Suspected psu problem on 1570 disk drive
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    I was just using my Commodore 1570 disk drive that has been sitting for a year or two and it was working fine for about 15 minutes. Then I left it to format a disk and when turned round to check on it the drive lights were all off.
    This thing is real old fashioned transformerror power supply. I've disconnected the power outputs and i am getting 5 volts and on the other output I get 19volts but when I plug the power output to the drive motherboard the 5 volts remains stable while the 12 volts drops to 0.5 volt. Can someone give me a idea what to suspect. I have a service manual for a similar drive and it has the same psu as this one. You can get it from my Dropbox here:
    https://www.dropbox.com/s/kme7z0bweh...85%29.pdf?dl=0
  • CapLeaker
    Leaking Member
    • 8297
    Re: Suspected psu problem on 1570 disk drive
    Either the output capacitors in the PSU are bad and can't handle the load, bad LM340 cant handle current anymore, or there is something shorted on the 12V rail inside the drive, loading it down. Measure the resistance between the +12V rail and GND and the 5V rail on the disk drive. Maybe there is a short?
      • 31163
      if it's anything like the original 1541 then i would replace all the thermal compound on the heatsinked parts - it's going to be dust by now.
      then recap it.
      i used thermal pads on mine - didnt want paste all over my fingers!
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        Thank you for your help. Ive had a good look at it and traced the 12v rail through the PCB and listed all the components it travels to. There is surprisingly few mainly resistors and few ceramic caps and 2 transistors. I hope its one of these because otherwise it would be a faulty IC. I just today found a schematic for the drive. Can someone take a look at it and suggest where its most likely to have happened. The two Transistors I was talking about are Q2 & Q3.
        Schematics attached
        • R_J
          • 9582
          Have you tried a different load on the 12 volt line of the power supply to confirm it is not the problem? IE 25 ohm 5 watt resistor, should draw about 1/2 amp
          with the drive connected did you check the voltage going into the 7812/LM340 regulator?, if it is droping the output to .5 volts the reg. ic would be getting very hot also.
          I cant make out the second schematic
          I found the schematic on line and I doubt q2 OR Q3 could cause the problem, the base's are connected to the 12 volts through 4.7k resistors, a short after the resistors would not kill the 12 volt supply
          You could have a shorted motor, can you disconnect CN7 plug?
          You could have a shorted U7, disconnect one end of L3
          • roadrash
            • Oct 2015
            • 490
            • U.K.
            Thanks RJ that helps a lot. I will have to go search out a 25ohm 5w or more resistor. I was wondering, if I dont have one can I use a 12v light bulb? I have lots of those 5w to 75 watt.
            • R_J
              • 9582
              A light bulb should work, If the power supply can output about 1/2 to 1 amp It should be ok. I would think the output should be close to 12 volts unloaded, if you measured close to 19volts I think that regulator ic is bad
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                Yeah I was right I have no resistors like that unless I rob one from something else.
                What sort if wattage bulb should I use? I was kind of hoping it was a voltage reg or something rather than a motherboard problem.
                • R_J
                  • 9582
                  try the 12 volt 25 watt lamp first, if you want to draw more current add a second one in parallel
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    I tried a 12v 25w bulb on the 12v output and it did not illuminate the bulb. However when I tried it on the 5v output it made a very good glow for 5v.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      replace the 7812.
                      i have seen them fail in these back when these drives were popular.
                      the 19v reading is the big clue that its bad.
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        This is great news as i really didn't want it to be any to serious. I have a 1541and a 1541-2 and they have both been reliable. It was just how quick this failed when it gave no warning of any kind. One minute working then turns off. Thanks for that will get that 7812 replaced.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          Thank you everyone The new 7812 Transistor arrived today. I fitted it and tested the output with the meter and 12v bulb and it showed it as working as bulb lit bright. Connected it to the drives motherboard and it powered up just how it should. Its amazing how some things can be working one minute then die suddenly with no warning. But thanks to you guys on here its all working again THANK YOU everyone...
                          • madura2010
                            DAY11AM6E0 hard disk drive and optical disk drive not detected
                            by madura2010
                            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                            i checked the connectivity of ribbon=good communication with hard and motherboard
                            changed hard disk and checked=3f0 error persist
                            sata power=+5v available
                            Then checked data capacitors=all good
                            Then checked data lines path connectivity to pch=all good
                            reflashed...
                            03-12-2023, 09:09 AM
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                          • reformatt
                            Intel iMacs, 3rd party SSD failures and Fusion setups
                            by reformatt
                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                            12-18-2024, 10:34 PM
                          • perfm2
                            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                            by perfm2
                            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                            Steps taken in my usual process.
                            Reset security settings in the BIOS
                            Ensure existing HD comes up into the OS
                            Shut down the laptop and disconnected the main battery
                            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                            Replace battery connector and close up the laptop
                            Insert my USB drive with my Windows 10 image I've...
                            03-21-2023, 08:45 PM
                            HP EliteBook 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 1000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                            09-06-2024, 08:50 AM
