Is this Seasonic good?
  • sLowEnd
    • Aug 2008
    • 33
    Seasonic SS-400ET
    I haven't been able to find any info on it anywhere
    Info on it's quality would be great, Thanks
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Is this Seasonic good?
    OEM Seasonics have crap caps in them. You want a retail one.
    I'd sooner get this one:
    http://www.newegg.com/Product/Produc...82E16817104952
    Sure it's still got Teapo's in it, but at least it's priced appropriately. I've used them in customer builds and they seem to hold up fine.
    A man convinced against his will is of the same opinion still.
    • sLowEnd
      • Aug 2008
      • 33
      What about Antec's Earthwatts series?
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        It's probably fine, but I got off the Antec train with the Smartpower series.
        • sLowEnd
          • Aug 2008
          • 33
          What about a Seasonic S12 II 500w?
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            That should work fine, and have quality caps. Assuming you get the appropriate wattage, you really can't go wrong with retail Seasonic's.
            • Wizard
              • Mar 2008
              • 2296
              What Asctech means, RETAIL models that is boxed with all the pretty graphics on it and with a good warranty and manual etc. Not the white boxes or loose PSU and no manual (that what OEM is) and lesser warranty.
              Cheers, Wizard
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                Yes, to clarify, I mean the OEM ones come with OST and Teapo capacitors, while the retail boxed ones such as the S12, S12-2, and M12 come with qualtiy Japanese units.
                It's real easy.
                http://www.newegg.com/Product/Produc...SeaSonic%20USA
                If it says "retail" at the end of the name, it's a retail unit. If it says "OEM" at the end of the name, it's OEM.
                I have an OEM Seasonic 650w that Newegg no longer carries, that I got before I found out that their OEM ones use undesirable caps. It worked ok for a couple weeks, then I recapped it as a preventative measure. It now has Panasonic caps, and is still working great.
                http://www.newegg.com/Product/Produc...82E16817151036
                • sLowEnd
                  • Aug 2008
                  • 33
                  Thank you
                  You have been very helpful
                  I just ordered a Seasonic S12II 500w
