Dell NPS-110CB bad?
  • pentium
    • Mar 2006
    • 2778
    Dell NPS-110CB bad?
    I had two Dell Optiplex GX150 systems come in today marked "dead".
    I plugged them in and both give me a glowing standby power led on the board and a blinking front light but pressing the power button does nothing and one of the PSUs give off a squeal.
    I would open the PSUs and look myself but I can't seem to figure out how on earth to get them out of the case. I see no screws or clips anywhere.
    Is this model known for badcaps or is it just something else in the system?
    Find Nedry!
    Check the Vending machines!!
  • Wizard
    • Mar 2008
    • 2296
    Re: Dell NPS-110CB bad?
    Is this SSF
    Push down the thumb green lever hard and push PSU foward at same time.
    This is 815 chipset with memory in the AGP slot. PIII and coppermine celerons only and supports 100 and 133mhz but not tualatin support, 512MB limit. Meh. Chassis is slot & hook style for mainboards. Not ATX design. CDROM notebook drive is 24X.
    The squealer meant southbridge blown. Not exactly a bad caps PC. I have this PC as well. It's not used much for this reasons.
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      You sure it would be the southbridge?
      I unplegged the PSU and it still squeals so it is from the PSU.
      Also, there are no green clamps short of the handle that pulls off the PCI riser card.
      EDIT: 512 and coppermines is not a problem. All I seem to find are coppermines and Windows 2000 is still plenty happy with 512Mb
      Find Nedry!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Squealer PSU's have a habit of blowing southbridges.
        Depends on exactly -why- PSU is squealing too but that's a common symptom/result scenario.
        Doesn't mean it's blown yet, just that it might be.
        Mann-Made Global Warming.
        - Dr Seuss
        • pentium
          • Mar 2006
          • 2778
          Well I'll see how much damage has been done once I figure out how to remove this blasted PSU so I can look inside. Also, you said that this thing takes a notebook cd drive? :s Mine seem to use regular IDE drives.
          Find Nedry!
          • Wizard
            • Mar 2008
            • 2296
            Didn't say what kind of form factor, mine is SFF version of GX150.
            Is the back covered in plastic, or is there a catch in the chassis near PSU?
            By the way, you can test run with a ATX PSU in these GX150.
            Cheers, Wizard
            • Scenic
              o.O
              • Sep 2007
              • 2642
              @ pentium: there are two versions of Optiplex GX150's...
              SFF (with notebook optical drive)
              "normal" tower..
              • pentium
                • Mar 2006
                • 2778
                I have the SFF however it uses regular CD and floppy drives (though that does not matter here).
                Find Nedry!
                • pentium
                  • Mar 2006
                  • 2778
                  Can anyone help figure out how t get the %$^@#ing PSU out? I can't seem to figure out how to remove it. I'm also trying to remove the side skin to look for screws but I can't get that off either.
                  Find Nedry!
                  • Wizard
                    • Mar 2008
                    • 2296
                    I have a question does PSU rattles in it's place if you wiggle, pull/push in and out as if it like it was only trapped without any screws?
                    All the Dell machines SFF machines I have or had were kept in place with a catch. No screw.
                    Cheers, Wizard
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      The correct instructions are right here:
                      https://www.badcaps.net/forum/showpo...84&postcount=2
                      Or you could just scroll up....
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        There are actually 3 GX150 form factors.
                        SFF, Small Desktop, and Tower.
                        - Dr Seuss
                        • pentium
                          • Mar 2006
                          • 2778
                          There is no green lever or tab. From the sides I can see, there is nothing holding it in place.
                          Screw this. I'm going to tear the whole damn system down and find out how the hell you remove this PSU.
                          EDIT:
                          Turns out this is held in place by a little latch like mentioned but it was not even clearly marked and it was jammed until I took the skin off and cleaned out a few pieces of wood that were in the system (this apparently came from a wood shop).
                          I'm looking at teh caps now.
                          Find Nedry!
                          • pentium
                            • Mar 2006
                            • 2778
                            Well the first one had two large Teapos for the primary caps and the secondaries were Nichicons and Ltec caps. None were bulging but I can't seem to figure out how to manually start the PSU up yet when not pluged into the system so I'll have to check the pinout.
                            The other PSU that was squealing also had two Teapo primaries but all the secondaries were Ltec. Plugging it in while disconnected gave me a constant squeal and again the caps were not bulging. Manually starting it also gave no response.
                            It's also to note that both PSUs were made in early 2001.
                            Find Nedry!
                            • Wizard
                              • Mar 2008
                              • 2296
                              Slap on the forehead.
                              Now, DID you try the mainboards with a ATX PSU?, pin out is same.
                              Cheers, Wizard
                              • pentium
                                • Mar 2006
                                • 2778
                                Say that again? This dell motherboard is 100% compatible with an off-the-shelf ATX PSU?
                                Find Nedry!
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Topcat, I hate this damn editing time limit.
                                  Anyways, trying a spare ATX PSU did work and the system POSTed and booted up into Windows NT. So this means that the PSUs are the problem and I now have two more systems to fix and setup for Folding@Home.
                                  Find Nedry!
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    You'd better double check that with Dell<->P3.
                                    Some are, some aren't.
                                    With P4-up you are okay that way.
                                    - Dr Seuss
                                    • Wizard
                                      • Mar 2008
                                      • 2296
                                      I have checked. It is with the newer P3 like in GX150.
                                      Because, I have a dimension 8300 and GX150, both slots and hook style boards and same mainboard trays, 8300 is a P4 and GX150 is P3 and share same chassis designs and I did test run GX150 in the 8300 case before and I did use ATX PSU on that GX150 as well. The 8300 uses ATX PSU.
                                      Cheers, Wizards
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
                                      • master3112
                                        by master3112
                                        07-29-2025, 01:55 PM
                                      • F R 2568
                                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                                        by F R 2568
                                        Hello all,
                                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                        If the laptop is only connected to the AC adapter (battery removed):
                                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                        The power/battery...
                                        01-08-2025, 05:45 AM
                                      • diamon
                                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                        by diamon
                                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                        Pictures of these boards:
                                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                        Dell...
                                        02-28-2024, 12:51 PM
