Zyxel PSU
  • diif
    • Feb 2014
    • 6978
    • England
    Zyxel PSU
    Obvious why this switch has failed !
    Should I be replacing with a DC or AC cap ?
    I have a choice of three is it's a DC cap. Which one would you buy ?
    http://uk.rs-online.com/web/p/alumin...itors/7152303/
    http://uk.rs-online.com/web/p/alumin...itors/7260729/
    http://uk.rs-online.com/web/p/alumin...itors/6997559/
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8665
    Re: Zyxel PSU
    Pics or it's not broken...
    • 999999999
      • Sep 2006
      • 774
      Re: Zyxel PSU
      1) I am assuming you have a zyxel network switch that stopped working because the power supply for it failed.
      Any of those 3 capacitors you linked should work, but I wouldn't get the Rubycon because it's excessively priced. It does not need to be an AC capacitor as it is rectified to DC by one or more diodes before that capacitor in the circuit,but this should be obvious by looking at the original capacitor, looking up how it is rated.
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Zyxel PSU
        Ahhh, missing photos, seems the uploading failed last night.
        Here we go.
        I bought a lot of 10 faulty assorted gigabit switches. I have Netgear, HP, Dell and a lovely Belkin.
        Obvious failures in most of the power supplies although one of the small Netgear switches is down to a damaged DC socket.
        Thanks 999999999 i ordered the Panasonic.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Re: Zyxel PSU
          • goodpsusearch
            • Oct 2009
            • 2848
            • Greece
            Re: Zyxel PSU
            L O L
            • diif
              • Feb 2014
              • 6978
              • England
              Re: Zyxel PSU
              Haha, liking that.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8665
                Re: Zyxel PSU
                Bipolar/AC capacitors should say "BP" on them or look like they're completely symmetric minus having possibly a dot on which pin is the outside foil. If there's a band of any kind it's a unipolar DC capacitor.
                I don't know if there are any recent usage for bipolar electrolytic these days - perhaps other than audio crossovers and even then people probably prefer some other method for separation. Induction motor AC caps aren't electrolytic - and bipolar electrolytic capacitor ESR is not that great... if not outright bad...
                Oddly enough I've never tested the ESR on a bipolar cap, I'd think these would be pretty bad?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Re: Zyxel PSU
                  Cheers eccerr0r.
                  I'm hoping the parts will be here later today, i'll update one i've fitted it.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8665
                    Re: Zyxel PSU
                    Hmm... I have a ~70KHz analog ESR meter that measures (NOS unless indicated):
                    Nichicon 2.2uF/50V BP 2 ohms
                    Illinois Cap 22uF 35V BPRM 0.5 ohms
                    Symphony Asuno 2.2uF/50V NP 2.5 ohms (hey... that Nichicon is better!)
                    Matsushita 33uF 16V BP Y 1 ohm (PULL)
                    Matsushita 33uF 16V BP Y 0.8 ohm (PULL)
                    CapXon 1uF 250V NP ~6 ohms (PULL)
                    Richey 16uF 50V ~0.4 ohms (PULL)
                    Hmm some of them are comparable to small polarized caps after all. I thought these bipolar caps are usually made by putting two polar caps in inverse-series which means ESR will be doubled...
                      • 30931
                      Re: Zyxel PSU
                      i notice the capxon is worst - what a surprise.
                      bipolars are usually a lot larger than a polarised equiv cap though.
                        master hoarder
                        • May 2008
                        • 12164
                        • Bulgaria
                        Re: Zyxel PSU
                        That picture just made my day!
                        And maybe NASA should put some CapXon caps in their thrusters to get an extra "boost" at liftoff .
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Re: Zyxel PSU
                          Just to update, replaced the cap and the bridge rectifier and the switch is back to working.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8665
                            Re: Zyxel PSU
                            Also note the worst one is also only 1uF (due to my ~70KHz meter, it may make a difference), and also highest voltage (250V) so the ESR might be a bit higher for this one just because...
