Altec MX6021
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Re: Altec MX6021
    The light bulb trick only works with the old incandecent tye light bulb. It doesn't work with CCFL's or LED type bulbs. The lamp is connected in series on the phase. If the bulb is hooked up in parallel like normal, it will not work as intended either. In order to determent if there still is a short on the primary side of the PSU, did you actually test the output on the secondary to see if there is any voltage coming out?
    That little IC is the PWM that connects to the gate drive circuit to the FET. IF the FET was shorted to the gate, then you would have to inspect he gate drive circuit closely and probably replace the PWM. All you can do here is to check all components of the gate drive circuit, check the FET itself, do the lamp test, if there is still a problem, replace the PWM. I use a oscilloscope and a isolation transformer to see if the FET is switching or not. You can check with a DMM if the PWM is getting any power. The PWM also has protection built in, so you'd have to download the spec sheet and measure voltages etc.
    • zerbino
      • 11
      • Russian Federation
      Re: Altec MX6021
      Series) Lamp with nichrome coil)
      Thanks, i will try)
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Re: Altec MX6021
        Yeah, the old 100W glowing wire type A19 light bulb. Wire it up like in the picture on the phase wire.
        • zerbino
          • 11
          Re: Altec MX6021
          as i told at 20 post it give light permanently. Unfortunately my knowledge is not enough except to replace U1.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Re: Altec MX6021
            see if there is a short at the main filter cap
            • Behemot
              • 4845
              • CZ
              #26
              Re: Altec MX6021
              Be sure it is discharged first. Altough a meter will indeed show charged cap as shorted, a one without input protection will most likely do that as the last thing ever
              • naveenbedre
                • Oct 2013
                • in
                #27
                Re: Altec MX6021
                What is U1 specification number part number
                • zerbino
                  • 11
                  #28
                  Re: Altec MX6021
                  As i understand U1 is NCP1351D https://cdn.badcaps-static.com/pdfs/...f4ba3fa041.pdf may be version D (Latch not connected on board)
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Re: Altec MX6021
                    Does the DBT bulb turn on and stay lit if the transistor isn't in the board?
                    If so - look into diode or main capacitor shorts.
                    if not, then suspect feedback, U1, transformer, or output.
                    If U1 fried, quite possibly it would fry the transistor again...
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #30
                      Re: Altec MX6021
                      Indeed. When you have a switching mosfet short circuit, connected to a controller chip with low (under 100 ohm) or no gate resistance, it is recommended to replace both switching transistor and controller chip together. This is valid for all switching power supplies.
                      I once blew 2 sets of mosfets and 3 charge control chips in an Acer laptop which had a no battery charging fault. The final time i replaced both the mosfets and the charge control chip and everything worked fine then.
                      A working TV? How boring!
                      • naveenbedre
                        • Oct 2013
                        • in
                        #31
                        Re: Altec MX6021
                        U1 1351D PATM can i replace with UC3842
                          master hoarder
                          • May 2008
                          • 12175
                          #32
                          Re: Altec MX6021
                          No.
                          They have different pinout and made for different circuit.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5065
                            • New Zealand
                            #33
                            Re: Altec MX6021
                            Get the NCP1351D from UTSource, that's probably your best option for cheap. https://www.utsource.net/sch/NCP1351D
                            MOSFET blows up and takes out the controller, usually.
                            I'd suspect the glue caused the MOSFET failure. Remove all of it. Heating it with hot air makes it easier to get off.
                            -David VanHorn
                            • zerbino
                              • 11
                              #34
                              Re: Altec MX6021
                              Hello, guys.
                              I personally could not repair the breakdown, so I gave it to the service center. The specialist told me after the repair that he replaced the "some kind of diode" and it all worked. Although before this I replaced 1 transistor near C3, and 4 resistors 1Ohm and a capacitor. But I did not have enough the mind and knowledge to diagnose and understand that there is also a diode out of order. By the way, it was not necessary to replace U1. It was working, as well as the rest of the resistors.
                              Thanks to all.
                              • naveenbedre
                                • Oct 2013
                                • in
                                #35
                                Originally posted by momaka
                                No.
                                Thank you for reply
                                • zerbino
                                  • 11
                                  #36
                                  Re: Altec MX6021
                                  Bought NCP1351D at this place.
                                  • naveenbedre
                                    • Oct 2013
                                    • in
                                    #37
                                    No.
                                    • ant3202
                                      • Jun 2006
                                      • 275
                                      • Singapore
                                      #38
                                      Re: Altec MX6021
                                      Ahhh finally someone has a decent pictures, seems this power board is failing.....
                                      my infineon mosfet seems to be shorted, all beeps ....
                                      • lincolnkorg
                                        • Jun 2018
                                        • 10
                                        • India
                                        #39
                                        Re: Altec MX6021
                                        Has anyone had success in repairing the power supply? I am a hobbyist, got a unit from a friend to fix. Someone has already tried working on the board earlier.
                                        So far from what I've tested, the fuse, rectifier diodes, mosfet, the 4 SMD resistors at the bottom, filter cap (bulged on the top) seems to be the problem. Do zener diodes need to be replaced? Does anyone have all the part numbers? What else could have failed along the way.
                                        I also noticed that C25 was mounted in an angel, wondering if this was tampered by the previous person who tried to fix it. The polarity of C25 is reversed (smaller reading on diode test on one side and bigger reading when the probes are reversed, not sure if this is the right way to test) when compared to C24. Does that matter? Should I reverse C25 to match C24?
                                        Any insights would be of great help.
                                        I haven't tried to power the unit yet, the area around the fuse looks a little burnt.
                                        Thanks in advance.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5065
                                          • New Zealand
                                          #40
                                          Re: Altec MX6021
                                          Can you post photos showing these parts especially C25?
                                          You can't test capacitors in diode test mode except for a short so the results are meaningless.
                                          -David VanHorn
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • brightest_z
                                            Hot Air Blew Away Resistors Near Bios
                                            by brightest_z
                                            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                            Does anyone with more knowledge, and experience than I, know if this is the case?
                                            12-11-2024, 08:34 PM
                                            Multifix 425-01 and 450-01 Rework Flux Datasheet
                                            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                            - No Clean Formulations
                                            - Low residue
                                            - Range of activity to deal with different component solderability
                                            - Halide free
                                            - Suitable for dispensing
                                            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                            Both products are supplied in syringes or cartridges for application by dispensing....
                                            10-07-2024, 06:02 AM
                                          • jinu_j
                                            LED driver circuit. Burnt Resistors
                                            by jinu_j
                                            Hi Folks
                                            This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                                            Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                                            But i have some queries on this circuit
                                            1. The resistors that burnt to crisp...
                                            08-26-2020, 01:24 AM
                                          • vikivng
                                            guys..i need help with this lcd display used on ebikes pls.
                                            by vikivng
                                            This is an lcd display used on ebikes.
                                            long story short, there was condensation inside the unit.
                                            I opened it and thoroughly cleaned the pcb with isopryl.
                                            The board had no visible corosion.
                                            It powered on fine and was tested for an hour or so.
                                            However when connected to the bike,,it did not power on at all.
                                            I took it home and reopened it to take a look. There are no shorts based on MY testing.
                                            However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                                            09-16-2025, 12:56 PM
