Miller 375 Plasma Burt Cap..
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Miller 375 Plasma Burt Cap..
    well, that's no fun, this is a 3 or more layer board with embedded layer via connections I guess that's the end of remote debug for me, need a continuity checker along with the board for me to work on multilayer boards without a schematic.
    Just a word of warning: this board is extremely fragile to work on, so be careful: if you damage the plated vias, game over.
    The only thing left to suggest: if the semiconductors all look good (i.e. no shorts) it might be worth to just replace that 100Ω resistor and see what it does, make sure you use a DBT and just run it without welding/cutting to see if it at least powers up... I suspect it's simply completely dead at the moment prior to any parts removal?
    • KG7AMV
      • 41
      Yea, reason why i am not using solder wick.. Proper desoldering tips..
      I will test the transistors, photo the PCB reassemble with any failed /damged part replaced.
      My Personal Blog
      • KG7AMV
        • 41
        Miller Support Got Me A Schematic For The Machine To My E-mail Box This Afternoon Will Upload Soon..
        Bus Precharge Circuit and R123 is 10ohm PTC Thermistor has to be something cheaper..
        http://www.brweldingsupplies.com/mil...-10-ohm-25-deg
        +1 For Miller...
        Schematic Drawing
        My Personal Blog
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Ah... yeah, normally SMPS have thermistors there, it's very typical along with a relay to get higher efficiency. I was thinking about how practical a regular resistor would do there...may work fine too but I've never worked on welders before...
          oh... main reason for posting... after being infatuated with varactor diodes (yes for radio ).... that MOV RV1 in that schematic is hideously wrong.... I think two inverse series zeners would be a better representation for a MOV than two inverse parallel varactor diodes...
          • KG7AMV
            • 41
            Just need to find a source that is not a Welding shop or miller part # $13+ ouch..
            My Personal Blog
            • R_J
              • 9551
              Do you have a picture of the original R123 ptc thermistor? or did they have that white ceramic resistor in its place?
              • KG7AMV
                • 41
                Ceramic Resistor was in R123..
                My Personal Blog
                • R_J
                  • 9551
                  So they are replacing the 10Ω resistor with a ptc thermistor? too bad they don't provide a picture of the 200656.
                  I guess that resistor was a 10Ω, I hate when they mark 100 and its actually 10 multiplied by 0
                  This digikey 570-1024-ND would likely work but it is $9.24
                  • KG7AMV
                    • 41
                    Yea, I also hate parts labeling like that..
                    I Also Notice that PM1 Has Miller Part # What Could it Be? Seems to be the only proprietary #'d part.
                    My Personal Blog
                    • KG7AMV
                      • 41
                      I Also Notice that PM1 Has Miller Part # What Could it Be? Have not seen any Other Proprietary Parts on The Board.
                      Here Are The Extracted Schematic Images
                      My Personal Blog
                      • R_J
                        • 9551
                        Does it have 4 legs or 5 ? it could be similar to the ALFET ALF08NP16V5 but this is a fet, the schematic shows similar but with transistors. So it's a TO-247-5 package
                        You could use Go Advanced and attach the documents , that way all the pictures don't have to download each time we go to the thread,
                        • KG7AMV
                          • 41
                          5 legs..
                          My Personal Blog
                          • R_J
                            • 9551
                            I did find a similar item on alibaba
                            • CapLeaker
                              Leaking Member
                              • 8195
                              That isn't a Miller stamp... Maybe Microchip, Micrel etc?
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                The logo appears to match that of in the schematics....
                                This device seems to be some two way insulated gate controllable bidirectional diode... weird.
                                • R_J
                                  • 9551
                                  There is a bit of information here https://www.elektroda.pl/rtvforum/topic3329021.html
                                  Here is a translate of the miller reply to the person
                                  I wrote to Miller and here's the answer:
                                  Miller part number 218760 is a proprietary part not available as a service item. There is no third party source for the part.
                                  The subject is closed. Thanks.
                                  • KG7AMV
                                    • 41
                                    R123 Is a Thermistor Miller Part # 200656 I Found For 12.88.
                                    Their Description "THERMISTOR PTC .10A 600VRMS 10 OHM"
                                    Still Seems like an Excessive Price For a Thermistor? Anyone have a source for alternate source? I tried Digikey, Mouser, Etc... But Nothing with them specs..
                                    http://miller4less.com/product_info....ducts_id=99742
                                    My Personal Blog
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      The only test I can come up with for the 218760A is to ensure there's no connectivity between pins when it's out of circuit much like a MOSFET. Otherwise probably SOL other than getting another from Miller if it needs to be replaced.
                                      Likewise for 200656 it seems Miller wants custom fees for custom parts...
                                      • R_J
                                        • 9551
                                        I posted this: This digikey 570-1024-ND would likely work but it is $9.24
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          570-1024-ND is quite large, hopefully it will fit: it's over 1.3" in diameter... At least it's thinner, however.
                                          I'd be tempted to stick a regular resistor there, however...
                                          • CapLeaker
                                            Miller Diversion 165 TIG no arc
                                            by CapLeaker
                                            Hmm… someone brought me this Miller Diversion 165 TIG welder for repair. Claim is it doesn’t arc. Well it tries doing something if I put the tungsten tip straight to the aluminum plate. All I hear is a little tick… tick… tick…, I have the power LED on, but the other (blue?) LED doesn’t light up. I think it is supposed to when there is an actual arc.
                                            So I opened it up, found a bad looking connector between the main board and the small HF board. Checked the SCR and few other things on it and found nothing. Then tried again. Same thing. I will not for its own life strike...
                                            05-14-2025, 03:32 PM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • porfyriadhs
                                            Samsung Plasma PS51D6900DS Bootloop
                                            by porfyriadhs
                                            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                            Thanks a lot !!
                                            10-19-2023, 11:31 AM
