Measuring switching frequency ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    How can I measure the switching frequency of my ATX power supply ?
    Is it just switch to Hz on my DMM ?
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Measuring switching frequency ?
    yes just measure on secondary
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • bianchi77
      • Jun 2016
      • 1121
      I got 312Hz is that right ? positive DMM to +12 psu and 0 to ground
        • 31161
        you should meter before the diodes.
        if your seeing that on the output cables then your capacitors arent up to the job!
        • bianchi77
          • Jun 2016
          • 1121
          What's the common frequency used ?
            • 31161
            there isnt one, look at the controller chip part number - the frequency will be in the datasheet
            i suspect it's half what you metered
            • bianchi77
              • Jun 2016
              • 1121
              the controller is 2003
                • 31161
                well someone with more psu knowlege will have to give us the datasheet.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8297
                  https://www.badcaps.net/forum/attach...2&d=1391622049
                  That's for the 2005.
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Are you sure that isn't 312 KHz
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8297
                      312 Hz would be waay to slow. I was hoping he forgot the (k)Hz.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        it's Hz in DMM....
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8297
                          that' s not right. look up the specs on your DMM. Maybe it can't measure that high.
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            that' s not right.
                            yes, it can be!
                            if the feedback compensation is off, the loop can oscillate at some low frequency- anything from a few hundred Hz to a few kHz
                            bet there's not any load either- some will oscillate w/o load
                            this is not switching freq bleeding thru
                            wanna measure switching freq? one lead to the chassis and the other to an outer lead of one of the common-cathode rectifiers
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8297
                              Originally posted by kaboom
                              yes, it can be!
                              His measuring point is wrong. He went to the output of the 12V to GND. So he's measuring the ripple of the cap.
                              • kaboom
                                "Oh, Grouchy!"
                                • Jan 2011
                                • 2507
                                He's measuring the oscillating feedback loop! The hunting is that 312Hz.
                                "ripple of the cap" -what does that even mean?!
                                That 312Hz will change as the load on it changes, believe it or not...
                                EOL it...
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8297
                                  Supposed to be on the cap. Autocorrect at its best again. Oh yeah, the switching frequency will change as the load changes, but 312hz is quite low for my liking. Time will tell.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    So negative side of DMM to chassis or earth n red one to +12
                                      Not on the 12V, on the ANODE of the rectifier diode for the 12V which is the AC feed to the Anode of the rectifier. May be you should look up how rectifier is used and connected to an AC source to rectify an AC then you will understand where to put the probe to measure what you are looking for, need to understand the basic first.
                                      • kaboom
                                        "Oh, Grouchy!"
                                        • Jan 2011
                                        • 2507
                                        Originally posted by budm
                                        Not on the 12V, on the ANODE of the rectifier diode for the 12V which is AC feed to the Anode of the rectifier.
                                        Thank you, OM. That's exactly what I (and stj) said above to the OP, who's jumping in before he can swim.
                                        May be should look up how rectifier is used and connected to an AC source to rectify an AC then you will understand where to put the probe to measure what you are looking for, need to understand the basic first.
                                        Said the same to him in the other thread, with the fake POS external supply. His posts are almost as bad as some youtube comments. Has no idea what the hell he's doing, yet wants to be "rewarded" with constant handholding with answers to the types of questions which suggest he's got no clue.
                                        Yes, we all started somewhere, but dammit, start small and work your way up; don't turn things into a google handhold competition, read some books and use your head. THINK about things for an entire 30 seconds, after LEARNING SOMETHING, then you'll (hopefully) arrive at some conclusion.
                                        "Reactive and emotional" have no place in troubleshooting.
                                        EOL it...
                                          03-31-2024, 02:12 PM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • SluggerB
                                          Help making a switch work the opposite way with a relay
                                          by SluggerB
                                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                          02-07-2025, 07:57 PM
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                          Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                          Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                          ( needs more cam circuits for the machine to work correctly again )
                                          https://www.ebay.com/itm/275321870186
                                          To
                                          3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                          ( not 4 positions but the right amount of cams circuits )
                                          https://www.ebay.com/itm/274660439950
                                          I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                          03-18-2023, 05:12 PM
