switch mode supply transformer, leads to nowhere
  • jojo69
    • Nov 2015
    • 25
    • US
    Stumped troubleshooting a Cetek battery charger here. I am pretty weak on switch mode supplies.
    There were 2 terminals on the transformer that were open to any other xfmr nodes so I figured that was probably the problem.
    Unwound the xfmr and actually those leads just go a couple cm in next to shield wrap layers and end...what the actual *&%#?
    I pine for the days of simple pass regulated linear supplies where I understood what was going on. Can anyone explain what is going on here?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: switch mode supply transformer, leads to nowhere
    Clear focused pictures of both sides of the pcb and a clear description of what is wrong or not working with the battery charger helps us help you.
    --- begin sig file ---
    --- end sig file ---
    • Joe Black
      eager to learn
      • Sep 2015
      • 173
      • southeastern europe
      I find THIS GUIDE to be on-spot, short and to the point when it comes to basic troubleshooting SMPS.
      stay classy
      • jojo69
        • Nov 2015
        • 25
        • US
        Sorry if I was not clear guys, I have pretty much given up on this one, having unwound the transformer,. I am just trying to learn at this point.
        This was really a more general question about these nodes to nowhere. All I can figure is that they provide some sort of sense signal of current in the transformer?
          'There were 2 terminals on the transformer that were open to any other xfmr nodes so I figured that was probably the problem.' If we see the pictures of the board we probably can tell if those two pins are not used. You might as well upload the pictures if you want to learn how this power supply functions.
          • jojo69
            • Nov 2015
            • 25
            • US
            lol, OK, it is in a few pieces at the moment
            • jojo69
              • Nov 2015
              • 25
              • US
              OK, got back to the bench.
              First one, top of board, input to the left, the stuff outside the heatsinks is pretty conventional.
              2nd one bottom side input
              3rd one bottom side output
              4th, unwound XFMR, yu can see the short wire I am asking about
              5th here it is taped back down with the shield layer ready to go back over it
              edit/ hold on, I'm getting 500 from the server
              • jojo69
                • Nov 2015
                • 25
                • US
                trying again
                • jojo69
                  • Nov 2015
                  • 25
                  • US
                  and the xfmr
                    Can you please show the pictures of the whole board, top side and the bottom side?
                    • jojo69
                      • Nov 2015
                      • 25
                      • US
                      thanks for the answer!
                      not without dismounting both heatsinks, all of the input; fuse, thermistor, rectifiers, choke and caps are hidden under the input switcher heatsink on the left. Most of the output filter is hidden under the other one.
                      I will do that next bench session
                        So far it looks like the primary side has two windings, the secondary side has one winding with center tap to feed the full wave rectifier diode D14 (dual diode common Cathode).
                        • jojo69
                          • Nov 2015
                          • 25
                          • US
                          Sorry about that, those heatsinks take a frightening amount of heat to get off. The input side was not so bad because I had it off before and just tacked it back on, but the output sink was a bear...2 iron job, need 3 hands.
                          I hope these views work better
                          • CapLeaker
                            Leaking Member
                            • 8300
                            I have a few of those Ctek's. Not one of them has failed yet. Having said that, with my luck I'll go in the garage later and everything is dead. What was wrong with it first place and how long did you have used it?
                            Not too long ago, I posed a thread repairing a Motomaster switching battery charger, as water went into it somehow.
                            • jojo69
                              • Nov 2015
                              • 25
                              • US
                              bunch of the input side silicon was failed short, 2 diodes, a zener and the switcher as I recall
                              replaced all that and it worked for a day, now something else is wrong with it
                                Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 05:30 AM
                              • Natob82
                                Micro Momentary Push Switch?
                                by Natob82
                                Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                12-21-2022, 05:22 AM
                              • grimacelord
                                NEC TurboExpress On/Off Power Switch Replacement Help
                                by grimacelord
                                I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                11-09-2023, 09:49 AM
                              • SluggerB
                                Help making a switch work the opposite way with a relay
                                by SluggerB
                                I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                02-07-2025, 07:57 PM
                                Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                by sam_sam_sam
                                Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                ( needs more cam circuits for the machine to work correctly again )
                                https://www.ebay.com/itm/275321870186
                                To
                                3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                ( not 4 positions but the right amount of cams circuits )
                                https://www.ebay.com/itm/274660439950
                                I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                03-18-2023, 05:12 PM
