X-Force 200 "Power Supply"
  • Agent24
    I see dead caps
    • Oct 2007
    • 4958
    • New Zealand
    https://youtu.be/0OSA1CS8bV4
    http://www.xforceamps.com/item/Adjus...wer-Supply-448
    As Morpheus said: "You have to see it for yourself"
    -David VanHorn
  • Sparkey55
    • Jan 2010
    • 1523
    Re: X-Force 200 "Power Supply"
    The box of death.
    • lti
      • May 2011
      • 2548
      That website looks like it was written by a 12-year-old in 1997.
      It's still better than the power supply. If you're extremely lucky, it's a circuit breaker tester.
      • Sparkey55
        • Jan 2010
        • 1523
        It's still better than the power supply. If you're lucky, it's a circuit breaker tester.
        More like a fire exstinquisher tester.
        • lti
          • May 2011
          • 2548
          Yes, there isn't much that can fail in a way that trips a safety device.
          It also tests your body's tolerance of 120V.
            master hoarder
            • May 2008
            • 12175
            WOW!
            That is one helluva shit power supply. Makes me feel completely safe about using my PowMax and Deer power supplies to their full labeled ratings - at least they will just blow up and pop their fuse. This thing...
            LOL, that sums it up pretty well.
            And the description of their power supplies is absolutely hilarious. For those who haven't visited the website linked, here are some of the best quotes/lines.... at least IMO:
            "-- They Are BAD TO THE BONE"
            I say: Yeah, no shit Sherlock. This is the "baddest" power supply I have seen - literally!
            "-- To Keep You Swinging That XFORCE Hammer With Authority !!!"
            I say: Ooh, the power supply come with a hammer? How thoughtful! Indeed I will keep swinging it... with authority... until that thing is broken into pieces.
            Now who would like to see/get the "3500amp" model?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              They didn't even get it UL listed?
              Yeah this supply is not going to last, and take things out with it...
              BTW, what is the target for a "2KW" 12V PSU... use it to start car engines? Normally amplifiers and transceivers, if they need the watts, they go up in voltage, makes things easier and cheaper to boot.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4958
                • New Zealand
                What would be the point in trying?
                The only place this thing should be listed is on the F.B.I. most wanted!
                -David VanHorn
                • Sparkey55
                  • Jan 2010
                  • 1523
                  2KW 12VDC would do about 1.5KW output power from a linear rf amp. Think CB amp. Any SB box with a booster could drive the linear to full output.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Well, if they tried, then it would never have been sold.
                    That's the problem, can one really build something like that which actually works properly? I thought most of these tube linear amps, well, don't run off of 12V power.
                    Ganging up a bunch of low voltage transistors to run at 200 amps (AVERAGE, and there are no single transistor solutions) for the finals does not seem feasible, they will not all behave the same.
                    If people don't care about actual RF fidelity, then they might well buy this BS PSU...
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4958
                      • New Zealand
                      They probably knew that it would never pass, so instead of drawing negative attention, just sold it "under the radar".
                      Or, like the completely clueless design, they may actually just have had no idea what UL listing is.
                      -David VanHorn
                        • Jul 2011
                        • 6039
                        That power supply from hell like the person doing this you tube video I would not even think about plug it in into outlet
                        Really who thought of this crap knock off from a knock off and take as many short cuts as possible and let see if will not burn down the house or wherever it being used
                        I have seen some very poor design crap but this one takes the cake
                        Thanks for sharing this video I got real laugh from it
                        I might Jerry rig something to test some piece of equipment but sure would not leave it like that
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          You cant fix STUPID.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Yeah I'll be honest I'd possibly could jury rig something like this, but:
                            - I'd never hook up power supplies in parallel if they weren't designed for it
                            - mains power would get upmost attention to details. I may even have line power go to the switch first, then to the fuse, just to make sure the fuse was dead when switched off.
                            - I could NOT get myself to deadbug that little circuit they had there. Wow. Such patience. I'd fabricate my own board if I need it.
                            This definitely is not a mass produced design. Building that board would take forever for each unit.
                            There are some things I would have to disagree with the presenter:
                            - the shorted internal fuses. While the application of the internal PSUs is wrong and hence probably why they short out to prevent blowing, it's okay not to have a fuse there if the main fuse and the reset of the circuit was designed properly...
                            - the custom board and the tapped out "brown wires" ... again if the design/application was correct it'd not be an issue, though this is a manufacturing optimization and not a safety hazard.
                            - The grounds on each individual internal power supply would be nice to have but I don't think it really matters as long as the external chassis was grounded properly. Worst case failure would not be any different whether they are grounded or not. However the cost is low and would help out RFI anyway, there's no excuse to omit them.
                            - I believe the color coding of the wires are necessary for UL listing as well as would be a manufacturing optimization so a layman could connect wires without knowing what they were for. Not an issue if they didn't care for UL listing and they were hand assembling and testing themselves.
                            The problem is of course people usually wouldn't open these things to inspect before using them, especially if they have warranty seals on them. Not sure what to say at this point other than to try to open everything that one buys... including that vacuum tube tester that I posted about in the test equipment subforum...
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              They have a FORUM. Check it out.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                more nasty shit for childrens band.
                                meant to power a spurious and harmonics generator.
                                aka splatterbox amplifier.
                                x-farce!
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
                                • CMCM
                                  Russound CA4 Power Supply Repair
                                  by CMCM
                                  Hello Everybody,
                                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                  The outputs marked 12v and 20v are all measuring only 1v.
                                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                  The capacitors physically look clean (no bludgesor leaks) and...
                                  07-03-2025, 01:12 PM
