W. Before changing the primary caps you should make sure how many watts the psu is capable of doing. To do that you need to check its switching transistors, secondary silicon and output capacitors.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #577
                                    Yes.
                                    A working TV? How boring!
                                      The rule of ~1uF/watt works well - divide by two to get uF because the caps are in series.
                                      • pdavid
                                        • Jan 2011
                                        • 279
                                        • Hungary
                                        #579
                                        A friend brought me a Chieftec Cft-750-14c. He got it in 2007 and it wasn't opened ever since. This psu was literally stuffed with dust. The fan couldn't move and the unit was shutting off. It was easy to clean it with air compressor and a brush. Suprisingly caps look ok. Hitachi primary and Samxon secondary. Take a look at the soldering... this is how it came out from Channel Well...
                                        I haven't touched it up since my friend was already in shock that I opened the unit up He took it back so it's going to work like this.
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          CWT aren't exactly known for good soldering. I probably would have checked the screws for the heat sinks. CWT often don't do them up tight enough and don't use any thread lock on them.
