	This is a sticky topic.
Yeah those switchers are only 10A, so 350W would be pushing it. The Jun Fu primaries are 470uF, and they read 474uF and 476uF. I think I'm going to recap it, I'll throw in some lame 560uF Teapo I have, and replace the minimum load resistor on the 3.3V with the 215Ω resistor and leave the 12V with no dummy resistor.Comment
Sunus Suntek 350ATXE-HP
Sunus Suntek hiding a Hipro inside
 This one looks similar to some of the recent Hipro's posted but it's definitely different. First of all, it has a rocker switch. Never personally seen one on a Hipro before. It's double forward, using two Toshiba 2SK2749 10A FETs. Nice input filter with MOV's. 8A bridge. Not sure what the primary controllers are. So, if I'm incorrect on in any of this, correct me because I definitely could be wrong. It looks like the 5V is rectified by four 30A schottky rectifiers (STPS3045CW). The 12V uses two 20A schottky rectifiers, and according to the datasheet, they can do 20A @ 125C! They're Fairchild FYP2010DN. As far as I'm aware, the 3.3V is generated from the 12V rail via DC-DC conversion and is output using synchronous rectification. The two FETs there are an STP40NF03L and an SSM40N03P. The 3300uF 10V Teapo SC before the coil on the 3.3V rail has failed. The soldering looks good, but definitely not Hipro's best. At least it's lead. The death ADDA was about as dry as a desert in Arizona, but it was still spinning freely, probably because the rubber seal was on there very, very tight. Also, the second lead on the fan temperature thermistor was never soldered to the board:
That my friend is the HP-P4017F5/RS-380-PMSR, a 350W rated Hipro, a 350W version of the 300W Hipro you posted earlier this year. +5V has two STPS3045CWs and the +3.3V rail another two. The +3.3V rail is generated through its own transformer tap and own rectifier, and hence its own winding in the toroid from which it's finally regulated down to +3.3V, hence the fact that it has its own set of filtering capacitors before and after the regulators, which are driven by the +12V rectifiers. How many power on hours were on this unit? 20,000 ~ 30,000? I take it the bulk storage is 560uF. Also looks like that unit has conductive glue. Can't help but notice that the underside of the PCB is silkscreened for a 250W version of this unit. I think the Teapo failed because it's right next to the heatsink and the heatsink probably gets warm if not hot with a heavy load on it. And that's not double forward, that's single switch forward with two switchers in parallel.Last edited by Wester547; 09-16-2014, 07:16 PM.Comment
The soldering quality is horrible. There are lots of bad solder joints and long component leads that are almost touching other leads.
Hipro always screws up the fan controller in some way. Both of the Hipro PSUs I've opened didn't have the thermistor touching the heatsink. There were some Corsair PSUs (which I think were made by Chicony/Hipro) that would shut off because the fan wasn't running fast enough, and none of the components were actually bolted to the heatsinks. They just pushed the components against the heatsinks and hoped the thermal pads would hold them in place.Comment
Cool, thanks for clarifying but I'm still confused. Why does it need two FETs on the secondary? Unfortunately I'm not sure how many power on hours this thing had. Yeah the bulk caps are 560μF. They read 510μF and 514μF. I think the Teapo failed because they're Teapo and they're oldThat my friend is the HP-P4017F5/RS-380-PMSR, a 350W rated Hipro, a 350W version of the 300W Hipro you posted earlier this year. +5V has two STPS3045CWs and the +3.3V rail another two. The +3.3V rail is generated through its own transformer tap and own rectifier, and hence its own winding in the toroid from which it's finally regulated down to +3.3V, hence the fact that it has its own set of filtering capacitors before and after the regulators, which are driven by the +12V rectifiers. How many power on hours were on this unit? 20,000 ~ 30,000? I take it the bulk storage is 560uF. Also looks like that unit has conductive glue. Can't help but notice that the underside of the PCB is silkscreened for a 250W version of this unit. I think the Teapo failed because it's right next to the heatsink and the heatsink probably gets warm if not hot with a heavy load on it.
How effective is this compared to double forward?And that's not double forward, that's single switch forward with two switchers in parallel.
I wouldn't say that the soldering is horrible but it's pretty disappointing for Hipro. The joints on the toroid and 5VSB transformer definitely need to be cleaned and redone. I'm surprised to hear such poor build quality from Hipro, in my experience they've been very good.The soldering quality is horrible. There are lots of bad solder joints and long component leads that are almost touching other leads.
I'd just be interested in how long they lasted. It doesn't need two FETs on the secondary but using two FETs in parallel (or one on the high side and one on the low side) to linear regulate that rail is certainly more efficient than only using one.Cool, thanks for clarifying but I'm still confused. Why does it need two FETs on the secondary? Unfortunately I'm not sure how many power on hours this thing had. Yeah the bulk caps are 560μF. They read 510μF and 514μF. I think the Teapo failed because they're Teapo and they're old
About the same, maybe.How effective is this compared to double forward?Comment
Makes sense. It must work differently than with schottky diode packs, since the specs on the two FETs are different.It doesn't need two FETs on the secondary but using two FETs in parallel (or one on the high side and one on the low side) to linear regulate that rail is certainly more efficient than only using one.Comment
I love that secondary heatsink!
Just like it's not bad enough that 99% of the time the fan controllers are configured to run the psu too hot and quiet, now they even forget to solder the thermistor!!Comment
I'm load testing the D2567F3P PSU at 250W again now after the recap as I type this. The ripple is about the same on most of the rails, but on the 5vsb rail, it's now down to 12.6mV - half what it was before the recap. The fan is also very noticeable at this load and is pumping out a decent amount of air.
EDIT: I re-lubed the fan too. The bearings were dry.Last edited by c_hegge; 09-18-2014, 08:15 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I didn't measure the voltage before, but it was about 5.05V IIRC with 1A load after. I was more interested in what effect it was having on the ripple suppression.I love putting bad caps and flat batteries in fire and watching them explode!!
100th page markerThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Update:Power Systems Inc (from a Tektronix TFP2A FiberMaster)
820uF 200V Nichicon 105C primary unit pair.
2200uF 35V Nichicon PF on all rails; +5V rail has 2200uF 35V Nichicon PF before and after output inductor.
820uF 16V Nichicon PF on primay side control B+ rail.
MJW16010A primary switcher with BUK454-800B synchronous clamping.
KBU6J primary bridge rectifier.
Model number is 225X-34.
SB540 x4 in parallel for +5V 15A rail.
UF5402 parallel pairs for each of the +12V 2.5A, +24V 3.5A and -12V 2A rails.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Recapped the Linkworld. Also replaced the failing Globe Fan with that silly-named chinese one. Much more silent now. Unit looks pretty good. All the CS caps were in spec, even the one on the 12V! Canicon on the 5VSB failed, Fuhjyyu on the 5V and 3.3V failed. Fuhjyyu on the -5V and -12V were fine.
12V rail oscillates on a Haswell system, but is fine on a Core 2 Duo system. It does make a high pitch whine which brings me to the question, how can you tell if a whine is coil whine or from oscillation? I think it may just be coil whine because the pitch does not change at all at any load.Comment
I've isolated the whine to the 5VSB. I tried using caps with lower ESR and it still does the same thing. Went from nichicon PW 1000uF 10V to Panny FM 1000uF 16V. I wish I could remember if it was whining with the failed Canicon caps.Comment
Maybe something on the feedback is bad…TL431, optocoupler? What about the small caps, have changed them as well, for the same type?Less jewellery, more gold into electrotech industry!
  Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
What about the small caps? You should use entry level low esr caps thereComment
Depends, I suggest using same type it was there before unless you are certain you can use low-ESR. Sometimes it doesn't like some drastic change and starts oscillating.Less jewellery, more gold into electrotech industry!
Assuming...7 Photos -
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
