Powersupply washingmachine. Relay problem?
  • R_J
    • Jun 2012
    • 9582
    Re: Powersupply washingmachine. Relay problem?
    I bet the problem is the (ipm) actually it is a CIPOS. I am going to take a guess and suggest you check that part.
    You should be able to diode test the output, check between P-U, P-V, V-W, W-NU, V-NV, W-NW. this should be the layout looking at the back of the board
    The voltage on the KIA78R15PI is a bit low and might effect operation, it supplies the low side control of the cipos ic, depending on what the part number is it should be around 15-16 volts
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      #42
      I took the gamble and heated up the topside of the board with a heat gun with most heat going to the capacitors. The voltage on the regulator changed from 12 to 13.5v and its now running a program. Im waiting to see if it finishes the program.
      The regulator has to be 15v , i measured on the good board.
      So either because of heat the board expands and fixes a loose connection OR the heat charges for example the capacitors or spool?
      What do you say?
      • R_J
        • Jun 2012
        • 9582
        Check the input voltage to the regulator and see if it changes when heated, I believe the cipos ic requires a minimum of 14 volts, 12 would be too low for it to operate.
        There are 3 diodes that supply voltage from the transformer the one you measured before supplies the regulator ic, the other 2 are D5 and the one beside it, check there voltage also.
        The cap CE9 in the primary could be bad and it would effect all the output voltages, the other 2 I circled are the input and putput oc the 15 volt regulator ic. I marked with arrows the output voltage test points
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          #44
          Thanks for the pictures , helps people in the future.
          It did not finish the program because the voltage went down to 13.2v. I heated up the board again and just in the area of the small caps. The diode voltage goes from 17.3 on cold start to 16.9/17 when heated so the input voltage goes down. It looks like its stabilising if that makes sense.
          I got it eventually to 13.6v and it ran the motor again.
          Funny thing is that the voltage is fluctuating when it goes below 13.5v because it tries to start the program and "pulls" down some component.
          The upper right cap that is marked in the picture above is not standing straight on the board like all the others. Maybe the silicon pulled the capacitor out because of vibration?
          I got the caps so i can swap them?
          • R_J
            • Jun 2012
            • 9582
            That is just a basic smps. 17 volts should be enough to get 15 volts out of the regulator ic, but if the caps are weak that could be the problem. if changing those caps does'nt fix it I would replace that regulator ic next. 13.2 volts is too low, 13.5 is the minimum voltage for the ic motor drive ic to run. So it looks like that cipos is ok and the low voltage is the issue.
              Great troubleshooting so far.
              I have seen these KIA switched LDO regulator goes out a lot in the Sharp TV, it uses 12V version.
              It has really low drop out Voltage so I do expect it to be able to put out 15V easily with 17V input.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #47
                I replaced all the caps and i still got 12v on the regulator. This makes me believe the regulator is bad because when i heat it up it will go up to 13.6v. ( or heat is spreading around the board...... )
                I got this sharp powersupply somewhere. Do you mean this PS or a different one?
                  That Sharp uses SWITCHED 12V IC for the 12V_PANEL, you need the 15V one for your circuit.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8297
                    and what is the voltage input to the regulator? Does it go up and down too, when you apply heat?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #50
                      It starts on 17.3v cold start and when i apply heat the output goes up and the input goes a tiny bit down to 17v.
                      Datasheet says it needs atleast 16v to make it 15v so im pretty sure its the regulator.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8297
                        Sounds like it... anyway it would be exactly that what I'd be doing.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #52
                          Will let you guys know when the part is installed. Waiting for the post....
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #53
                            Replaced KIA78R15PI and the machine is now running like new! Thanks everybody and especially R J for all the help , i learned some new things and i can make someone happy!
                            Total cost , $3.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8297
                              Good job Morneno!
                                Thanks for the follow-up.
                                • R_J
                                  • Jun 2012
                                  • 9582
                                  Glad to here you got it working.
                                    • Jul 2011
                                    • 6059
                                    I had a feeling that this KIA78R15PI chip was not working right
                                    • peterpancanfly
                                      • Jun 2014
                                      Where can I get KEC voltage regulator ( KIA78R05PI ) from? I've got the same issue.
                                      Found the forum very educational.
                                      • peterpancanfly
                                        • Jun 2014
                                        Sorry, mean the KIA78R15PI
                                        • R_J
                                          • Jun 2012
                                          • 9582
                                          You should be able to use the KA78R15 Digikey KA78R15CTU-ND
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                          • edugimeno
                                            Diagnose real-vintage Strong-Hammer arcade machine
                                            by edugimeno
                                            Hi there!
                                            My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                                            I am attaching several pictures of the machine.
                                            It basically has 2 sides, left side has
                                            • 2 x 220->12+24v transformers
                                            • 2 relays (1 moves motor UP, other moves motor DOWN)
                                            • IGF and breakers for safety
                                            Right side is shown on pictures. It has 3 boards ( top-down)
                                            • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                                            02-29-2024, 11:05 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
