Tagan TG480-U01 480W ATX PSU
  • BeetleJuice
    • Sep 2014
    • Greece
    #81
    Re: Tagan TG480-U01 480W ATX PSU
    Originally posted by ep9es
    I'll look at the characteristics of the other capacitors (fortunately in this FSP psu are few).
    This thread is about Tagan TG480-U01, and I have one broken.
    When I took and opened, I thought: "Wow, it's heavier than the FSP and (for me) very well built. It seems semi-passive!! "
    I had read some people say that Topower not be in the highest level psu's, but I think is enough.
    In the Tagan psu I found these caps:
    - PFC board: broken 1x Fuhjyyu MK 22uf 400v 85ºC
    - Primary: OK 2x Panasonic 680uf 200v 85ºC
    - Secondary: want to replace
    2x Fuhjyyu P7 1000uf 10v 105ºC
    2x Fuhjyyu P10 4700uf 10v 105ºC
    2x Fuhjyyu TMR AA10 2200uf 10v 105ºC
    1x Fuhjyyu TMR AA09 3300uf 16v 105ºC
    2x Fuhjyyu P7 470uf 16v 105ºC
    Apart from these, I see more little capacitors, they seem ok, not bloated and are difficult to access.
    Seeing the specifications of these capacitors I think I can't use repeated capacitors because they have different capacitances .
    That is, I think I'll have to replace them with others with the same capacity and perhaps higher voltage.
    Behemot, your eshop is HV World, no??
    did you find the value of resistor 34?
    i have the same psu and i cant find the value of the resistor...
    can we find a circuit diagram?
    • ep9es
      • Jul 2015
      • 24
      • Spain
      #82
      R34 in my board is burnt.
      But I found over internet, a photo from a similar Topower.
      Can you upload a photo from yours?
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • chth96
        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
        by chth96
        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
        Since then, This AC/DC adaptor have been out of order.
        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
        And Is there any possibility that it will suddenly explode as well as to be out...
        12-03-2023, 04:40 AM
      • badcap111
        Xiaomi mi 9T missing resistor
        by badcap111
        Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
        I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
        Is...
        08-07-2023, 10:42 AM
