12V rail is not on ?
  • playit
    450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
    by playit
    hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
    09-02-2023, 02:43 AM
  • NConstantinou
    19v rail short voltage injection help!
    by NConstantinou
    i HAVE AN HP MOBO WHICH HAS SHORT +VIN.
    THE SHORT APPEARS AFTER THER CURRENT SENSE RESISTOR.(REMOVED AND TESTED).
    I AM GETTING RESISTANCE TO GROUND 14 OHMS.
    I PLACED A JUMPER CABLE ON CURRENT SENSE RESISTOR AND I APPLIED 2V
    AND I INCREASE AMPS UPTO 0.86 SHOWNING CC ON PS FOR SHORT.
    I NOTICE PCH AEAR IS GETTING A LITTLE BIT WARM.
    I INCREASE AMPS TO 0.9 AND CC LIGHT ON PS WHEN OFF.
    ACCORDING TO PS SHORT CC LIGHT IS ON BETWEEN 0.27-0.86A
    WHY IS THIS!
    CAN SOMEONE EXPLAIN
    THANKS
    07-16-2022, 03:17 AM
  • fab13
    0 Volt PEX Rail on Zotac GTX 1080 8 GB OEM- No short help
    by fab13
    Hello to all,
    I'm struggling with this card lol Zotac GTX 1080 OEM 8 GB
    After checking there was a short circuit on the 1.8V from a capacitor and I had no voltage and now I have my 1.8V voltage.
    Other problem I do not have the voltage PEX Rail 1Volts and measured value 48 Ohm seems correct.
    Measured 3.3 V and 12 V and 5 V OK and 1.8 V OK to the coils
    Missing Vcore between 0.8 V and 0.9 V and VEM 1.5 V (Rather normal because no 1 V PEX)
    1 ) After checking the controller uP1728QBDDA (See photo Missing PEX) there...
    08-21-2022, 08:51 AM
  • Askic
    Short on motherboard power rail - general question
    by Askic
    Hello guys,
    first of all I'm not a professional in repairing electronics, but I do have formal electrical background. From time to time I have managed to repair something like PSU or laptops when faults were obvious or very easy to find with a multimeter.
    However, recently I had a problem with 19V power rail shorted to ground. I was not able to find the cause, because a shorted component was somewhere deeper in the motherboard and this was handed to a professional.
    I wonder if it is sufficient to check 8th pin on BIOS chip and pin on power switch, where 3.3V...
    12-24-2020, 11:55 PM
  • brain123
    Msi Gp76 20V short Rail
    by brain123
    I have a Msi Gp76 mainborad here that cannot be switched on."20V rail has a short circuit. One of the mosfets from the graphics card burned out and was unsoldered. The board is still hot without the mosfet.
    What could be the problem?...
    01-14-2023, 03:08 AM
