SB240 diode test ?
  • bianchi77
    • Jun 2016
    • 1121
    SB240 diode test ?
    Guys,
    I've tested SB240 with diode test on DMM...
    and I got 0.115V and 0.127V on both side red and black probe of DMM vice versa....
    I reckon it's faulty...because diode normally only doing one way and the other is OL...
    Comments ?
    • 31304
    Re: SB240 diode test ?
    a schotky diode can react like that on some meters.
    • bianchi77
      • Jun 2016
      • 1121
      so how can I determine if it's ok ?
        • 31304
        use a battery & bulb - see if it only lights one way
        • bianchi77
          • Jun 2016
          • 1121
          ok..that's good idea
          • bianchi77
            • Jun 2016
            • 1121
            if it's a rectifying diode on switching regulator and there's a short on its output...it's most likely faulty isn't it ?
            • bianchi77
              • Jun 2016
              • 1121
              I'm testing it with battery and LED...it's normal...
              another one...I have SBL1040....I've tested with LED and battery...forward and reverse bias...it's normal, but when I tested this SBL1040 on diode test DMM it's 0.17V....it's faulty, isn't it ?
              I used LED, resistor 1K and 9V battery performing the test..
                • 31304
                not sure what you mean,
                if a diode is shorted then it's bad.
                but if your just metering the output of a psu, many have a low ohms resistor across the output that will fool your meter.
                  • 31304
                  if the lamp only works one way - it's working.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Doesn't matter if DMM = 0.17V ?
                      Use 9V, 100 Ohms resistor in series with DUT (to simulate about 90mA of If) to forward bias the diode and use your meter to read the Vf of the diode under test to see what you get.
                      Vf will very with current flowing through the DIODE, Temperature also affect Vf.
                      If you test setup show LED lights in one direction only with that diode, the the diode is OK.
                      You can also use your variable power supply to reverse bias the diode to see if it will break down way before the Voltage break down spec. of the diode.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        if I use 90mA...will the LED stand...or it will be very bright...
                          • 31304
                          very very very bright, most led's are only rated for 30ma!
                          • bianchi77
                            • Jun 2016
                            • 1121
                            That's what I'm thinking...will it burn only in few seconds ?
                            • TechGeek
                              Computer Geek
                              • Jan 2015
                              • 2254
                              probably; that's 4.5x more than it's rated for!
                              Permanently Retired Systems:
                              Kooky and Kool Systems
                              sigpic
                                No LED! We are just trying to read Vf of the Diode with about 90mA through it. You can look at the Vf graph of the diode with relation to the current in the spec sheet.
                                That why I said 9V, 100 Ohms resistor, and the DUT.
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  ok...9V -->100 Ohm --> Device Under Test (diode)...and my DMM on diode test mode to see the voltage on diode ?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    compare with this chart ....
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      with DMM diode test on 90mA Vf must be inside the red circle, correct me if I'm wrong
                                        https://cdn.badcaps-static.com/pdfs/...de6c30ae15.pdf
                                        https://cdn.badcaps-static.com/pdfs/...2f0cb7ec39.pdf
                                        Not all brand will have same exact Vf.
                                        So just try it and see what you get.
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP EliteBook x360 830 G6 + Fitbit Versa Smart Fitness Watch Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 830 G6 + Fitbit Versa Smart Fitness Watch Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Fitbit Versa Smart Fitness Watch boardview and 830 G6 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 12:00 PM
