OCZ 700 Watt Bug Zapper Recap & Repair
  • Sparkey55
    • Jan 2010
    • 1523
    Re: OCZ 700 Watt Bug Zapper Recap & Repair
    Originally posted by manthi
    oups!!
    received my TNY278P (IC501) switching regulator this morning, so i installed it,
    but as soon as i turned the power on, i heard a bang and saw some sparks inside the psu, the same part (ic501) had blown again, so i have to find what cause this
    You should be using a series light bulb tester to reduce the voltage to the power supply. It would have saved the chip from utter destruction. Since the psu still has a short circuit the voltage would have divided between the bulb and the psu with the bulb having the greater voltage across it.
    • Behemot
      • 4845
      • CZ
      #42
      The voltage is not the most important aspect. The current limiting which the small-wattage bulb provides is important. A 60W bulb at 230 V has about quarter ampere going through which most power silicon handles.
      • Sparkey55
        • Jan 2010
        • 1523
        Your nit-picking is quite annoying and uncalled for. With a shorted psu most if not practically all the voltage will be across the brightly lit series bulb with only a few volts across the psu. We are assuming a supply source of 120 VAC. So if for istance the bulb sees 115 VAC and the psu sees 5 VAC well then the tester is doing its job.
        • Behemot
          • 4845
          • CZ
          #44
          You never know what is the internal resistance of shorted PSU…there are always losses on the silicon (bridge rectifier etc.), thermistor and so on. But it is never so close to zero.
          Initially the voltage on the bulb is very low, if the current is high than it heats the filament and as its resistance increases it takes most of the voltage. But it still lowers the maximum current (usually the initial resistance is couple tens of ohms) so much the unit is able to withstand it for the short time before the current drops to minimum.
          • Sparkey55
            • Jan 2010
            • 1523
            You just amaze me Sherlock.
            • manthi
              • Feb 2014
              • 39
              • canada
              #46
              here's a picture of the regulator i soldered yesterday
              can someone tell me if i fucked up, on the red arrow i notice i made a connection between the diode and the regulator leg,
              what does the white line underneath means (no connection?)
              • Behemot
                • 4845
                • CZ
                #47
                I think it should be connected, otherwise the pin would be severed from the rest of the path. According to datasheet it is drain, those four common are source. But the diode may have been already bad. Or something else. Now when it exploded you have to check every component in that circuit, something else may went bad during the blast.
                • manthi
                  • Feb 2014
                  • 39
                  • canada
                  #48
                  thanks for the input,
                  i did some more testing and found 2 mosfet 20n60c3(q701 q702) when i set my multimeter to 200 homs, i get 5.5 between the gate (pin 1) and the source (pin 3), it means it is shorted no?
                    • 31259
                    maybe, did you test them on the board, or removed first?
                    • manthi
                      • Feb 2014
                      • 39
                      • canada
                      #50
                      on the board
                      now i removed them, and i did this test
                      http://itrepairguide.com/how-to-test...th-multimeter/
                      when i connect the black probe to the drain and red probe to the source i get a reading of 623 (continuity setting) on both mosfet, but when i try to charge them up, black probe to drain, red to gate for a few seconds, when i move the red probe to the source, i do not get any beeping, and the multimeter give me a value of 127 (both mosfet)
                      i try this on a working fu9024n, and it is beeping.
                      what do you make of this?
                        • 31259
                        leave it for now and go meter the pads on the board.
                        • manthi
                          • Feb 2014
                          • 39
                          • canada
                          #52
                          not sure what you want me to do with the pads, you means the pads the mosfet connects to the pcb?
                            • 31259
                            yes, see if the short is still there.
                            • manthi
                              • Feb 2014
                              • 39
                              • canada
                              #54
                              ok i see, thanks for the clarifications, at the moment i put that psu aside , i am going to get back at it after the chrismass season.
                              have fun everybody
                              • Behemot
                                • 4845
                                • CZ
                                #55
                                I got the same model here, 700W. Similar situation: input cap was bad, I've replaced it. No big transistor or rectifier seems shorted. Stand-by rail outputs 5.16 V so that's OK, but it only twists when I try to turn on. Repeatedly. Lightbulb in series indicates no problem.
                                It's Sirtec platform for sure. I was also first thinking the FETs are bad, but they have 4R7 resistor between their gate and source pins which I think explains it. Or should I remove them as well to be sure? It would make sense something else was damaged because of the failed bulk capacitor…
                                  KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                  by momaka
                                  For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                  http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                  I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                  What mostly drew me into buying it is its 2x PCI-E power connectors...
                                  03-29-2022, 11:34 PM
                                • chth96
                                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                  by chth96
                                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                  Since then, This AC/DC adaptor have been out of order.
                                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                  And Is there any possibility that it will suddenly explode as well as to be out...
                                  12-03-2023, 04:40 AM
                                  ASUS P5GC-MX motherboard recap
                                  by momaka
                                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                  So here is what the motherboard looked like with its original caps:
                                  CPU VRM area up close…...
                                  01-27-2021, 11:59 PM
                                  GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                                  65 Watt Multiple Output Global Performance Switchers
                                  Condor Part Summary
                                  • 65 Watt Wide Range Input
                                  • High Efficiency (Up to 90%)
                                  • Universal input 90-264 Vac
                                  • 2-year warranty
                                  • Also available in single outputs
                                  • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                                  • Exempt from line harmonics standard EN61000-3-2
                                  • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                                  • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                                  10-07-2024, 05:46 AM
                                  Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                                  So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                                  The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                                  You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                                  09-07-2024, 07:26 PM
