Power supply doesn't work on just one motherboard (stumped)
    Re: Power supply doesn't work on just one motherboard (stumped)
    shit replacements will not last.seen many tv psu that were recapped with ebay shit kits that didnt go 6 months.
    Originally posted by Dannyx View Post
    Actually the pictures were taken BEFORE I started messing around with it The caps I put in are new. They may not be brand names, but they SHOULD work....I'm not exactly interested in this thing lasting a life time - I just want it to turn on enough to return it to the guy who brought it in
      Originally posted by kc8adu View Post
      it is possible you plugged it enough to wipe the contacts.
      but i bet this will rear its ugly head again soon.shortly after you declare it "fixed" and return it.
      Definitely not a contact issue, since the volts didn't drop to 0 entirely to signal a bad connection - they fluctuated and tried going up but dropped again, as if too much load was applied.
      Wattevah...
        That could still be bad contacts. I've seen this happen quite a few times with experimental circuits where I got lazy and didn't use proper alligator clips to run power - the voltage on the meter would jump up and down as if my power source was failing (and it wasn't - it was just the poor connections causing the problem).
        So perhaps tighten the pins on that "faulty" PSU, especially the 5VSB wire and ground around it.
        The only other thing I can think of why the "faulty" PSU was acting up is if the motherboard was somehow making the 5VSB oscillate due to unstable loading. But I think the chances of that are very slim (probably close to impossible).
