FSP200-60ATV. Worth repairing?
  • Scorpent
    • Sep 2015
    • 27
    • Singapore
    G Day,
    Recently I got this PSU from a friend of mine. When I received it, it was fully functional, voltages within spec.As time passed, it's been acting up funny like turning off randomly or refusing to turn on. Now, it wont turn on at all. If you short the green to black quickly will will make the fan turn or receive power less than 1 sec. STBY voltage is normal at 5V. So what you guys think? Capacitors screwing up?(no bulged caps) Screwed IC? If i'm missing any info, feel free to ask me.
    I only have basic tools for repairing and my soldering skills ain't best.
    Thanks in advance.
  • R_J
    • 9633
    Re: FSP200-60ATV. Worth repairing?
    Is it worth repairing, Not really, You can usually find higher wattage units for free, but if you are going to try and repair it you might try checking some of the small low value caps in the primary circuit, they are usually around 4.7-22 uf and around 50v, they can go bad and won't bulge, and cause the main power supply not to start up.
    • everell
      • Jan 2009
      • 1514
      I am of the opposite opinion. This is why. This power supply has a good input filter - most cheap power supplies don't. This power supply has pi filters on the output. Much better than the cheap power supplies. This power supply has a large switching transformer for a 200 watt power supply. It should hold its power with little ripple. If you decide to fix it, here is a hand drawn schematic of the pwm circuitry.
      If you decide to fix it, it will out perform many of the cheap power supplies, such as the IMicro 400 watt bargain basement power supplies. Buying one of these cheap power supplies for a replacement is only asking for trouble.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • Scorpent
        • Sep 2015
        • 27
        • Singapore
        Sorry guys, almost forgot, that resistor(see pic) heats up quite toasty if it runs.
        • delaware74b
          • Apr 2009
          • 628
          IF you do decide to recap, get rid of that yellow glue as it turns conductive when heated. The glue around that resistor is starting to turn brown (=conductive).
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Worth repairing?
            - That depends on how valuable your time is. Overall, though, I would say that it is worth repairing, especially if you want to learn or get better with repair. Moreover, everell is completely right here: don't judge this PSU by its power rating. Just because it is only a 200 Watt power supply doesn't mean it is wimpy. I've seen "higher-rated output" power supplies that aren't really much better than this, especially the really cheap ones (which are actually often much worse).
            The label on this power supply states it can do 10 A on the 12 V rail. This should be enough for a somewhat modern, basic PC with a single HDD, onboard video/audio, and a low-power processor - something such as Core 2 Duo with less than 70 Watts TDP. It should also work okay with socket 462 Athlon XP/MP and Duron/Sempron. DO NOT use with Pentium 4 or Pentium D.
            Now, as far as the problems you are having with this PSU, there are several things that could have gone wrong: an output rectifier can be shorted, bad output caps, or some of the small caps around the logic circuitry are bad.
            Start by checking the output rectifiers. You will need a multimeter for this. Set to the lowest resistance scale (usually 200 Ohms for manual multimeters) and measure the resistance between each of these:
            orange wire and ground (black wire)
            red wire and ground
            yellow wire and ground
            Let me know what you get. "Dummy" load resistors can affect those readings above into making us think that something is shorted on the output, be we can weed those out. The hot resistor which you pointed to is likely one of those "dummy" load resistors.
            Also, if you can post more pictures of the secondary side and its caps (the side with the output wires) as well as a picture of the solder-side of the PSU, that would tremendously help with the troubleshooting process.
            The fact that you have 5 V standby already brings some hope for this PSU.
              • 31304
              old FSP supply's are really good.
              although i'v never seen one under 300w before.
              i refuse to believe those are the original output caps btw, they always blew the tops open on the teapo's pretty fast.
              • Scorpent
                • Sep 2015
                • 27
                • Singapore
                Originally posted by momaka
                Worth repairing?
                red wire and ground
                Okay thanks momaka, Here's my findings:
                Ground to:
                Orange(3.3v) 8Ω
                Red(5v) 15Ω
                Yellow(12v) Around 92Ω-95Ω
                My cheap multimeter doesn't give a too accurate result so accuracy at about +-5Ω
                Pictures are attached. The bodged wire was not done by me or my friend.
                • Scorpent
                  • Sep 2015
                  • 27
                  • Singapore
                  Fact : Brand new from the factory. Never replaced. I guess Teapos were once an okay capacitor or just plain luck. (So far, I have seen no blown Teapos.)
                    • 31304
                    luck.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Teapos often do fine in power supplies if the cooling is ok and they are not subjected to too much ripple due to the design.
                      If you do decide to fix it just a small warning: probably it has no overheat protection like my old NX-3000 PSU which seems to be pretty much the same PSU.
                      So some kind of monitoring of the fans RPM or circuit that simply cuts the "power ok" signal if it becomes too hot would be good.
                      See here what happens otherwise when you fix a perfectly good PSU and the fan control PCB decides to die a few months later:
                      https://www.badcaps.net/forum/showth...=5050#post5050
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Well, the pictures still aren't very clear. But I guess it doesn't matter. I can see that there are several dummy load resistors wrapped in black sleeves, and that's probably why the resistance readings you got are a bit low. But nothing too out of the ordinary. So the only thing I can tell you at this point is that you should probably just recap the entire PSU first - every single electrolytic capacitor except for the two big 200V ones on the primary side.
                        If that doesn't fix it, then we dig in deeper. Of course, if you think it is worth it.
                        • Scorpent
                          • Sep 2015
                          • 27
                          • Singapore
                          Hmm, in that respect, I may scrap it as I don't have enough cash or time to recap the whole thing. Thanks anyway. What do you suggest to take from the psu?
                          • Scorpent
                            • Sep 2015
                            • 27
                            • Singapore
                            There was a thermometer for fan control, but it runs too slow to even move a decent amount of air.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Keep it for parts. Maybe eventually you'll find a bad PSU or other electronic device that has good caps and can then fix this PSU. Or alternatively, you might find use for some of the parts in this PSU to fix other electronics. I had a really and cheap nasty PSU that I kept for parts. And even with that, I was able to fix more than 5 other items with it (3 of them being other proprietary or good quality power supplies).
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • iMic
                                Vintage AT Power Supplies - Selecting Capacitors
                                by iMic
                                Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                02-19-2023, 06:45 PM
                                09-06-2024, 05:59 AM
                                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 02:15 PM
