Replacement caps for Tektronix 434 Power supply board.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5064
    • New Zealand
    #161
    Re: Replacement caps for Tektronix 434 Power supply board.
    Is the new Q995 still OK?
    -David VanHorn
    • John McGivern
      • Dec 2013
      • 195
      • uk
      #162
      Yes Q995 ok so is Cr924/5, Q924/5 and C926.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
        After all of...
        07-13-2024, 08:14 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
        by momaka
        03-15-2023, 10:17 PM
