4 pin vs 8 pin 12V plug on PSU
  • travistee
    • Sep 2008
    • 68
    I have an PSU with a 4pin plug.
    My mobo can take either 4 pin or 8 pin. It has a cover over the first 4 pins that can be removed if you have the 8 pin psu plug.
    Is there any reason I should get a PSU with the 8 pin plug?
  • Wizard
    • Mar 2008
    • 2296
    Re: 4 pin vs 8 pin 12V plug on PSU
    Recommended.
    C2D cpus can exceed 65W and some models can go over that. Athlon high speed ones (above 2.6GHz often is 65 and some over 3.0GHz easily exceed 125W.
    Cheers, Wizard
    • travistee
      • Sep 2008
      • 68
      Can you explain that in terms of what the limitations of the 4 pin plug are?
      • jpdoe
        • May 2007
        • 237
        In order to feed the CPU you need to move electrical current from the PSU to the motherboard. Each cable can conduct so much amperage. Cables have internal resistance. Connectors have contact resistance, and each time you unplug it and plug it again it tends to go up.
        As the CPU power requirements increase, so does the current needed to feed it. So you need more motherboard power connectors to keep things under control.
        Maybe you've heard horror stories where the PSU connector plastic melted and became a constant fixture of the motherboard? The reason is heat emitted by the metal plugs, that coudn't stand the amount of electric current running through them. A few connectors and cables more could have prevented that from happening.
        The bottom line is: connectors are there for a reason. If you ignore them, you better understand the consequences. If you have a not so hungry CPU things will be OK. If you have a super duper quadcore that consumes 125W things will get toasty in a short time.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          The only difference between 4 pin and 8 pin is that 8 pin has more wires and more pins and so can handle more current.
          The limitations are:
          The current capacity of the wires.
          The current capacity of the pins in the connectors.
          The current capacity of the traces on the board.
          When they want to more more amps than 4 pins or wires can move they add more wires and pins.
          [Usually]
          All the +12v in the 4 pin are connected together on the board.
          - As are all the grounds.
          [Usually]
          All the +12v in the 8 pin are connected together on the board.
          Mann-Made Global Warming.
          - Dr Seuss
          • stevo1210
            • Oct 2006
            • 4156
            I have an Asus P5K-E WIFI AP motherboard (the one in my sig) and I'm using a Thermaltake 430W TR2 PSU with a 4 pin +12V cable. Should I be concerned as well?
            So far It's been running for nearly a year and I haven't experienced any issues yet and I think the connector is still OK from my routine checks last month.
            Thanks.
            Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
            • Wizard
              • Mar 2008
              • 2296
              D920 is 95W cpu, that is bit concerning with 4 pin plug. Best to find a solution to get 8 pin plug hooked up or get another PSU. Seasonic is good make and quieter.
              Cheers, Wizard
              • travistee
                • Sep 2008
                • 68
                I used my D 820 in an Asus p5p800se for a few years until the mobo died.
                My PSU only had the 4pin plug. I think at that time (2005), the PSUs all came with 4 pin 12V ( I think?).
                I asked the question because I'm planning to upgrade to a quad core.
                • Wizard
                  • Mar 2008
                  • 2296
                  Which Quad? Lot of them tend to be 125W
                  Cheers, Wizard
                  • travistee
                    • Sep 2008
                    • 68
                    Q9300
                    • bgavin
                      • Jan 2007
                      • 1355
                      I have seen recommendations against using only four pins of an ESP-12V mobo connector. It is possible they are using smaller land patterns on this board, expecting the load to be distributed across 8 pins.
                      One is probably safer to buy a 4-to-8 adapter. Use the 4-ping PSU connector, and the adapter to split those lines to all 8 mobo pins.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Sometimes the 4-pin plugs will arc/burn in the contacts (pins) if they are pulling too much current.
                        Usually if there is a problem the pins are the weakest link.
                        So - If you are concerned then do something to get more pins in there to handle the current.
                        If you have 4-pin PSU and 8-pin MoBo then one of those adapters is at least some protection.
                        You might still burn/arc at the 4-pin end but it won't damage the connector on the Mobo too, just the one in the adapter.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          bgavin is correct.
                          If mobo manual specifies to not use a 4-pin then don't use one.
                          Traces on mobo may not be in common and may burn-out.
                          You can check with ohm meter or looking at the solder joints.
                          If all 12v and all grounds in the mobo 8-pin plug are in common then a 4-pin should be okay to use as far as the mobo goes. - If the pins can handle the current.
                          - Dr Seuss
                          • jpdoe
                            • May 2007
                            • 237
                            Man... It sure is interesting to lurk in these forums.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I have seen this (pins not in common) mostly on dual processor boards where 1/2 the 8-pins go to one CPU and the other 1/2 to the other CPU.
                              That doesn't mean they couldn't do something similar on a single CPU board though.
                              - Dr Seuss
                              • stevo1210
                                • Oct 2006
                                • 4156
                                I just read my Asus P5K-E manual and it says I can either use a 4 pin or an 8 pin 12V connector. If I want to use an 8 pin connector, I have to remove the plastic cap covering the 4 other pins. Does this still mean it's OK to use a 4 pin 12V connector?
                                Thanks.
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  I still say not ok especially iwth 95W cpus. Both cpus you have and the future Q9300 is 95W. Get new PSU especially if your is older. Seasonic with 120mm fan is quiet also you will get SATA connectors, PCI-E connectors for the video cards. And wirings are all sleeved. Which is nice.
                                  Nix on 4 to 8 adapters.
                                  I had few ATX connectors burn out. Big job to replace and leaves you with old stuff.
                                  Cheers, Wizard
                                  • bgavin
                                    • Jan 2007
                                    • 1355
                                    I have a 63w P4 going into service on an MSI board with ESP-12V 8-pin connectors. Embedded VGA, single disk. This is a minimal power draw for sure.
                                    I agree with Wizard to avoid using adapters with high current loads. The 8-pin cabling inside the PSU is 8 wires all the way to the board, as it should be with high current.
                                    There are places where Band-Aids are inappropriate and real stitches are required. In my case, my modest 350w PSU with 4-pin ATX12V, into an adapter or straight into the board (if mfgr allows) is a workable Band-Aid. I can't find either Yes or No in the manual, about using a 4-pin cable in the 8-pin jack.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Thanks.
                                      Yes it's okay.
                                      That means the pins are in common.
                                      Cap is just to keep junk out of unused socket.
                                      - Dr Seuss
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Cheers, Wizard
                                        Adapter w/8 pins at MoBo keeps you from burning the pins in the motherboard.
                                        If pins burn it will be in the adapter to PSU connection.
                                        - Easy to fix.
                                        - No broke MoBo.
                                        That was the point.
                                        - Dr Seuss
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • mrsith
                                          Dell G3 17 3779 - no display after mobo replacement
                                          by mrsith
                                          Hi guys,
                                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                          04-30-2023, 05:11 AM
                                        • tartuf
                                          FSP-350GLN(80) not booting mobo properly
                                          by tartuf
                                          Greetings
                                          My old 350W FSP-350GLN(80) PSU was working fine with my current computer for few years(and previously with few other computers as well). Nothing has changed in setup but since last few months I am getting problems while trying to boot PC.
                                          What happens, is that PSU starts and I can hear fans, both PSU, CPU, MOBO and GPU. I can also hear HDD scratching and normal starting sounds. But DVI monitor claims that there is "no signal". Moreover, neither USB mouse nor PS2 keyboard does flash leds like it should do upon boot.
                                          I have to turn PSU switch...
                                          12-23-2022, 10:54 AM
                                        • SluggerB
                                          Ancient Memorex VCR/DVD Combo device with strange display issue
                                          by SluggerB
                                          This is a 14 year old Memorex DVD/VCR Combo.
                                          I got a new LG TV. I pulled the Memorex out to hook it up. it only has composite out, so I go composite to a little composite > HDMI device, then HDMI to the TV.
                                          In VCR mode, it works fine. The display quality is what you would expect, but I can play tapes just fine
                                          In DVD mode is where the issue started. In the main DVD screen, prior to it loading any DVD (or with no DVD even in) I am getting diagonal black lines scrolling diagonally across the screen. These continue even if I play a DVD.
                                          So...
                                          12-10-2021, 08:54 PM
                                        • Ibod
                                          Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                          by Ibod
                                          HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                          With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                          Not sure where to go from here ?
                                          Is the PSU at fault or is the mobo causing the problem
                                          Look forward to any help :-)
                                          If I plug the 24...
                                          02-08-2023, 11:00 AM
