Measuring switching frequency ?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Measuring switching frequency ?
    Supposed to be on the cap
    If you know anything about SMPSes, the switching freqb is measured on the LV output diodes' anode(s).
    Autocorrect at its best again.
    Then stop using it! Why people would rather waste energy "apologizing" for autocorrect versus gee, correcting something, is beyond me.
    Oh yeah, the switching frequency will change as the load changes,
    Again, you don't understand. The switching frequency doesn't change with load. Only the hunting/squealing of an poorly compensated SMPS changes w/ load. If you don't know what "compensation" is and how it can cause/effect low freq oscillation in an SMPS's output, shut up til you know what the hell you're talking about.
    but 312hz is quite low for my liking. Time will tell.
    Again, you fail to understand what's going on. The fact that you think something would actually switch at 300-anything Hz is in direct conflict with the "little" transformers SMPSes use.
    Once again! 312Hz is NOT the switching frequency!
    The unit is oscillating/hunting- increase the load (add damping to the output filter) and it'll change or go away. The switching freq will remain the same- isn't that part of why they're called switch mode power supplies?!
    Get it right or go home.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • bianchi77
      • Jun 2016
      • 1121
      Got it measure the frequency as AC at the output of the transformer before it s rectified by diode set DMM to Hz and put negative to negative.. positive to that point..
      • CapLeaker
        Leaking Member
        • 8126
        Oh, grouchy... I apperrently know nothing. However you better re read what I meant. I didn't say that you measure the switching frequency at the capacitor. I suit he measues the ripple on the cap.
        #2: you may not like me posting with my tablet, as autocorrect frigs up things in a while, but since you know everything, you should understand better. Not your problem what I use.
        #3: I wasn't the one that said, 312hz is o.k. It should be way higher than that. Using a DMM to figure out the switching frequency is a bad idea anyhow. Use an oscilloscope for that.
        #4: I don't like to be yelled at chief grouchy. I think you should relly read the thread before you do some WAG pointing fingers. I've got a pretty good track record in fixing PSUs.
        Since you know things much better, go head. I am pissed off and out.
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Well , i agree with Capleaker about the Oscilloscope thingy , DMM were never made to do accurate frequencies tests .
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            And what did you measure for frequency? The data sheet in post 9 gives a good understanding of how the IC is working.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Kaboom some people are not book learners. They learn by doing. It is just a different form of learning.
              • Marianelforum
                Dj Marik
                • Jul 2016
                • 26
                • Romania
                #27
                There is an easier way to measure the freq of the supply by just measuring it at the outputs of the controller, for the 2003 one the outputs are at 7 and 8 pins, you just put the black lead of the multimeter at pin 12 ( Gnd ), and the red one at either 7 or 8 pin, each one delivers half of the wave for the power transformer's primary winding, so measuring just one of them tells you the frequency, you just need to make sure the DMM is well calibrated. Ofcourse if you got an osciloscope, you can view the outputs with it, and calculate the freq.
                • softm
                  #28
                  Switching freq of AT2005B is 50-60kHz, anybody who open datasheet can saw this at page 3.
                  Oscillation freq param.
                  If anybody want to verify this he will need use oscillocsope
                  to measure signal at gates/bases of mosfets/bipolar transistors of the power dcdc converter.
                  By what is need if datasheet have exact frequency.
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    That is the oscillating frequency the switching frequency is the cross over point at 0 dB. The oscillating frequency is a sawtooth waveform that is referenced to the switching frequency.
                      Page 4 notes: 2) Operating frequency, for push-pull operation, Fpush-pull = 1/2 Tosc.
                      So look at the value of the Ct cap and then use the scope to look at the outputs to see what you have.
                      • Marianelforum
                        Dj Marik
                        • Jul 2016
                        • 26
                        • Romania
                        #31
                        Not that this topic speaks of AT2005B, but fyi, that is the freq for a given vallue a CT, you can see what it is in the same page. But that is not neccesarily the case with all the psu's, because not all of them have the same CT vallue.
                        You should pay closer attention
                        The oscilator freq is divided by the internal flip-flop controlling the outputs, so the output frequency is half of the oscilator. That is well known by anyone with basic knowledge of PWM supplyes.
                        But again, the topic speaks of the 2003 controller, NOT AT2005B, and as i sayd, the simplest way is to measure one of the outputs, and you get the switching freq of the power transformer.
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          that escalated quickly
                          Permanently Retired Systems:
                          Kooky and Kool Systems
                          sigpic
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • Natob82
                            Micro Momentary Push Switch?
                            by Natob82
                            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                            12-21-2022, 05:22 AM
                          • SluggerB
                            Help making a switch work the opposite way with a relay
                            by SluggerB
                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                            02-07-2025, 07:57 PM
                            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 05:30 AM
                            Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                            by sam_sam_sam
                            Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                            ( needs more cam circuits for the machine to work correctly again )
                            https://www.ebay.com/itm/275321870186
                            To
                            3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                            ( not 4 positions but the right amount of cams circuits )
                            https://www.ebay.com/itm/274660439950
                            I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                            03-18-2023, 05:12 PM
