OCZ 700 Watt Bug Zapper Recap & Repair
    • 31259
    Re: OCZ 700 Watt Bug Zapper Recap & Repair
    yes, it's critical in that application.
    you need equal or higher ripple.
    go look at something like panasonic ED or EE series.
    and if you have the height, consider 390uf
    • manthi
      • Feb 2014
      • 39
      • canada
      ok thanks, going to check that
      • Behemot
        • 4845
        • CZ
        Originally posted by manthi
        add $8 shipping and you start crying,
        but everything is relative
        this morning i went to a local electronic store to see if they had anything that would fit, but i came back empty handed,
        but got a $168 ticket +3 points for failing to do a complete stop.
        so in the end that $15 with digikey is a bargain versus driving to my local store
        ok back to topic, original cap has 1.9 ripple and the one i listed has 1.44 does it matter?
        I can get it much cheaper. But its always the same…you dont need it so foten after all, you need it fast, you whatever. So I invest at least 500 bucks in that, than sell 10 pcs here and keep the rest on stock for 5+ years till I sell it out finally…nah, not really. You want, than buy it overpriced.
        What series is that teapo crap? I can find no 330/400 with 1.9 A RC.
        • manthi
          • Feb 2014
          • 39
          • canada
          LH
          also can someone explain me why it's ok to go with a 390 uf instead of 330, i always read that you should stick with same capacitance when replacing a capacitor
          • Behemot
            • 4845
            • CZ
            Oh I see, noticed just the 1.75A version.
            You can go with 390 just fine, you'll get less stress on PFC silicon and longer hold-up time. But the cheapest seems to be https://www.digikey.ca/product-detai...965-ND/3986864, for 390 https://www.digikey.ca/product-detai...1663-ND/483261
            • manthi
              • Feb 2014
              • 39
              • canada
              #26
              ok thanks, went for https://www.digikey.ca/product-detai...1663-ND/483261
              • manthi
                • Feb 2014
                • 39
                • canada
                #27
                ok some update,
                i replace the defective 330uf 400v capacitor (funny when i shake it i can hear moving part inside) by the one i bought (390uf 400v from panasonic) but still no power.
                so after some more reading (link given by sgtrock+ one of his post on eevblog) i found out that a TNY278P (IC501) switching regulator could have gone bad, and indeed after close inspection, i realise it has a blown leg,
                so i got to change this also.
                i also checked the q601\602 mosfet but they are ok
                • SgtRock
                  • Feb 2012
                  • 175
                  Good work Manthi. Get er done.
                  Cheers!
                    • 31259
                    i have *never* had or heard of a capacitor that has anything moving in it.
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Are you sure?
                      http://320volt.com/en/cakma-kondansator/
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                        • 31259
                        lol
                        that's better than the original, it's got rubycon in it.
                        • SgtRock
                          • Feb 2012
                          • 175
                          Dear Kaboom"
                          --The British used to say that if you locked a bunch of Hong Kong merchants in a cave for twenty years, when you opened it they would have all gotten wealthy by selling rocks to each other.
                          "Does not squirell crack nuts on bough of tree."
                          La Fu (ancestor of Wun H. Lo and his brother Tu H. Lo) 1610 -1780
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #33
                            Please dissect the capacitor and post some pics of it's innards.
                            I guess a capacitor that has dried up completely inside could rattle around a bit.
                            Still it should be a minimal difference vs a cap filled with electrolyte...
                            Never seen or heard of something like this before so I'm curious
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              I have seen (or rather heard) this quite often with lead-acid batteries. Guess that snap-in caps with big cans can to it too, there is often some room inside between the roll and the top part of the can. If you remember that opened cap from the welder I posted here and it measured fine, the roll inside was moving if you shaked it enough
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                #35
                                i have a lelon 4700@50 i replaced in a rockford fosgate boom car amp.
                                if it hasnt hit the dumpster yet i will dissect it.sounds like a marble rolling around inside.its mate on the - supply is normal.replaced anyway of course.
                                • manthi
                                  • Feb 2014
                                  • 39
                                  • canada
                                  #36
                                  ok will try to do it this week, any special precaution to take before doing this, i never opened a capacitor, what is the proper procedure?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #37
                                    Cut the sleeve, than usually cut the aluminium can by the the rubber sealing (or you may try to pry it out using small screwdriver). Remove the rubber and than the foil roll should go out. Or cut the can more to remove it.
                                    Just be carefull to not cut yourself.
                                      • 31259
                                      use sidecutters to peel the edge of the can away from the rubber bung.
                                      it may hiss when you first cut into it if pressure has built up.
                                      • manthi
                                        • Feb 2014
                                        • 39
                                        • canada
                                        #39
                                        here it is
                                        i think it was the paper roll that was moving inside
                                        • manthi
                                          • Feb 2014
                                          • 39
                                          • canada
                                          #40
                                          oups!!
                                          received my TNY278P (IC501) switching regulator this morning, so i installed it,
                                          but as soon as i turned the power on, i heard a bang and saw some sparks inside the psu, the same part (ic501) had blown again, so i have to find what cause this
                                            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                            by momaka
                                            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                            http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                            What mostly drew me into buying it is its 2x PCI-E power connectors...
                                            03-29-2022, 11:34 PM
                                          • chth96
                                            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                            by chth96
                                            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                            Since then, This AC/DC adaptor have been out of order.
                                            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                            And Is there any possibility that it will suddenly explode as well as to be out...
                                            12-03-2023, 04:40 AM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                            GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                                            65 Watt Multiple Output Global Performance Switchers
                                            Condor Part Summary
                                            • 65 Watt Wide Range Input
                                            • High Efficiency (Up to 90%)
                                            • Universal input 90-264 Vac
                                            • 2-year warranty
                                            • Also available in single outputs
                                            • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                                            • Exempt from line harmonics standard EN61000-3-2
                                            • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                                            • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                                            10-07-2024, 05:46 AM
                                            Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                                            So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                                            The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                                            You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                                            09-07-2024, 07:26 PM
