Alternative to Dell Power Supplies
  • 4tified
    • Jun 2008
    • 55
    In my personal experience, Dell power supplies are crap. If it isn't the boards that are failing, it surely is the power supplies...Full tower, Mid tower, and SFF alike. My question is are there any alternatives to Dell power supplies out there (ie: differnet vendor)? I know Dell uses different voltages and a standard ATX power supply won't fly. (Found that out the hard way)
    Any help is appreciated.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Alternative to Dell Power Supplies
    I heard that you can change the pinout through buying a converter cable to use with your Dell PC. Personally I feel that Dell PSUs are very good. Usually they are made by Delta and Hipro, which make the best PSUs I've ever used. Heck, I even go out buying Dell second hand PSUs by the lot because I can rely on them. But yes once in a while, the Hipro ones will have bad caps and can be cured by a simple recap and about $4-5 in capacitors.
    Thanks.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      I don't think the voltages are different on the offending Dell PSU's its the pinout on the plug. If you "Google" it you will find the instructions you need to switch the wires around on the ATX connector. I have one here with an off the shelf Hipro PSU in it and it works fine. I didn't have to change anything on that one. I do have a newer Dell here with the non-standard pinout on the PSU but its working just fine for now. Good Luck! You can do it!
      Mark Twain
      John Paul Jones
      Rod Serling
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Don't listen to me.....I was wrong!!!! Your system will Blow up if you do!!!
        Buy the adpter if needed. Its neat and clean and will allow you to use a standard PSU in place of the Dell non-standard PSU. I found one on "End PC Noise" The price was $14.95. The site also lists some Dells that need it as well as some that don't.
        Mark Twain
        John Paul Jones
        Rod Serling
        • 4tified
          • Jun 2008
          • 55
          Thanks.
          I wish I knew what system genenration of power supply you're using, becuase the ones for the GX150's and GX270's go bad, but never show any sign of failing caps.... though maybe they are just worn out and and haven't bursted, which is why I need an ESR meter to guide me around.
          Well, that would take care of the power conversion problem...now what about the reversed plug-in on the back of the power supply itself? I'd hate to have to gut another power supply just to reverse everything...
          Note: You know what? I might as well buy a Dell power supply as this converter costs $15...if I spend $15 or more on a power supply, I haven't saved any money at all.
          • Krankshaft
            • Jan 2007
            • 2328
            Modern Dells observe the standard ATX pinout unless you have an old Dell then this shouldn't be a problem.
            I believe Dell went astray on the ATX pinout around 1998 or so as soon as they released their first Pentium 4 system they went back to the standard pinout.
            I just installed my 4th recapped Antec Smartpower on my brothers Dell Dimension 4700 yesterday without any problems.
            I must say though Dell mobos are CRAP I went into Speedfan to check the temps and voltages and I got nothing.
            This is either because Speedfan doesn't have the drivers to access the sensors or more likely these sensors were left out of the mobo to cut costs .
            No matter after every recap I connect a HDD to the PSU as a dummy load and read the rails to make sure that everything is within spec before plugging it into a mobo.
            • severach
              • Aug 2007
              • 1055
              Dell didn't faire any better or worse than other companies at the time. Whether you call them bad or not depends on whether you can fix them. If not it's just another system for warranty or scrap. If so then it's another good system at scrap prices. Supplies that don't burn out the boards are a major benefit.
              GX150 and GX270 supplies are standard ATX. Dell GX1 and similar Pentium II boards had a different ATX layout. Compare the wire colors. My GX1 supplies were usually Delta and had a low failure rate.
              All of my GX150 supplies died without any bad caps. Once the Power Good got below 250ms as measured with the CoolMax PS-224 power supply tester the supply didn't have long to live. The high quality reclaim caps were worth more than the supplies. I use rebuilt GX270 supplies for the few GX150 systems that need to stay running.
              GX270 HP (Hi-Pro) with Arcon caps always revive with new capacitors. HiPro with Teapo caps fail for non cap reasons so I take the Teapo caps and put them into an Arcon equipped HiPro. Dead HiPro supplies seem good about shutting down without destroying motherboards and are visibly better built than the others so I prefer them. NPS (Newton) and PS (Lite-On) supplies fail for non cap reasons.
              I ran all of my GX270 systems with HiPro formerly Arcon and Antec supplies.
              I traded my GX270s in for GX280s and I am seeing the same non cap high failure rate that the GX150s had for the PS-5201 supplies and the failure might destroy motherboards. The ones that still power lose control of the 3.3v line. All were discarded. I'm running a NPS-250KB to see if it holds up. The rest have Antecs out of the GX270s.
              The CoolMax PS-224 is much more informative than any hand operated volt meter.
              sig files are for morons
              • 4tified
                • Jun 2008
                • 55
                Interesting....I took apart a GX150 power supply and could nit diagnose the issue (at least not visably, there were no bad caps or other signs of failure.) i guess my other problem is that I don't have any testing equipment at the moment. Other than my multimeter (which I'm told can't measure components in-circuit), I am running blind. I did however just order an ESR meter, hopefully that will be my light in the dark, so to speak.
                P.S. - I just found some NPS-250KB PS's on eBay, I'll take my chance and see how they fair. Thanks for the help everybody.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  Our family computer is a dimension 4600, speedfan registers 3 fans, (only has 1.) shows two that run at 26,000 rpm, 1 runs at 1920rpm (thats the real one,) but that uses a standart atx connector. So does my optiplex Gx150 1ghz p3, I put a bestec psu in it from a compaq, and it works just fine.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    My problem is the other way around
                    I bought some new Dell HP-P2507FWP power supplies, guessing they were Hipro built, to use with generic motherboards
                    Each supply will power up if I connect it to a HDD and FDD for load, then on its 20-pin ATX connector, short the PSON wire to a GND wire beside it
                    But after plugging its ATX connector onto a motherboard, as well as the 12v connector, nothing happens when I touch a screwdriver tip to the motherboard's PwrSw pins
                    Have tried with an Abit SG72 board, as well as an Intel D845GVAD2
                    Same procedure with a generic ATX supply - comes on straight away
                    Pity - the HP-P2507FWP appears to be a quality supply, especially compared to some of the flimsy junk where bling is more important than function
                    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      BTW, the HP-2507FWP appear to have standard pinout, judging by colour coding and measured voltages
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        I was able to hook up an Antec to a Dell Dimension 4600 without any problem noticed.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Mark01
                          Dell Optiplex 7490 AIO - red power led after flash
                          by Mark01
                          Hi guys,
                          This is my first post! 🚀
                          I have no idea what I’m doing, but I’m learning by trial and error.
                          I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                          07-04-2025, 12:54 PM
                        • zlr8r
                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                          by zlr8r
                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                          Ill try and give as much info as I can.
                          Dell Inspiron 17 (7786) Laptop
                          Service Tag: 5J0NHT2
                          Bios: 1.9.0
                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                          Then it started getting weirder!
                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                          12-12-2023, 09:31 PM
                        • LimesKey
                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                          by LimesKey
                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                          10-17-2025, 05:33 PM
                        • seppde
                          Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                          by seppde
                          I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                          My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                          Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                          Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                          10-01-2024, 10:57 AM
