Annoying heavy load-failure in Tecnoware Free Silent 500W
  • Bungz
    • May 2013
    • 133
    Re: Annoying heavy load-failure in Tecnoware Free Silent 500W
    I have skim read the thread but I will say this.
    It will be allot easier to replace the PSU's rather than find new P5B's, those are nice boards and not particularly cheap 2nd hand.
    • omega
      • Mar 2014
      • 47
      • Italia
      #42
      Sorry for my delay in replying but I have been concerned in a slow recapping of ATX in my free time!
      So far I recapped four Power Supplies (and replaced their 12 V rail diodes) but I had the opportunity to test two only and the result is of course Solomonic. One had shortly failed (ATAPI error of the HDD) and the other has been stressed for 10 days of intensive computation and holds super. However, I believe that the statistics has to be extended to the other recapped PSU, maybe the failure of the former machine has been due to the Mobo or elsewhere.
      Momaka, as you suggested me, I also have been desoldering the resistors (see the picture), actually 470 ohm, since most of them have been baked enough for the colour bands to appear all as dark-brown ones :-) Anyway, the dissipating heat is 17x17/470 = 0.61 W which is 20% too much for a halfwatt resistor. Therefore I removed thm all (V = -11.5 to -12 V). I measured every voltage under a 21 W car stop bulb (see picture) connected to the 12 V rail only. Not so much indeed, but better than nothing.
      The other pictures are concerning the previous release of the ATX posted in this thread to recap. Here, there is the usual failure under intense load (ATAPI error #11 and #9). Based to the hints of my "teacher" Momaka, I now have some clue of my own about recapping and replacing the diode. Just let me post some questions:
      1. why did they put a 2200 uF 6.3 V cap in the 5VSB rail after the wattage in the specification is even lower with respect to the newer release (10 W vs. 12.5 W)?
      2. is there any concern about the presence of a central, small electrolytic cap between the fast diode and the two small transistors (I had to also replace a 0.25 W 10 ohm resistor - red ellipse - which was rather baked together the PCB)?
      3. what may the green spots on the ChengX cap black envelopes near the diode heatsink mean? I can see no exploded component, however.
      4. last but not least: how can one MEASURE the actual (instant) load of a PC to an ATX? I mean experimental readings, not average computing in some web sites. I begin to suspect that the PSUs simply can't afford the intense load of my computations!
      P.S. I am inspecting the Corsair VS450, which we had speaking about in a previous post. It's indeed full of CapXon and JunFu caps! I will be posting some pics since it's not yet clear to me which cap belongs to which rail.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #43
        Sorry, I didn't read the whole thread.
        https://www.badcaps.net/forum/attach...4&d=1454168083
        This is terrible. The 3 main output voltages (3.3V, 5V and 12V) need to have a CLC output filter.
        Capacitor , coil in series and capacitor.
        This thing has no output coils and only 1 cap per rail. Ripple is gonna be terrible. There is really no point trying to repair/recap a psu like that.
        It should never be powering a computer again.
        • omega
          • Mar 2014
          • 47
          • Italia
          #44
          Thank you for your post! Unfortunately, as I explained above, it was a crazy choice of 2011 which I can't modify now. Anyway, I think you believe it even worse than the 3rd series Tecnoware PSU (posted at the beginning of the thread) which has no coil but TWO identical serial caps per rail. Right?
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #45
            No coil but 2 caps in parallel per rail is OK if you make sure that the caps are not bad and choose their capacity and esr wisely
            • omega
              • Mar 2014
              • 47
              • Italia
              #46
              2 caps in parallel
              ops sorry for the lapsus digiti :-)
              Then I won't recap this last one, but I will replaced it by a spared "two caps" PSU, which I will Panasonic recap in the meantime
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #47
                Before doing anything please first post pics of the psu in question. There are some known issues with certain models and we could advise you what to do with them.
                The psu I saw some posts ago definitely belongs to the "For parts only" pile.
                • omega
                  • Mar 2014
                  • 47
                  • Italia
                  #48
                  It's exactly what I show you in middle December in this thread. What I can say is that I recapped the first ones with Japan quality ones according to the momaka directions and now one of them is about to pass my 10-day-stress test.
                  As posted, would I put them away, would also put myself and my research away, now I am obliged to repair them. :-(
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #49
                    I am re-reading the thread...
                    OK, done.
                    2 caps in parallel without a coil in series among them is definitely better than just 1 cap per voltage output.
                    The last psu is not worth recapping/repairing.
                    About the other psus, you could use them with caution.
                    Pay attention to this:
                    Originally posted by momaka
                    Yes.
                    Your FAL501FS12 had those 1500 uF caps everywhere simply because the manufacturer probably saved a few coins by not buying bigger 2200 uF caps. Same reason why there are no inductor coils between the caps - less parts to put in, less cost for the manufacturer.
                    Pinch a coin here and there and you can save a decent amount at the end of the day.
                    You can try improving these power supplies but no one here can guarantee to you that they are going to be safe to use on a power hungry and expensive system, such as an Intel quad core computer. I wouldn't.
                    • omega
                      • Mar 2014
                      • 47
                      • Italia
                      #50
                      Thanks for the warning. Beside recapping them, I also replaced the 16A Fast Recovery 12V rail with a Schottky 20A. Hopefully it will increase the MTBFof these 20 PSUs
                      • omega
                        • Mar 2014
                        • 47
                        • Italia
                        #51
                        What if I put bigger capacitors in the one-cap-per-rail PSU? Let's say I would double capacitance. If I remember, two same caps in parallel is equivalent to a double capacitance cap.
                          • 31286
                          2 caps in parallel also lowers the esr
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #53
                            2x2200uF or maybe 2x3300uF is the maximum you can put. If the caps esr is too low for the psu design then you may have oscillations.
                              master hoarder
                              • May 2008
                              • 12175
                              #54
                              Good riddance with that load resistor! I think the heavy load on the 12V rail will keep the -12V rail voltage is spec too.
                              Even if that 470 Ohm resistor was rated for 1 Watt, 0.61 Watts is still enough to make it run very hot. A good rule of thumb for resistors is to dissipate no more than half of the rated power (so for 1 Watt, that would be 0.5 Watts). I guess the PSU manufacturers here weren't too concerned with that, though .
                              If the voltage were in spec with that 21 Watt car bulb on the 12V rail, chances are, they will be in spec when the system is loaded as well (provided the CPU isn't too much of a load on the 12V rail). Speaking of which...
                              ...and the other has been stressed for 10 days of intensive computation and holds super.
                              What did the voltages measure in that PC when it was idle and under load? Sometimes this can be a decent indication if the PSU is actually capable of running the PC in the long term. Generally, if many of the voltages are too close to being out of specs, that indicates you've likely reached the PSU's limits or are getting very close.
                              So that's a different revision of the PSU than the one is post #14 below bu same model number?
                              https://www.badcaps.net/forum/showpo...4&postcount=14
                              If yes, I say this revision (in post #42) is even more terrible. One cap per rail means you will have to use HUGE caps on the output to keep ripple and noise low.
                              For the 12V rail, you will want at least 3300 uF. Same with 3.3V and 5V rails. I see you only have a single 1800 uF cap in there. I'm not surprised at all you are getting unstable PC / HDD errors here again.
                              If the PSU had other 2200 uF 6.3V caps elsewhere originally, they probably did this because it was cheaper to buy many caps of the same size and capacitance (to reduce cost per cap). Either that, or perhaps because they knew they used low quality capacitors and wanted the 5 VSB cap to last a bit longer.
                              In general, most older 5VSB designs need to have at least 2000 uF worth capacitance. Whether you do it with two 1000 uF caps or one 2200 uF cap is irrelevant. And having two 2200 uF caps is even better in terms of filtering ripple on the 5VSB, but not necessary. 5VSB topology is usually Flyback type, so low ESR and high ripple-current -rated caps are recommended.
                              If it looks like that cap got overheated and you have a spare cap, then replace it. Looks like that electrolytic cap is for smoothing voltage for the BJT drive circuitry on the secondary side. Not sure how important it is for this design, though.
                              Also, if that 10 Ohm resistor was really burned, then you should probably also replace ceramic cap C19 as well (ahh, more parts to change, I know! ). The 10 Ohm resistor and C19 form a snubber network, which limits voltage spikes going to the secondary rectifiers. Since C19 appears to be connected to that F16C20C rectifier, then this snubber network is for the 12V rail (which makes sense, because your PCs were/are stressing the 12V rail the most, and those ceramic caps were likely not coping well with the high loads.)
                              I recommend replacing the ceramic cap in spot C19 with a polypropylene (PP) / film capacitor. Reason for that is because ceramic caps tend to have a terrible thermal coefficient (their capacitance greatly varies with temperature), whereas PP/film caps are much more stable. Use same capacitance as original. Voltage rating of 50V should suffice, but 100V will be even better. If the resistor burns again, you might want to consider replacing with a 1W watt rather than 1/2 Watt.
                              I was just looking at the pictures myself before I read your questions and was wondering the same thing too. :\
                              Aluminum corrosion is usually green or dark gray, but I think it would be weird for that to go through the paint like this. Hopefully someone else can chime in with answers or ideas.
                              Easy, but less accurate way:
                              Use a Watt meter (like P3 Kill-A-Watt or similar) to measure the power drawn from the wall. These cheap PSUs have 65-75% typical efficiency, so the DC power drawn by the computer will be only 65-75% of what you measure with the Watt meter - and most of that from the 12V rail.
                              Example:
                              PC draws 170 Watts from the wall at full CPU load. Then that means the PC is drawing between 170 x 0.75 = 127.5 and 110.5 Watts of DC power (of which, 85-90% is likely from the 12V rail).
                              Harder, but much more accurate way:
                              You will need a meter that can measure at least 20 Amps of DC current continuously (most multimeters say they can measure 10 or 20 Amps only for a few seconds). Splice it between the motherboard and PSU on the CPU 4/8-pin 12V connector to measure the current. This will present the majority of the load on your PSU if there is no medium/high power dedicated video card. In your case, you said you had a GeForce 6200, so add 10-20 Watts for that.
                              Probably better to start a new thread about that one so we can keep better track of the discussion. Feel free to link the thread here, though (once it's created.)
                                master hoarder
                                • May 2008
                                • 12175
                                #55
                                Correct.
                                Yes, double the capacitance would be better. As I suggested, 3300 uF should be the minimum for any of the rails. 4700-6800 uF would be a lot better, though.
                                I know and I agree with what you said earlier - I wouldn't bother to fix such a cheap PSU for such a good PC either. But sometimes the choice is not ours to make.
                                Actually, I've had a similar scenario happen before when I was a tech. Had a friend call and said some computer at his work was down. When I came, his boss made it clear: either repair the faulty PC for this low amount of money or they'd rather throw it away and get a new one, because this one was cheap and the boss was convinced it wasn't worth spending too much money on repair. Now, the PC in question was a decent C2D or C2Q machine if I remember correctly, so I thought it was definitely worth trying to save it (I'm pretty sure they wouldn't have given it to me, even if I said it couldn't be repaired for this cheap - knowing that place, they'd probably take that computer to the parking lot and take turns to run it over with their work trucks rather than give it to someone). Upon opening the case, I was greeted with a cheap Linkworld PSU that turned out to be the problem. I suggested a good quality PSU, but owner was dead-set on spending a low amount of money on repair. So instead I went with a used/refurb 250 Watt HiPro PSU from a local electronics store. I opened the HiPro to clean it a bit, then checked for bad caps and also the fan. After that, swapped it in and called it a night.
                                Was it a perfect repair? - No, not by my standards. But sometimes that's all you can do in a given situation.
                                That said, my repair was still at least 2x cheaper than what a fly-by repair tech would have charged to install the same or worse PSU as the original crap.
                                • omega
                                  • Mar 2014
                                  • 47
                                  • Italia
                                  #56
                                  Dear Momaka, thanks for your wide and thorough post!
                                  In fact, the scenario is worse than you painted (see pic). Those resistors are 0.5 W, definitely!
                                  Actually, I wondered whether I have to put some load to the 5 and 3.3 rails.
                                  Here are the data:
                                  nominal before recap, 21W after, 21W after, no load
                                  12 V 11.9 V 12.1 V 12.4 V
                                  5 V 5.2 V 5.2 V 5.1 V
                                  5 VSB 5.1 V 5.1 V 5.1 V
                                  3.3 V 3.3 V 3.4 V 3.3V
                                  –12 V –11.4 V –11.5 V –11.5 V
                                  The final verdict is of course yours, however :-)
                                  Yes, the #42 post (Technoware FAL500FS12) concerns a previous revision of #14 post (FAL501FS12). The The so many posts before yours have convinced me NOT to recap these three PSUs of mine. I will rather replace with recapped, third series (i.e. #14) Technoware PSUs, definitely better designed. On the other hand, it's not easy to find big caps as you suggested me which fits the narrow PCB places. In fact, the 2200 uF, 16V, 10 mm have been proved particularly expensive!
                                  Example:
                                  Actually, I did not believe that it was so complicated to do. No 20 A multimeter, sorry.
                                  And i did it, waiting for a post of yours.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #57
                                    You can use clamp meter for higher currents. El cheapos are not really much precise, but still much more than measuring through wattmeter.
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      The 500 watt Technoware in post #42 looked very familiar. I have an identical pc board which was marketed in the USA as a 350 watt IMicro Model HP-350-G12S. Mine had a bulging 5vsb capacitor. I added a small coil and another capacitor to the 5vsb because the pc board was marked for C-L-C but the coil and second capacitor were missing.
                                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #59
                                        *sigh* Built to fail, I suppose
                                        Not today, though - you fixed it
                                        Most older designs like this almost always perform well with a good load on the 3.3V and 5V rails. Not having any there and solely loading the 12V rail really tells you if the PSU is somewhat capable of handling cross-loading. So it's a good thing you tested without load on 3.3V and 5V rails.
                                        Here are the data:
                                        Nothing out of the ordinary here. But I was wondering about that recapped PSU you put in one of the computers. Would really like to see how these PSUs do "in the field" after they are fixed.
                                        Ah okay, got it.
                                        Well, you can use the version in post #42, but again, you will need some 3300 uF and 4700 uF caps for the 3.3V/5V and 12V rails, respectively. Note that there is lots of space around the caps in that revision, so it will be much easier to use 12.5 mm diameter caps. And for the 12V rail, maybe even a 16 mm diameter cap. That should make it a lot easier to find capacitors with such large capacity. If you have the choice, always go for the bigger capacity. The ESR is important, but not as much. In general, any 105C cap will do.
                                        Even Behemot's?
                                        Anyways, if it's easier, see if at least one 12.5 mm cap will fit on the 12V rail, besides the other 10 mm cap (for the revision in post #14, that is).
                                        Well, yes, it really isn't. But if you are trying to get the total power consumption accurately, you will also need to do the 3.3V and 5V rails. (Though it's worth mentioning that many motherboards rarely pull anything more than 20-30 Watts combined.)
                                        Okay, I will chime in there a little later tonight.
                                        I don't know . You keep saying that, but I can measure my PSUs just fine. In fact, I just tested a laptop power adapter. Measured the input power with my P3 Kill-a-watt and the output with a multimeter (had a resistive load connected). Got efficiencies in the range of 84-87% and a Power Factor of 0.47-0.52. Maybe not very accurate, but still a decent ballpark, I think.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #60
                                          Yeah and now take unknown unit and try to measure power output through the wattmeter. You'd be glad to get 10% error.
                                            MSI Cubi 3 Silent S-018US 4415U Specification for Upgrade or Repair
                                            This specification for the MSI Cubi 3 Silent S-018US can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi 3 Silent S-018US boardview and Cubi 3 Silent S-018US schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:28 PM
                                          • Robin21
                                            Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                                            by Robin21
                                            I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                                            I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                                            All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                                            I've replaces both buck regulators already (AOZ1212)...
                                            09-25-2025, 03:24 AM
                                          • ChanHa
                                            Help me Resistor on FSP Hexa ATX 500w
                                            by ChanHa
                                            My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
                                            06-04-2025, 08:44 PM
                                          • unimatrix93
                                            Jeep Drive-train control module repair
                                            by unimatrix93
                                            Dear forum,
                                            My father's Jeep has this annoying rattling sound which is caused by the Drive train module as it constantly moving a solenoid.
                                            It comes and goes as the temperature changes. For example, when you cold start the vehicle from a long parking time, it starts loudly (especially on winter) then it goes silent as the vehicle's temperature rises.
                                            So I took the DTCM apart and found this damaged ceramic cap, which I should replace:
                                            Now the problem is that I couldn't find the schematic for this module, nor I could identify the circuit...
                                            06-03-2025, 01:21 AM
                                          • dbuergi
                                            Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                                            by dbuergi
                                            i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                                            Any ideas where to look?...
                                            11-07-2024, 10:57 AM
