Re: Measuring switching frequency ?
If you know anything about SMPSes, the switching freqb is measured on the LV output diodes' anode(s).
Then stop using it! Why people would rather waste energy "apologizing" for autocorrect versus gee, correcting something, is beyond me.
Again, you don't understand. The switching frequency doesn't change with load. Only the hunting/squealing of an poorly compensated SMPS changes w/ load. If you don't know what "compensation" is and how it can cause/effect low freq oscillation in an SMPS's output, shut up til you know what the hell you're talking about.
Again, you fail to understand what's going on. The fact that you think something would actually switch at 300-anything Hz is in direct conflict with the "little" transformers SMPSes use.
Once again! 312Hz is NOT the switching frequency!
The unit is oscillating/hunting- increase the load (add damping to the output filter) and it'll change or go away. The switching freq will remain the same- isn't that part of why they're called switch mode power supplies?!
Get it right or go home.
