help to id a resistor on Vestel_17IPS11__rev4 power board
  • Dev Web
    • Jul 2016
    • 13
    • united kingdom
    hello, i need help to id this resistor circled in green on this Vestel_17IPS11__rev4 i will include a photo, i cant id it as nothing comes up when i enter them colours none have a balck at ether end from what i can tell but this one looks like it does, also if anyone could id the 5 resin dipped caps, i think iv id them but not sure they are circled in red, thank you phil.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: help to id a resistor on Vestel_17IPS11__rev4 power board
    Hi mate what was the issue with the set again no backlight ?
    • Dev Web
      • Jul 2016
      • 13
      • united kingdom
      oh hi man nice to see you, ok ye the back lights did not work at all so i opened up and 3 leds had blown so i replaced and tested all worked, but when i now turn thre tv on it will flash the back leds on for a fraction of a second then there off, tv works and displays if i shine a light on it to see, i tested that resistor and those resin caps and none of them have any reading at all so i assume there the problem, but hard to id them.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm what is the Led voltage when it flashes ?
        • Dev Web
          • Jul 2016
          • 13
          • united kingdom
          it does the normal jump up to around 90 then falls off to around 24, the return does nothing until that the red wire power falls to 24 then the return shows 4 then slowly drops to 0 again
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Psu is fine then buddy, the Leds you used might not have been the rating I thought and have burnt out.
            • Dev Web
              • Jul 2016
              • 13
              • united kingdom
              ok that makes some sense then, they do only light up when 3 volts is passed they dont light up if i try 1.5 volt but im new to this so watt must matter here then, i will strip it back down and test them again to see, in the mean time are those caps i mentioned and that resistor ok not having any reading even if i take them off the board
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Or maybe order some ves315 leds off ebay they are cheap ?
                • Dev Web
                  • Jul 2016
                  • 13
                  • united kingdom
                  ok i will do, i will test the leds i put in and come back tomorrow and continue this thread if there working but sounds like ther not so then i will wait until iv got new leds to try, thank you so much for you time.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ok buddy keep us updated, also be very careful of the screen not to crack it.
                    • Dev Web
                      • Jul 2016
                      • 13
                      • united kingdom
                      um there very expensive on ebay, i have a company accounts at all the componant surpliers in the uk, what are these leds so i can find them as putting ves315 leds shows nothing at there websites
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        If not try ves400 into ebay leds for them are about £20 buddy then use the stacking method.
                        • Dev Web
                          • Jul 2016
                          • 13
                          • united kingdom
                          iv found simlar at rs and there only o.o63 per led but they dont list the mha so not sure plus they have other even cheaper as 20 quid is to dear for me im on a very tight budget that means no food for a week if i spend 20 quid on something.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Yeah they might smoke as you power it up, they need to have 400mha current.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              trying to find new leds from the likes of rs components ,mouser etc is hard as the colour is usually hard to match and also the size and amps etc, reece has the best idea use ebay for used led strips and use the stacking method reece has a youtube video on it. take a picture of the led strips used in your set i may have some out of a smashed screen sets.
                              https://www.youtube.com/watch?v=RxwdC7V5Ue0
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Good point Vince
                                • Dev Web
                                  • Jul 2016
                                  • 13
                                  • united kingdom
                                  ye iv watched that video and from it i was able to unsolder tiny leds from a laptop and solder them without melting them onto the strip so no need to stack, also they have evry colour at rs iv checked i can get 2700k upto 7000k and white is usualy 7000k, i cant aford those dear leds of ebay as i mentioned im on a very tight budget until my software company makes money, that could take years, which is why i thought i would learn how to fix tv's for some extra income as i getting quite thin LOL.
                                  vince the led strip are the same as in that video as its the same set with the same vestel boards and setup only difference is this is rev 4 board and they took some caps out and replaced it with some kind of stealth chip that is a trasistor with the middle leg cut off so what ever those leds are i have the same.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Regarding new leds then im not sure im like reece use recycled ones from old led strips there are various posts on this forum regarding trying new leds etc i dont think anyone has really found any that work/last im not sure what reece thinks regarding sourcing new ones?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      I have only ever used recycled ones buddy, finding new ones is very hard to do as they are hard to match properly
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        yes thats my findings too hence why i collect free smashed screen led tvs still well worth keeping the led strips and boards/stands etc
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ugamazing
                                          Assistance with identifying resistor value on 820-02918 A2992 board?
                                          by ugamazing
                                          Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                                          I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                                          09-06-2024, 08:33 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
