TV SMPS BN44-00473A keeps turn on and off
  • sn4k3
    • Oct 2016
    • 68
    • Portugal
    I have a BN44-00473A from a TV, the voltage output is not fixed, the psu keep turn on and off or is trying to turn on, but due some problem it can't mantain and keep reset. Every three seconds voltage rise about 5V to 12V (on B12V line) but my meter is not fast enought to cath that voltage spike because it drop to 0V almost instantly. I can hear a fast click sound every time when voltage rise, maybe from a relay or switching noise. The psu is able to light up the LCD backlight at that rise moment, like an instant flash. Same happen with 5V Line.
    High DC Voltages also variate from 160V to 140V at that moment but never drop to 0V
    I have no experience with SMPS boards but i test all caps and they are good, visual inspect with microscope seens good and new, no signs of damage.
    I also have the datasheet, if someone can give me some guideness would be cool as i don't have experience troubleshooting this modules but i would like to have.
    PS: Main board had a short under CPU which i already replaced and is fixed now. Maybe the SMPS killed the main board with that unstable voltage?
    All measurements was made only with SMPS connected to AC without any other conections to modules
    Regards
    Re: TV SMPS BN44-00473A keeps turn on and off
    It sounds like you have problem in the STBY power supply (A5V) section.
    This board is know for having bad connections on those rivet through hole solder pads, especially on the transformer's leg.
    • sn4k3
      • Oct 2016
      • 68
      • Portugal
      Can you advice what components i should check?
      I have measure all TS801S legs 7 and 8, they are near 0v dc.
      DS853 center leg gives 2.6V min and 5V at spike.
      I have checked all transformer legs and they are good. Why they are bad? The board is single side print and pins go directly to the hole and soldered at bottom
      Is there any point on the board i can inject 13V or 5V to check if is a hot or cold problem?
        Those boards are know for bad solder joints, if you inspect with magnifying glass you will see ring developed around the solder joints.
        So right now you A5V power supply is swinging high and low?
        "I have measure all TS801S legs 7 and 8, they are near 0v dc." those two pins are high frequency AC output, no DC.
        Startup/running cap CS802 should be check for capacitance and ESR, or just replace it. DS804 needs checking.
        CS855 has good capacitance and low ESR?
        Snubber diode DS803 also need to be check.
        Right now A5V power supply section must be repaired first.
        • sn4k3
          • Oct 2016
          • 68
          • Portugal
          Yes i can see the ring under microscope, i have resolder the joints just in case.
          CS802: 25.21uF, Vloss: 0.7%, ESR:0.11Ohm
          CS855: 604.4uF, Vloss: 1.2%, ESR:0.00Ohm
          DS804: 0.5153V (Voltage Drop)
          DS803: 0.4740V (Voltage Drop)
          DS853: 0.2427V (Voltage Drop)
          Diodes was tested on board, should i remove them to better test?
          • sn4k3
            • Oct 2016
            • 68
            • Portugal
            Voltage across + and - BD801S is 325VDC
            Fuse FP802S is rated at 250V, 325VDC messured, and not blown, why?
              "Fuse FP802S is rated at 250V, 325VDC messured, and not blown, why?"
              Are you saying that you measure the DC Voltage between the two ends of the fuse and it shows 325VDC???
              If that is the case, the fuse has open circuit.
              • sn4k3
                • Oct 2016
                • 68
                • Portugal
                No, i put the negative lead on terminal (-) of BD801S and positive lead on fuse, tested both sides and they are 325VDC. As i told fuse is good, i test first for continuity, not open. I also tested with two different multimeters just to discard any error from equipment, both show same voltage
                  I am just trying to understand your statement regarding to the Voltage reading on the fuse.
                  "CS855: 604.4uF, Vloss: 1.2%, ESR:0.00Ohm" That is very odd capacitance value and ESR of 000 Ohms. What is the capacitance value as printed on the cap?
                  • sn4k3
                    • Oct 2016
                    • 68
                    • Portugal
                    Well i'm just following the schemantic from PDF, as i can see the AC voltage get rectified to DC at BD801S after that the positive side pass the diodes DP802 and DP803 and go directly to the fuse (FP802S T2AL/250V), thats why i have checked, fuse is rated at 250V and 325V is passing there.
                    CS855 spec: 560uF 25V
                    I tested the caps using this tool: https://www.banggood.com/DANIU-3_5in...p-1083042.html
                    Might have a small error due cheap equipment but when testing with a good capacitance meter the results doesn't vary that much and this give the ESR value too
                    • Thushara Wijesingha
                      • Oct 2020
                      • Sri Lanka
                      Regards
                      I had same issue with my SMPS. I replaced ICM 801. and capacitors around the IC. It's working smoothly now.
                      • pajdek
                        Lenovo Y700-17ISK turn on and off
                        by pajdek
                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                        09-20-2023, 02:49 AM
                      • RdeveLabs
                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                        by RdeveLabs
                        To all the members here...
                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                        05-05-2025, 04:59 AM
                      • robante15
                        Acer Aspire 4520 won't turn on after reboot
                        by robante15
                        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                        If I remove the...
                        04-06-2024, 06:50 PM
                      • masoksian
                        Dell latitude e7470 not turn on .power buton on off and Run Power problem
                        by masoksian
                        I am dealing with the problem of turning on and off my Dell e7470 notebook.
                        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                        The system does not turn on, there is no post.
                        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                        The problem continues in the same way.
                        I tried to turn on the Fn key, nothing came to the screen....
                        02-15-2025, 12:08 PM
                      • dqtech
                        lenovo x240 nm-a091 wont turn on
                        by dqtech
                        i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                        board number VIUX1 NM-A091 REV:1.0...
                        02-07-2024, 01:57 AM
