ATX PSU +5VSB too high
  • Pierre95
    • Feb 2016
    • 65
    • France
    I have an LC-B300ATX. It is based on the not very usual 2003 IC PWM controller for which I have difficulties in finding datasheet. Recently I have noticed +5VSB being too high. When the PSU is cold, +5VSB starts as high as 10V then drops slowly (within minutes) to 6,6V for keeping that value, which is not acceptable.
    So far as I have seen, the schematics is similar to the 250W version found here: http://danyk.cz/s_atx04a.png.
    I have some basic questions about the way +5VSB is actually generated:
    1) Does the +5VSB use a standalone 2 transistors oscillator for switching voltage generation or is it derived from the PWM controller output?
    2) Is there some feedback to insure voltage stays as close as possible to +5V or is it unregulated?
    3) What is the optocoupler labeled "COSMO" for? Is it a feedback for regulating +5VSB by adjusting the bias current of Q4?
    I've noticed C18 is getting really hot and keeping a finger at its end is barely sustainable. But it may be normal temperature as this capacitor constantly gets the pulsed voltage issued at D7's cathode? D7 is also hot. Same for the COSMO optocoupler.
    May be Q3, Q4 or both transistors are damaged, but I made oscilloscope recordings of the voltage at D7's anode and I can see near square alternating waveform voltage.
    So which component should I check first?
    Thanks a lot,
    Pierre
    • 31015
    Re: ATX PSU +5VSB too high
    the caps on the 5vstandby are bad.
    • Pierre95
      • Feb 2016
      • 65
      • France
      Which can explain the variation in voltage as the capacitor warms up...
      You mean the 1000uF C18 capacitor connected between D7 cathode and GND I presume?
        • 31015
        post some foto's
        • Pierre95
          • Feb 2016
          • 65
          • France
          C18 capacitor:
            • 31015
            foto's of the actual psu i meant.
            btw, post the whole schematic too - i want to see where that standby voltage goes as it goes up off the image.
            • Pierre95
              • Feb 2016
              • 65
              • France
              OK, here it is:
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Yeah likely C18 is bad, due to ESR it's gotten worse and worse until it finally fries itself. If you have an oscilloscope you can check the voltage across it, probably spiking like mad as the ESR is so bad it can't smooth out the voltage anymore.
                There is regulation - the feedback loop through the R30-R27 divider, U2 TL431 reference and the U1 optoisolator is the sole prevention to make sure 5VSB doesn't get too high, but there's no other secondary protection from the "2-transistor" oscillator to generate standby damaging voltage...
                It's unfortunate - the 2003 chip seems actually fairly common, just that the datasheet isn't...
                • PeteS in CA
                  • Aug 2005
                  • 3579
                  • USA, Unsure of Planet
                  The Standby section is a self-oscillating discontinuous flyback circuit. The switch MOSFET Q3, once on, can be shut off either by the voltage across R4, the 1.8 ohm resistor in the Source circuit turning on Q4 or by the optocoupler U1 turning on Q4. Once the energy stored by the primary is dumped into the secondary circuit (filtered by C18), the remaining energy in the primary leakage inductance will turn Q3 on, for the start of another cycle of charging the primary. Optocoupler U1 plus the TL431, U2, are the feedback loop. The way the TL431 is configured, it's an opamp with the internal 2.5V reference connected internally to one input, and the sample of the output voltage fed to the other input (the Ref pin).
                  So C18 is critical and very stressed in a discontinuous flyback design, and C8 is also important (and stressed), filtering the V(cc) for the transistor section of the optocoupler. C11 is a compensation cap, not particularly stressed, but still important. I'd replace all 3: C18 and C8 with Nichicon PW or similar; C11 with a 105C rated general purpose part from a good manufacturer.
                  The discontinuous flyback circuit of that basic design has been around since the late 1970s. It was used in the Apple II+ power supply and in Boschert's OL25 family, with bipolar transistor switch devices. In the early 80s Boschert refined and optimized the design and had a whole series of models ranging from 25 or 30 watts up to 165 watts.
                  PeteS in CA
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Yes C8 seems to be your critical cap.
                    When it goes bad in these designs the 5VSB goes high.
                    So if you wan to fix it be sure the replace ALL small electrolytics!
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      So is that just like the Bestec 250-E?
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Pierre95
                        • Feb 2016
                        • 65
                        • France
                        I would like to thank all of for your answers which were very helpfull.
                        C8 was the faulty part. I now get 5,08V at +5VSB after C8 replacement. C18 might have been the cause of the failure but seeing a ripple-free 6,6V +5VSB, made me think C18's filtering performs well and the origin is actually before D7, so most likely in the primary of the transformer.
                        But without your help I would probably not replace C8 as a priority.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          RJARRRPCGP: Do you mean Bestec ATX-250 revision 12E?
                          Here is some mods to make it safer:
                          https://www.badcaps.net/forum/showthread.php?t=6680
                          https://www.badcaps.net/forum/showthread.php?t=34860
                          And for fun
                          http://www.jonnyguru.com/modules.php...Story&reid=154
                          Yes it's failure is the same as the LC-B300ATX PSU in this thread.
                          In my opinion the only way to make them safe is to replace the whole 5VSB supply with for example a DM311 IC.
                          But to each his own
                            • 31015
                            you should be changing all the caps, or atleast everything under 470uf
                            • PeteS in CA
                              • Aug 2005
                              • 3579
                              Discontinuous flyback circuits look simple, but really are not. And many components are very stressed. The big attraction is the low component count (e.g. Boschert's continuous flyback OL50 had 140-150 components; the discontinuous flyback XL50 that replaced it had about 90). The design also saves PCB space because the output transformer also serves as the "output" inductor. The core is gapped so it can store energy.
                              In that circuit, even though it's "only" filtering the V(cc) for the optocoupler's transistor, C8 is an output capacitor. With C8 bad, the V(cc) was unfiltered pulses and the opto's transistor probably had very little collector voltage at the time when the TL431 tried to turn off the switch MOSFET. So the switch MOSFET was being turned off by the power limit resistor in the MOSFET's Source circuit. Thus the output voltage was not being regulated. In Boschert's designs they always had an OVP SCR crowbar on the +5V, regardless of the topology. If the +5V rose to about 5.5 volts, the SCR fired, shorting the +5V and tripping current limit or power limit.
                              PeteS in CA
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Yes.
                                Arc A770 16 GB
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  You mean the ATX-250-12E?... Yup.
                                  Pretty much every Deer / L&C from the early 2000's to the late 2000's used that 2-transistor 5VSB design, as did many cheap PSUs in the early 2000's as well. However, with the Bestec ATX-250-12E and the L&C PSUs, they had that critical cap, C8, which was crucial for the 5VSB regulation. And with the Bestec ATX-250-12E, it's even worse, because that cap also filters power going into the UC384x PWM controller on the primary, so that cap sees even more stress than the L&C designs.
                                  That said, there are 2-transistor 5VSB designs that don't have an electrolytic "critical" cap in the circuit. Those designs tend to be a lot more stable, and in fact, I don't ever recall running into one that had 5VSB overshoot/over-voltage problems.
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1865
                                    • Romania
                                    I have an idea: can we bypass that critical capacitor from the traces? Or is there some more rework to do that? (without needing a DM311 circuit)
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    Core i5-3470 3.60GHz
                                    16GB DDR3-1600
                                    Samsung SH-224AB DVD-RW
                                    Delux MG760 case
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3579
                                      If protecting the MB against the 5VSB going out of control, why not wire in an SCR crowbar circuit - a 4.7V or 5.1V zener, a 5-10A SCR, and a resistor across the gate-cathode so a little leakage current from the zener doesn't fire the SCR.
                                      PeteS in CA
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        It's a lot more work than that. Basically, the whole 2-transistor 5VSB has to be designed to work without that critical cap. I've done a quick comparison on a circuit like that and one with a critical cap, and they differ in component values and layout quite a bit. Essentially, you would have to change more than half of the components in the 5VSB circuit to achieve that - at which point, you might as well go with a DM311 or other similar offline chip.
                                        If I have more time later in the summer, I will try to copy the 5VSB circuit in my 300W Macron Power MPT-301 PSU. So far, I have posted here on BCN at least three or four 5VSB 2-transistor circuits, but they are all with a critical cap (and three are CWT designs, so they are very similar.)
                                        But the bottom line really is: if you use good quality caps for the output and the critical cap, you won't have any issues with the PSU up to 10 years, if not longer.
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                          by sam_sam_sam
                                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                          02-04-2025, 08:08 PM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • harp
                                          high voltage high resistance marking resistor
                                          by harp
                                          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                          08-26-2024, 01:42 PM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
