Led mirror Ball PSU with no power output
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi Guys got another project here and looking for your advice got a led mirror ball that stopped working so checked power board and doesn't have any voltage on the output side and idea where to check for faults cheers guys
    Your never to old to learn
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8698
    Re: Led mirror Ball PSU with no power output
    Did something leak the "magic smoke" when it died (do you smell magic smoke from the circuit?)
    What's that TO-92 circuit, is it a transistor? Is it still good?
    Are there any ICs underneath the transformer?
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Hi, there no magic smoke and no smell from the board the to-92 is 13001 S6B 0 2A 400V high-voltage transistor to-92 plug-in flying electron and the small transistor is a j37 which I can't find any info on.
      Any help much appreciated
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8698
        Okay, looks like a 2-transistor switching supply. The 13001 is the switching transistor, did that burn out?
        • redwire
          • 3906
          Usually the MJE13001 shorts and blows up.
          But there is no fuse here, so I would check all parts for continuity. The transformer primary might have been the fuse...
          J3Y marking code is KST8050S
          It looks like poor build, the transformer core isn't glued aligned and any problems with it make the circuit not work.
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            This thing looks cheaper than garbage! I'd honestly just try to replace it with a different, better quality power adapter. If the LEDs don't have resistors to limit the current, you might have to add those before using another power adapter.
            That said, if you still want to try and fix this thing... my guess would be that the 13001 BJT probably either shorted or opened. If there is no fuse, it most likely went open-circuit, because TO-92 transistors can't really handle high currents and will easily blow their junction. Just remove it from the circuit and check it. If you don't see a normal forward diode reading between Base and Emitter/Collector pins or any reading out of circuit between Emitter and Collector pins, it's likely bad.
            • kevin!
              recapping PCB.
              • Jul 2013
              • 195
              • España
              How to comment momaka, look for a good quality replacement. That PSU is manufactured thinking of the cheapest and saving costs. That PSU is a danger.
              Gaming pc:
              nVidia RTX 3080 TI, Corsair RM750I.
              Workshop PC:
              Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
              Server:
                • Jul 2011
                • 6037
                I would also check the ( M7 ) diode I have seen a few of fail open and some of them short
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • tony359
                  Global AC logic output - XP Power FleXPower
                  by tony359
                  Hi all
                  I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
                  "Fan Fail" would work when the fan is manually stopped.
                  "Global DC" would change state when I manually adjusted one rail beyond 10%
                  "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC"...
                  06-20-2025, 03:06 PM
                  09-06-2024, 05:59 AM
