Dell PSU H240AS
  • midibob
    • Nov 2008
    • 285
    Dell PSU H240AS
    I've been asked to look at one of these that was dead.
    On opening I've found that R21 (1R) was burnt and open cct and IC21 had exploded (TNY280).
    The snubber cap (C25) is original and will need upgrading to a 2KV one, as has been suggested by others.
    All the main FETs and diodes appear to be OK as does the SMD components. I'm unable to find a schematic for this model to delve any deeper at present. I've removed the high voltage cap and it measures 130uF instead of 150uF although it's ESR is still very low. No bulging or leaking caps are evident but that's no guarantee they are OK of course.
    I'm probably going to re-cap it anyway to get rid of all those 'elite' caps.
    Does anyone have a schematic so I can investigate why IC21 blew up. I'm not comfortable just swapping parts and crossing fingers.
    Cheers
    Bob
    • 31048
    Re: Dell PSU H240AS
    pretty safe to say that if there was a schem we would have found it - given how these like to go boom.
    • midibob
      • Nov 2008
      • 285
      Re: Dell PSU H240AS
      Yes, that's what I was afraid off.
      It's probably going to be a case of new bits then firing it up on the rheostat and see what happens.
      Oddly enough nobody has mentioned having the fault of IC21 blowing up, plenty of the main FET and snubber network plus the collateral damage that goes with it.
      I'm sure I'm not the first to have it?
        • 31048
        Re: Dell PSU H240AS
        get the datasheet on the i.c. - chances are the psu users the example schematic.
        btw, when you reassemble it - make sure the fan works.
        i had a few where the wire broke under the insulation from all the pulling around at the pointless crimp terminals.
        replaced the crimp-pins with a regular 2.54mm fan connector on those.
        • midibob
          • Nov 2008
          • 285
          Re: Dell PSU H240AS
          Yep, that's a good idea about the fan. I did notice the wires might start to fracture with the fan flopping around.
          Horrible design to work with and as you've probably guessed it's not a commercial repair so I don't mind spending my spare time on it.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Re: Dell PSU H240AS
            Look for a small moderate value (maybe 22uF-100uF) electrolytic cap in the circuit around that Standby regulator. It is a part that is stressed some, and can leave the Standby regulator in a shut-down-and-retry loop that can cause it to get hot. A shorted rectifier on one of the outputs could cause ugly things.
            PeteS in CA
              • 31048
              Re: Dell PSU H240AS
              the problem with the standby supply is there is a lot of silicone poured over that area.
              a lot of digging needs to be done - often literally!
              • midibob
                • Nov 2008
                • 285
                Re: Dell PSU H240AS
                Thanks for the replies guys.
                I've now removed all the caps (after a lot of digging) and they appear to test fine both in value and ESR. Probably still re-cap anyway being as they are all out.
                All mosfets and power diodes removed and they all look good too.
                I think it's going to be a case of rebuild and see what happens.
                • midibob
                  • Nov 2008
                  • 285
                  Re: Dell PSU H240AS
                  Well, the plot thickens.
                  Firstly I noticed this...
                  C6 isn't on it's pads. Is this a mod or has it slipped during soldering?
                  I'm still trying to draw the cct out but it looks like this is on the feedback cct from the opto.
                  Also I've come a cross a thread about TNY280's failing for no reason in large numbers.
                  https://ac-dc.power.com/forum/low-po...4/tny-problem/
                  Those two horrible words are cropping up again together ie conterfeit and China. Let's hope not.
                    • 31048
                    Re: Dell PSU H240AS
                    most parts from china arent conterfeit, they are surplus from factory production lines.
                    • midibob
                      • Nov 2008
                      • 285
                      Re: Dell PSU H240AS
                      Time for an update on this one.
                      Once the TNY280 was replaced along with it's series flameproof resistor and rebuilt, power was applied via a 40W bulb. The bulb would pulse bright and dim but the PSU wouldn't stay running. At least it looked like nothing was going to blow up. Replacing the bulb with a 100W bulb and it then ran OK with all output voltages correct.
                      With full power applied everything looked good and it powerd the PC up OK. I'll let it run for a while to make sure it's stable but it's a mystery why the chip exploded?
                      I've now got another 3 to look at so it'll be interesting to see if it's the same issue.
                        • 31048
                        Re: Dell PSU H240AS
                        getting interesting.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Re: Dell PSU H240AS
                          I wonder if it's the snubber network causing this. Try different loads on the 5VSB. If it blows up again, the snubber definitely might have something to do with that.
                          • midibob
                            • Nov 2008
                            • 285
                            Re: Dell PSU H240AS
                            I have changed out the 1kv cap on the snubber for a 2kv as suggested in other threads so we'll see what happens after it's been running for a while.
                            The next one on the bench also had the 1R resistor burnt and although the TNY280 hadn't exploded this time it was measuring about 900 Ohms across most of the pins.
                            With a new resistor and IC it fired up and again appears to run OK. The snubber cap was upgraded too.
                            The last one was different and this fired up but shutdown approx 7 secs later? The series lamp also glowed slightly with no load whereas the other two didn't. Could be something on the secondary side that's going amiss so further investigation is needed. All the secondary voltages do appear to be correct though?
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Re: Dell PSU H240AS
                              Sounds like something is eating power when it shouldn't.
                              I'd check the snubber diode first. If it is shorted, it will conduct both during the TNY IC's On and Off cycles, which can in turn make the TNY IC overheat and go into thermal shutdown protection.
                                • 31048
                                Re: Dell PSU H240AS
                                check ceramic caps too.
                                • midibob
                                  • Nov 2008
                                  • 285
                                  Re: Dell PSU H240AS
                                  Will do. Thanks chaps. I'll report back when I've checked it out.
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • master3112
                                    by master3112
                                    07-29-2025, 01:55 PM
                                  • F R 2568
                                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                                    by F R 2568
                                    Hello all,
                                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                    If the laptop is only connected to the AC adapter (battery removed):
                                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                    The power/battery...
                                    01-08-2025, 05:45 AM
                                  • diamon
                                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                    by diamon
                                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                    Pictures of these boards:
                                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                    Dell...
                                    02-28-2024, 12:51 PM
                                  • lalle-
                                    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                    by lalle-
                                    Hello!
                                    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                    08-11-2024, 02:01 PM
