Miller 375 Plasma Burt Cap..
  • R_J
    • Jun 2012
    • 9632
    Re: Miller 375 Plasma Burt Cap..
    It looks like they used a ceramic resistor originally, 10 ohm
    Digikey A102453-ND or TWW5J10RE-ND (5watt); A103695-ND (7 watt); A131255-ND (10 watt)
    If that ptc is too large there are likely smaller ones that would work. I was basing it on the 600 volt rating of the miller part.
    Ametherm site: https://www.ametherm.com/inrush-current/
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Originally posted by R_J
      There is a bit of information here https://www.elektroda.pl/rtvforum/topic3329021.html
      Here is a translate of the miller reply to the person
      Ouch! That sux...
      • KG7AMV
        • 41
        Whats Under The Hood.. So far No Bad Parts.. Except the Relay and Resistor.
        So All Burnt Parts, Replacements On The Way Prob Tuesday. Including that HX50-P Prob Still Good But it is Burnt..
        My Personal Blog
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          That is what I was hoping for. Just the relay and the resistor. It could have been more, but I am sure the relay went out first, then the resistor burnt up.
          • KG7AMV
            • 41
            looks like it but for blog content I pulled the transistors and cover.. But best to check everything.
            My Personal Blog
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              Personally I would have done the same thing!
              73!
              • KG7AMV
                • 41
                Been a while but was waiting on the PTC R123 part Number (then got distracted) But,did just today get a reply from Miller on the PTC it is a VISHAY (BC COMPONENTS) P/N: 2381-663-93025 VISHAY (BC COMPONENTS) P/N: PTCTL8NR100HBE so I will click go on the shopping cart Wednesday.
                Hope to free some time up mid next week and reassemble this been taking up way to much bench space.
                My Personal Blog
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Let us know how it goes! That Chinese Plasma Cutter I fixed in the spring is still going strong. Problem is to remember what goes where after something has been apart for a long time.
                  • KG7AMV
                    • 41
                    Yes, I took lots of photos on disassembly.. then had a phone crash so going on photos I uploaded LOL.. and Schematic's!
                    My Personal Blog
                      • Jul 2011
                      • 6070
                      I watching this post I might have to fix one someday
                      • KG7AMV
                        • 41
                        All parts on the way arrow had the best price on most items.
                        My Personal Blog
                        • petehall347
                          • Jan 2015
                          • 4451
                          #52
                          what is a "burt cap " ?
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            I figured you watching this one...
                            • KG7AMV
                              • 41
                              Happy Halloween..
                              All parts arrived.. total Costs $18.00 - $28.00 Ish. for the Fix..
                              All Assembled see my blog for finial assembly and well the Result..
                              https://youtu.be/V6PePXDHt0k
                              Plenty of good conversation on this.
                              Did checks on both 110 and 240V all good.
                              My Personal Blog
                                • Jul 2011
                                • 6070
                                So did you get it working again if you did how well dose it work
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  Glad you got it working!
                                  • CapLeaker
                                    Miller Diversion 165 TIG no arc
                                    by CapLeaker
                                    Hmm… someone brought me this Miller Diversion 165 TIG welder for repair. Claim is it doesn’t arc. Well it tries doing something if I put the tungsten tip straight to the aluminum plate. All I hear is a little tick… tick… tick…, I have the power LED on, but the other (blue?) LED doesn’t light up. I think it is supposed to when there is an actual arc.
                                    So I opened it up, found a bad looking connector between the main board and the small HF board. Checked the SCR and few other things on it and found nothing. Then tried again. Same thing. I will not for its own life strike...
                                    05-14-2025, 03:32 PM
                                  • ArMaaN376
                                    Samsung PS51E550 Plasma TV
                                    by ArMaaN376
                                    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                    Opened TV cover & observed foll
                                    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                    How to confirm Y -Buffer board...
                                    06-19-2024, 04:05 AM
                                  • jm1234
                                    Panasonic plasma TX-P42ST50 - 6 blinks
                                    by jm1234
                                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                    I checked that board for any obvious faults...
                                    05-22-2024, 06:59 AM
                                  • KYBOSH
                                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                    by KYBOSH
                                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                    No picture but you hear the TV static (white noise) playing loud and clear.
                                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                    But it seems they didn't get too far and just left it.
                                    When I first took a look I was amazed at how pristine the inside looked.
                                    Its as if the TV had been in a time capsule.
                                    Caps looked like they were just pulled off the self.
                                    Copper coils had no sign of corrosion on...
                                    02-01-2023, 11:10 PM
                                  • alltvrepairs
                                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                    by alltvrepairs
                                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                    Any one met this problem in the past?...
                                    10-08-2025, 07:34 AM
