Re: I found the bad cap, looking at replacements
Yes! An equipment grounding conductor (EGC), from DC common to the "third wire" of your (new) power cord. Your line voltage is 120, so for a 200V input filter, use Nichicon CS.
Connect line & neutral from the cord to the fused & unfused (respectively) AC inputs on that PCB. Connect the green or green/yellow wire from the line cord to the "-" pin on the first filter cap after the transformer/rectifier on the secondary side.
So if/when it shorts pri-sec, the fuse blows and/or bkr trips, if fault current gets into bkr's instantaneous range. Instead of the output sitting at line voltage, with the connected load still working, it's made safe and the input to the supply is killed.
Let me add that those supplies are kind of flopping loose in that case- at least move them outside. Those little supplies, not that I'd use them personally, can be just as nasty as bigger ones, like what was in that case originally. Don't let their small physical size or capacity be mistaken for small hazards.
After looking at this, I think you'd be better off with an external "brick" supply connected by a cable and multipin plug/receptacle.
When i say safety i mean for the intended load not me, is there anything i can add on either the dc or ac side of the circuit?
as for the pictures of the 12v adapter:
https://imgur.com/a/ps6uALeave a comment:
"So assuming the transformer fails and allows ~170v to go through is there a fuse i can put in the output line to act as a safety? i would say a fuse of about 1.5A should be fine"
re you talking about putting a fuse on the DC output of the power supply?
If that is the case it will not protect anything if the transfomer insulation failed, you will likely to get electrocuted, the fuse on the DC output is not going to do anything.Leave a comment:
I know i would want a fast blow, but i do not know what the difference in between glass and ceramic, well i know what they are but i do not know why it matters in a fuseLeave a comment:
that unit is running my network switch and powers my keyboard light (SMD 3528 led strip), i think i used a TIP120 transistor to turn it on/off
but yes i can take a pic for you, easier now then back when i took that last photo, i have space connectors on the mains power lines now and there is a molex plug on the DC side, i can do so this afternoonLast edited by evilkitty; 11-23-2017, 10:39 AM.Leave a comment:
@stj you hit the nail on the head with the brand part (Changx)
I have 2 questions about the series
1. do you have a link to what each means/ intended use
2. which series do i want for each cap
I do have 3 of these units (replacing caps in all), 2 have the same garbage caps, one has different caps, the other has Jwco, the larger 10uf caplooks to have a actual number on it (CD11G brand appears to be jw)
https://www.badcaps.net/forum/showthread.php?t=47823
@Per Hansson
After looking at that cap, wouldn't this one be better/last longer?
https://www.mouser.com/ProductDetail.../EEU-FR1E471Y/
and about that 400v cap, does that need to be fr as well?
i had this in my cart, i know it is only rated at 160v, but it should only be getting used at ~125v
https://www.mouser.com/ProductDetail...47-UCA2C100MPD
You can use any 400v rated cap you find on your favorite shopping site, it really does not matter. (It does not have to be low ESR).
EDIT: This one is nice, maybe it was already linked before:
https://eu.mouser.com/ProductDetail/...5TgiW03dbXY%3dLast edited by Per Hansson; 11-23-2017, 09:55 AM.Leave a comment:
Would it be easy to take a photo of the 12 volt & 5 volts power supply board I am curious of the quality of that power supply seeing the quality of the 5 volt board is to me is crap
Just a thoughtLeave a comment:
While i do agree with that, but with how i am using the one that failed, that very nice unit is a bit large to fit in addition to being overkill
https://i.imgur.com/CyOkW3C.jpg
i have a 12v and 5v adapter in thereLeave a comment:
even fc will do on the output.
eb are fine on the input.
since i stock fc to simplify stock i use them for the startup.
they always work.
if you got hot output caps in 60sec they are backwards or rectifier leaky.
digikey offers usps 1st class and i dont mind the big flat box small orders come in.
great for shipping tcon,mains,frc,ect.
i reuse them.
agreed on that being a shit power supply.and a transformer failure may make the output live with line voltage.Last edited by kc8adu; 11-23-2017, 09:13 AM.Leave a comment:
I want to replace the low quality caps in the 5v 2a adapter my rpi uses (I did make sure it can do 2A, not sure how long it can handle it with how hot the 470uf caps get, but it did so with 0 vdrop; that test was done with 18awg wire soldered to the board, not over a micro usb plug)
it had 2 caps fail, both are 470 uf 16v, they are by far the hottest running component in the unit
they lasted about 1.8 years
First of all to me this a garbage power supply I would just take the low voltage power supply cord off of it and use this power supply after you replace the caps inside of it is very easy it has one screw that hold it together
Here is the link where you can buy one
One note every so often they run a sale on these power supply for $5.00 each some times they have a limit to how many you can buy and sometimes do not
http://www.goldmine-elec-products.co...?number=G20394
If you want to see the inside of this power supply look at this post at the top of the page
https://www.badcaps.net/forum/showth...t+Power+Supply
One thing that nice about this power supply is that it has an adjustment for the output voltage
The range is 4.75 to about 5.75 volts
I use this power supply for all of phones and tablet it works very good and this power supply run cool when pushing 2 amps while I am on my tablet surfing the web and charging the battery
I have pushed this power supply to 4.5 to 5.0 amps and dose get a little warm to touchLast edited by sam_sam_sam; 11-23-2017, 09:11 AM.Leave a comment:
sadly mouser does not carry rubycon
i ordered from digikey once but they charged me way too much in shipping, they sent be a box full of packing paper, almost entire cubic foot of it
*looks at life span*
if i use mouser i guess that limits me 1 one of these 2 with only about 1/2 the life
https://www.mouser.com/ProductDetail/647-UCY2G100MPD (400v Nichicon)
https://www.mouser.com/ProductDetail...XG201ELL100MJ1 (200v United Chemi-Con)Last edited by evilkitty; 11-23-2017, 08:26 AM.Leave a comment:
for the 10uf,
i'd use rubycon LLE series 10uf 250v (on 110v mains only!!)
that range is intended for led lamps and has incredible rated lifetime!
i use them in my radio chargers.Attached FilesLeave a comment:
You cannot go wrong with PANASONIC caps FR, FM series .
'and about that 400v cap, does that need to be fr as well?
i had this in my cart, i know it is only rated at 160v, but it should only be getting used at ~125v'
https://www.mouser.com/ProductDetail...47-UCA2C100MPD.
Nope, do not using 160VDC cap! the dcV on the cap after the rectification is about 120VAC x 1.414 = about 170VDC!, they use 400VDC cap because that adapter is probably made to handle 230VAC as well. Never go lower Voltage than the original.Last edited by budm; 11-22-2017, 10:44 PM.Leave a comment:
the transformer seemed warm, but those 470uf caps were cookin and it was not a very long test, maybe 60 seconds
for actual use this board is only outputting 0.5A and at most 1A or 0.5+ what ever it takes to charge a old 2ed gen ipod shuffleLast edited by evilkitty; 11-22-2017, 09:21 PM.Leave a comment:
Check temp rise on that little transformer- bet it's cookin' at 2A out w/o the PCB in the enclosure.
Sorry to say that looks like lots of cheep "fone chargers" I've EOLed. That has potential to kill if the transformer overheats and shorts pri-sec. It'll keep working with 5V across the output leads while line voltage is present to external GNDs, including YOU.
R- PI is the next frontier in cheep POS supplies, after gray/black market tablets/ fones & aftermarket chargers.Leave a comment:
I have not replaced any caps yet, all i did was swap a in a spare board
the original caps run hot, but to be far the adapter puts out 5.25v and i used 2.4 Ohms (5 Ohm 10% 10W x2) resistance and it did maintain 5.25v and it is rated (more accurately labeled) at 2A
we all know anyone using knockoff/fake caps does not care how long the unit last
I want to make sure i get the correct/best caps
@Per Hansson
@stj
as for the 47uf cap, this is the only one matching what you would use:
https://www.mouser.com/ProductDetail...67-EEU-FR1H470
It is a tad wider but i think it will fit
https://www.mouser.com/ProductDetail...47-UCA2C100MPDLeave a comment:
your wrong because the idea is NOT to have to fix it again later.
i would use a 47uf 35v/50v panasonic FR in it.Leave a comment:
I know others on here disagree, but I don't think it matters which brand you use. especially on cheap chinese parts like this.Leave a comment:
I think if you use caps that are physically larger then they will be able to handle more current with less heat.Leave a comment:
The fakes fail a lot sooner than the real ones, Chong and ChongX are spinoffs of the actual caps ChengX and Chang which ChengX being made by Bentex and Chang being made by Yang Chang.
Oh yeah, keeping in mind that they're fake. I found out fake caps are usually highly deprived of electrolyte. They reduce the amount to reduce costs, this is easily seen by taking a fake and a real and opening the fake one and the real one. The real will have much more electrolyte than the fake. The fakes also commonly have a very clear, (sometimes) odorless electrolyte.Last edited by jazzie366; 11-22-2017, 03:03 PM.Leave a comment:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by SluggerBI have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...-
Channel: General Capacitor Questions & Issues
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
I decided to verify that the batteries were... -
by Paxman_SwedeHello!
I have studied the board and...-
by fl0wHi,
I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
I need to replace:- 2x 2.5V 1500µF => I plan to use this
- 2x 16V 330µF=> I plan to use this
- 1x 6.3V 680µF=> I plan to use this
Thanks for...1 Photo-
- Loading...
