Rubycon ZLQ is ok for computer power supply 5 volt rail
    • Jul 2011
    • 6059
    I am recapping a computer power supply ( this one I posted a while back https://www.badcaps.net/forum/showth...ht=Sam_sam_sam )
    and having a problem with the size diameter is a 8 mm but a 10 mm would fit but it will be tight fit and how tall it is not a problem
    I could put in a 10 volt one in but this more for information more than anything
    I think I use to have some 8 mm ones but I used them all and I can find any more of them
    8 mm diameter would be better but I can not find any at all with this value
    With low ESR values FR FC KY KZE or any other ones that I have used before
    3300@ 6.3 and 10 volts 8 mm is what is in there now the one that is in it now is a Crapon and has pop it’s top
    • 31161
    Re: Rubycon ZLQ is ok for computer power supply 5 volt rail
    i used to replace those with pana FK series
    but maybe the new FS series has the right part.
    • mockingbird
      • Dec 2008
      • 5484
      If you want 6.3V and 3300uF you will have to use a 10mm... ZLQ only has 2200uF in 8mm.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
        I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
        I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
        I used a four USB outlet and electrical plate that is made for...
        08-03-2024, 07:54 PM
        After all of...
        07-13-2024, 08:14 PM
        I am in need of a 21 volt switching power supply with at least 5 amp capacity
        I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
        I would rather not have to use a buck converter to get the voltage that I need
        So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
        I googled for a 21 volt switching power supply and did not find very much information for switching power supply...
        02-19-2023, 05:47 PM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
