Coolmax unraveling
  • everell
    • Jan 2009
    • 1514
    Coolmax unraveling
    Acquired a dead Coolmax model V-600. Powered it up, and sure enough it was dead. The 5VSB was OK, but everything else was dead. Removed the pc board from the metal box, applied power to start troubleshooting, and everything working OK. Hum....................
    Doing a visual inspection, I found that one end of the pc board was delaminating. That ought to be a quick fix. Just squirt some super glue between the layers and use a couple of clothes pins to hold it together until dry. But.........I began considering that crappy quality pc board material means that it will probably continue delaminating in other areas. NOT acceptable. So I have met my match and decided that this power supply is simply NOT repairable (unless you want to replace the pc board!). So this one will be used for parts.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • CapLeaker
    Leaking Member
    • 8339
    Re: Coolmax unraveling
    I'd do the same thing.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5065
      • New Zealand
      Wow, that's a really crap PCB!
      Looks like heat is the cause of the de-lamination. (Well, that, and rubbish quality glue)
      -David VanHorn
      • everell
        • Jan 2009
        • 1514
        Such delamination reminds me of the Democratic Party!
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          Seeing how the Coolmax is crowded with parts,you'd be able to mod a Raidmax with that - especially since AT-2005B Sun Pros have that main transformer without the center tap.
          Main rig:
          Gigabyte B75M-D3H
          Core i5-3470 3.60GHz
          16GB DDR3-1600
          Samsung SH-224AB DVD-RW
          Delux MG760 case
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            What a bummer! I love those Sun Pro AT-2005B designs. I've probably recapped a dozen of them. Perform well and very silent. Should have some good parts to use!
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Considering they usually don't have too tall heatsinks,you can fit them in any generic 120mm PSU case
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • everell
                • Jan 2009
                • 1514
                It does have a nice case and fan. Perhaps I can find another IMicro to fix the pc board and put it in this case. Wouldn't that confuse the next person to work on it!
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  Oh boy,how much I used to do that.
                  I put a lot of funny stuff in cases. Last one I gave to a friend was a 350W CWT ISO PSU that I crammed (the wires were incredibily thick and stiff) in a 450W Delux (which in turn was a Kissquiet) that was fried. Same goes for two other fried Delux PSUs (a SunPro and the other was an iMicro I think?) except in both cases I used two L&C LC-B450E PSUs. (recapped,of course)I even remember slapping the Premier LC-B450E sticker it had on one .
                  Other works I did:
                  Delux (Sun Pro OEM) - Maxpower/KME - I remember I gave this to my friend who needed it to power a security system camera (12v)
                  Sumvision KY-450ATX - this one was built from both its original casing and another Delux casing.
                  Linkworld LPK2-30 - Eurocase 250X1
                  Intex IT-20F1BC-A 430W - JNC LC-B350ATX
                  and the most recent one? Delux (Sun Pro OEM) - Leadman LP-7700 (w/EI-40 transformer - anybody know where to get some 13009 transistors?)
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • everell
                    • Jan 2009
                    • 1514
                    This is the sticker I would use.
                    • dmill89
                      • Dec 2011
                      • 2534
                      That label comes from this piece of crap, which makes a Sun-Pro or L&C look "top of the line" by comparison:
                      • Drack
                        Yup it's me
                        • Nov 2016
                        • 297
                        • Venezuela
                        That happened to me with an old PSU that came from a Lenovo PC, don't know the manufacturer though.
                        I did the same, took everything I could use and throw everything else out the window
                        • dmill89
                          • Dec 2011
                          • 2534
                          Likely Delta, AcBel, or Lite-On for a Lenovo PSU. Assuming it was the OE PSU and not a cheap replacement, it was likely really old and exposed to allot of heat, none of those OEMs is known for using exceptionally cheap PCBs.
                          • Drack
                            Yup it's me
                            • Nov 2016
                            • 297
                            • Venezuela
                            Yeah, the parts where quality ones and everything was good but because of the bad PCB it would not work all the time or just never after a while lol. The only disappointment was the 20a fast recovery diode but I think it can be useful some day so I kept it,
                            the fan was stuck that's why it died, it was really dusty inside that little case
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              • USA, Unsure of Planet
                              ... So this one will be used for parts.
                              The "Y-caps" on that look like they could be general purpose rather than safety agency approved parts. If they are general purpose parts, don't use them as Y-caps.
                              PeteS in CA
                              • Drack
                                Yup it's me
                                • Nov 2016
                                • 297
                                • Venezuela
                                Ohh my god, it looks like a child cut that PCB with plastic
                                Scissors
                                • dmill89
                                  • Dec 2011
                                  • 2534
                                  Scissors
                                  Yah, that "free with case" OKIA "420W" (I think they added a 0, more like 42W) is by far the worst PSU I've ever personally owned (and by "owned", I mean I immediately took it out of the case it came with and replaced it with something better, I wouldn't even think of powering a PC with that POS).
                                  • Drack
                                    Yup it's me
                                    • Nov 2016
                                    • 297
                                    • Venezuela
                                    The sad part is that 95% of the PSUs people uses are like that (including my p4 PC)
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5065
                                      • New Zealand
                                      Scissors
                                      -David VanHorn
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1866
                                        • Romania
                                        OKIA is good for exploding.
                                        Seriously , I've seen Maxpowers better than that Okia with the same size of PCB. Is that OKIA made by KME? If so,shame on them.
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • k370
                                          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                          by k370
                                          I have a NM-A321 board that is dead, with no power at all.
                                          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                          • +3VALW
                                          • +5VAUX
                                          • 1.2VSUS_PWRGD
                                          • 3VALW_PGD
                                          • 1.05VAUX_PWRGD
                                          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                          09-23-2024, 11:57 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
