Grid feed inverter ticks every second
  • japlytic
    • Oct 2005
    • 2086
    http://youtu.be/UXxFtxTUIis
    Could this be the inverter compensating as it feeds into the grid?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: Grid feed inverter ticks every second
    I've got a 10kw Fronius inverter and it doesn't tick like yours every second.
    • eccerr0r
      A modified sine wave inverter + a grid tie inverter?
      by eccerr0r
      If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
      Next thing is trying to charge the batteries using solar power, but that's another issue ...
      08-31-2023, 09:14 PM
    • x_orange90_x
      Vizio E55-E1 bad backlights or bad inverter?
      by x_orange90_x
      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
      I don't know how exactly to test the inverter itself. Is it...
      01-29-2025, 09:24 PM
    • valvashon
      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
      by valvashon
      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
      01-04-2024, 01:44 PM
    • caseyjay_48
      Sony KDL-46BX450 Inverter Troubleshoot Logic
      by caseyjay_48
      I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
      I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
      09-23-2022, 08:08 PM
    • mitsu2k
      Power-One solar Inverter driving me NUTS!!!
      by mitsu2k
      Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
      Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
      There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
      All relays are good.
      I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
      11-13-2023, 07:19 PM
