XFX clicking noise
  • tiki66
    • Jul 2016
    • 39
    • Croatia
    XFX clicking noise
    So, my XFX PRO450W started clicking. Happens sometimes, clicks few times, then stops. Model is XPS-450W-SEW.
    Very common problem with these PSUs as I see, here is a video of one:
    https://www.youtube.com/watch?v=lcLzGFjkUKo
    Note: video is not mine. Also, it is not coming from fan (tried stopping the fan, noise continues). And on mine PS that happens only from time to time, not all the time.
    What could be making that noise? Here is picture of my PSU:
    http://imgur.com/a/iBLgC
    EDIT: I also tried looking at voltages when clicking happens, 12V and 5V rails keep being stable (measured with multimeter)
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: XFX clicking noise
    I would say a
    bad capacitor. or
    shorted diode.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • tiki66
      • Jul 2016
      • 39
      • Croatia
      Really? Even if the PSU is working normally?
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        hmm if works fine further investigation is needed.
        sounds like a converter is running in discontinuous mode usually caused by not enough load.
        My pc
        • Blechus
          • Sep 2015
          • Czech Republic
          Is it clicking even at heavy load? I assume a bad PFC circuit... (sorry about my english, its not my native language)
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            PFC coil?
            Btw who is the OEM?
            • Relayer
              • Nov 2017
              • 35
              • Earth
              Hello tiki66,
              The ticking almost sounds like the PSU is hiccuping. By this I mean, that the PSU tries to start up, senses a fault, then shuts down. It continually repeats this cycle.
              It also sounds a little like arching as well. Very strange that its intermittent.
              Can you check the outputs of the PSU with a multi-meter to see if there are any voltage fluctuations that keeps in tempo with the ticking?
              You may also need to monitor the voltage across the main filter capacitor as well.
              You need to check the above in and out of fault condition to compare it.
              If you have access to an oscilloscope, that would even be better.
              Regards,
              Relayer
              • Quaddro
                Tukang Kentu
                • Nov 2010
                • 141
                • Indonesia
                Yes, many psu make this sound if there's no load in the rail.
                But if it run with load and still have this noise, well..it's like something shorted.
                Like an arcing sound..
                • Stefan Payne
                  • 1267
                  Originally posted by goodpsusearch
                  Btw who is the OEM?
                  That is clearly made by gods and the best in the world. According to many people on the interwebs.
                  Seasonic
                  The Legendary S12II-Bronze series introduced around 8 years ago...
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    As I suspected...
                    This seems to be a common problem with that platform. I suspect the PFC coil and/or that glue that gets conductive:
                    https://www.badcaps.net/forum/showthread.php?t=16655
                    https://www.badcaps.net/forum/showthread.php?t=58380
                    • Stefan Payne
                      • 1267
                      As I suspected...
                      HOW DARE YOU!!111
                      No, just kiddin.
                      Hate the plattform too.
                      And especially the people recommending it today without any reason...
                      And because of the caps they assume the PSU will last and has better components...
                      PS: in the HX520W Thread, does it seem like the +5VSB chip has a hole in it and released the magic smoke?
                      Those things seem to die rather often for some reason...
                      • NConstantinou
                        HP Z840 workstation power supply clicking noise
                        by NConstantinou
                        No power
                        i have the above ps which i change the TOP258eg ic.
                        Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                        i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                        the colours look like R,R,W or silver,G Bl.
                        Thanks...
                        12-25-2024, 02:24 AM
                      • tony359
                        by tony359
                        11-28-2023, 05:18 AM
                      • MegaZAC
                        Onkyo TX-SR805 noise in one channel
                        by MegaZAC
                        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                        There's some logic behind it. As soon as I select an input I get only left...
                        04-23-2025, 10:09 PM
                      • CasasElectronics
                        Acer 6920G with strange error - sometimes boots and sometimes not, and rare fan noise
                        by CasasElectronics
                        Hi, I've been troubleshooting this PC for a while but I cannot repair it for now.
                        The error on this PC was the known graphics card soldering problem (or that was what I was thinking), so I took a 3470 from a 5920G and installed it.
                        The video after that worked, so I thought the problem was solved. When I tried to install windows, I noticed a problem: the ACER logo (bios load) stopped after completing the loading bar (and that was in every power on, but sometimes not even charged the Acer logo screen, I only could see a blinking white bar).
                        So I thought it may be...
                        02-25-2025, 03:26 PM
                      • ChristianBr01
                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                        by ChristianBr01
                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                        04-23-2025, 01:48 AM
