DC boost converter max power ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: DC boost converter max power ?
    I got 234mV on Vo for 47uH and 150KHz....
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      #82
      What is the output diode you are using?
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • bianchi77
        • Jun 2016
        • 1121
        Diode = FR302 on frequency 921Hz, Vo = 216V and RL=7K..
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          #84
          fr302 = 100 reverse blocking voltage.
          you need FR304 at least.
          My pc
          • bianchi77
            • Jun 2016
            • 1121
            Fr107 ?
            • bianchi77
              • Jun 2016
              • 1121
              what happen if reverse blocking voltage is smaller than Vo ? will it reduce the output voltage ?
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                #87
                1N5822 40v not good enough
                FR107 1000v good up to 1000v will work for your application.
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #88
                  Wasted power as it goes backwards through diode.
                  My pc
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Ok, I'll see your suggestion
                    • bianchi77
                      • Jun 2016
                      • 1121
                      so if the output voltage is larger than diode breakdown voltage, it will reverse backward through diode...I see
                      • bianchi77
                        • Jun 2016
                        • 1121
                        may be it will answer one of my puzzle...
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          #92
                          that is correct.
                          My pc
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Nearly the same result with FR107 ...216V at RL = 7K
                            • bianchi77
                              • Jun 2016
                              • 1121
                              I'm thinking obtaining 330uH or 470uH inductor in one piece, since I'm using multiple inductors in series now, a lot flux loss down the wire, reducing efficiency a lot..
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                #95
                                what are you supplying this with
                                if you use 330uf inductor use 15khz oscillator.
                                My pc
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  I'm using 12V ATX power supply...the output is 11.4V
                                  I put fuse for protection...
                                  • joshnz
                                    • Feb 2011
                                    • 969
                                    • New Zealand
                                    #97
                                    ATX power supply
                                    the power supply you are using maybe 5v regulated and will need a load on the 5v rail to provide good voltage and current on the 12v rail.
                                    My pc
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      do you mean I need to put 10 ohm 10W on 5V rail to get a good voltage and current on 12V rail ? I have 10 ohm 10W, I'll put it later on ..
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        #99
                                        another calck says 330uf inductor use 150khz oscillator.
                                        My pc
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #100
                                          Thanks for the chip link, but that would be another month to wait, I'll buy it later on, but I'm interested to find a way to increase amperage for 555, this is what I have on my hand..
                                          There are only two explanations for that.
                                          1) The mail in Australia is using actual snails for delivery - highly unlikely
                                          OR
                                          2) The location in your profile is... incorrect (i was tempted to say BS at first).
                                          I don't want to think of a third possibility. Or actually, the "nicer" third possibility would be that you didn't even READ what i wrote in that post.
                                          I'm quite sure you didn't even click on that first result - the seller seems to be based in Croydon, Victoria.
                                          Are you trying to tell me a small envelope with 10 chips takes a whole friggin month to travel from Victoria to Western Australia? Or you really can't spare 5-6$?
                                          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
