PSU worth replacing caps?
  • mikay786
    • Aug 2014
    • 765
    Struggling to decide whether it is worth replacing some caps in a PSU I have or would it be too risky to use again in system?
    Concern being if it blows and wipes out the system.
    I got it with a PC, seller witnessed it go fizz, pop, smoke and shutdown. I got it and its actually still working, made a buzzing noise when I plugged it in but subsided after a few seconds and ran fine for a few hours.
    Had a look inside a can see 3 caps that look bad, see pics below.
    PSU is a Topower Top-1100W modular PSU, so a decent unit.
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: PSU worth replacing caps?
    That supply should be worth recapping but it will not be easy. It would be important to pick the correct replacements and get them from a reliable source. Do not buy them off Ebay and you need to match the specifications of the original capacitors.
    The reason it will not be easy is that it most likely has a double sided PCB so you need a really good soldering iron to tackle this job. Also if your soldering experience is limited you need to practice before trying to tackle this job.
    For future reference you should post a power supply questions in the Power Supply Design and Troubleshooting section of this forum.
    • c_hegge
      • Sep 2009
      • 5219
      Agreed. I'd have no hesitations about recapping a PSU like this and using it in a PC. If you do a complete re-cap with entirely Japanese caps, You will actually end up with a PSU that is more reliable and less likely to fail than a brand new one.
      EDIT: see https://www.badcaps.net/forum/showpo...&postcount=274
      and
      https://www.badcaps.net/forum/showpo...&postcount=283
      That thing was in far worse condition than yours, and I have it in almost daily use in a PC now after repairs.
      • retiredcaps
        • Apr 2010
        • 9271
        Ahh, more Capxon (aka Crapxon) bad capacitors. I love them because I get all sorts of free stuff from owners who toss out the non working computers, TVs, etc.
        Easy fix (unlike troubleshooting a TV main board) with the soldering iron and some new caps.
        --- begin sig file ---
        --- end sig file ---
        • mikay786
          • Aug 2014
          • 765
          Thanks guys for all of the responses, puts my mind at ease. And noted regarding correct section.
          I've done some recapping before on a motherboard which turned out well.
          I have a Duratool desoldering station / gun which works well and was reasonably priced. It paid for itself fully with the repair on a motherboard I did.
          Not done a PSU before but will post on here and will order caps from badcaps.
          Will I get away with just doing the 3 leaky caps or will I have to do all of them?
          • mikay786
            • Aug 2014
            • 765
            Also I have a bit of a irrational fear (probably not irrational) of messing with internals of a PSU.
            Just to confirm PSU should auto discharge after a few hours? and secondly its only the two large caps that you need to be careful with? So what would be the best and cost effective way of discharging the two large caps to be double sure?
            • c_hegge
              • Sep 2009
              • 5219
              A few minutes is usually all it takes. If you want to make sure it's discharged, you can just short the two terminals of the big PFC cap with a screwdriver or a wire. It might spark a bit if the cap has some charge left, but doing so will almost instantly discharge the cap. Just don't do it while the PSU is plugged in.
                • 31092
                if you have a meter, just meter the large caps to check for residual voltage.
                replace all electrolytics oher than the mains ones,
                caps dont always bulge when they are failing.
                post a list of the caps,
                list:
                the designation on the pcb,
                the make, series, diameter, voltage and u.f.
                then the best replacements can be worked out.
                • mikay786
                  • Aug 2014
                  • 765
                  Measured with voltmeter and appear to be discharge, touched a screw driver across them just to be sure and seems fine to handle now.
                  Ill have to remove them to get a proper look but have removed pcb from casing to get a better look.
                  The 3 dodgy looking ones are all capxons
                  Capxon 10v 2200uf
                  2 x Capxon 16v 3300uf
                  and other which appear ok but you can see in pics, ill remove them over the next couple of days to get a better look
                  • c_hegge
                    • Sep 2009
                    • 5219
                    As stj said, Replace all of the caps on the secondary side, even if they aren't yet bulging, as they won't be far off it.
                    As for replacements, badcaps.net doesn't carry anything that is a suitable replacement.
                    For the 2200uF 10V caps, you could use either Rubycon YXJ from RS components (see http://uk.rs-online.com/web/p/alumin...itors/7497142/) or Nichicon HE from element 14 (http://uk.farnell.com/nichicon/uhe1a...tor/dp/1823552), both of which are UK based suppliers.
                    If you have any 3300uF 10V or 6.3V caps, you have two options. Ruby ZJL from element14 (http://uk.farnell.com/rubycon/6-3zlj...rad/dp/2346439). You can also PM our member "Behemot" and get Chemi-con KYA 3300uF 6.3V caps. (note that you can safely replace 10V caps with 6.3V caps, as they will only be on the 5V or 3.3V rail)
                    For the 3300uF 16V, you would have to get Behemot to supply them (either Samxon RS or NCC KZN), as he is the only one I know of who sells 3300uF 16V caps in 10mm diameter. Annoyingly, though, he doesn't sell any 2200uF caps, otherwise, I'd suggest getting everything from him. You may get away with replacing the 2200uF caps with 3300uF, but not all PSUs will play nice with it.
                    EDIT: This thread has been moved to the appropriate forum.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Another option for 6.3V 3300uF caps is Panasonic FK:
                      http://uk.farnell.com/panasonic-elec...rad/dp/1744878
                      Double the price of the ZLJ, and the spec is probably only half as good. The difference between ZLJ and FK is aqueous vs non-aqueous electrolyte. Some people prefer non-aqueous caps.
                      But I also recommend Behemot. And c_hegge mentioned using 3300uF instead of 2200uF. Absolutely you can do this. Regarding the 16V 3300uF cap, Behemot sells two options as c_hegge mentioned. I highly recommend the KZN over the Samxon RS for this application, because your PSU will probably need the extra ripple suppression. Just keep in mind it is a 40mm long cap, so you might have to do some maneuvering to get it in.
                      • mikay786
                        • Aug 2014
                        • 765
                        Wow WHAT a difference a good clean tip makes! Struggled with first two, tip was a little charred so swapped with a new one a the rest were a breeze. Cant recommend these desoldering guns enough. There were a couple more tiny ones which are quite difficult getting to which ive left. So we have
                        A) 2 x Toshin Kogyo 3300uF 10v (UTWKZ)
                        B) 1 X Toshin Kogyo 2200uF 16v (UTWKZ)
                        C) 2 x Capxon 3300uF 16v (C725)
                        D) 1 x Capxon 2200uF 10v (C723)
                        E) 2 x Samson 2200uF 10v (SGF)
                        F) 1 x Samson 470uF 16v (SKM0702)
                        G) 1 X Samson 220uF 16v (SKM0702)
                        H) 1 x Samson 2200uF 10v (SGF0702)
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Yup. I'd suggest sending Behemot (https://www.badcaps.net/forum/member.php?u=15285) a PM. I've ordered caps from him a few times before.
                          • Stefan Payne
                            • 1267
                            I think you mean:
                            'replace all the caps', not just on the secondary side...
                            I'd rather not risk using any old cap in an almost 10 Year old unit (and I woudn't use them in a modern system due to rippelastic load of modern components)...
                              • 31092
                              primary smoothers are expensive - your right about changing them, but the price deters people.
                              mikay - you didnt list the cap diameters: 5mm, 6.3mm, 8mm, 10mm, 12mm etc.
                              • Behemot
                                • 4845
                                • CZ
                                KYBs 2200/16 are on the way though it is getting somewhat longer. I expect them by late august/beginning of september.
                                • mikay786
                                  • Aug 2014
                                  • 765
                                  A) 2 x Toshin Kogyo 3300uF 10v (UTWKZ) D 10mm H 30mm
                                  B) 1 X Toshin Kogyo 2200uF 16v (UTWKZ) D 10mm H 25mm
                                  C) 2 x Capxon 3300uF 16v (C725) D 10mm H 30mm
                                  D) 1 x Capxon 2200uF 10v (C723) D 8.2mm H 25mm
                                  E) 2 x Samson 2200uF 10v (SGF) D 10mm H 20mm
                                  F) 1 x Samson 470uF 16v (SKM0702) D 8.2mm H 15mm
                                  G) 1 X Samson 220uF 16v (SKM0702) D 6.2mm H 10mm
                                  H) 1 x Samson 2200uF 10v (SGF0702) D 8.2mm H 30mm
                                  Would it be possible to source suitable caps from say Farnels as is local to me?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Originally posted by mikay786
                                    H) 1 x Samson 2200uF 10v (SGF0702) D 8mm H 30mm
                                    This is for real? Could you get me some clear sharp pictures when you remove it from the unit?
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      see attached
                                      • mikay786
                                        • Aug 2014
                                        • 765
                                        regarding D & H
                                        See fit in board and space left behind
                                        • Noodneek
                                          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                          by Noodneek
                                          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                          08-30-2024, 12:52 PM
                                        • kotel studios
                                          TAGAN TG380-U01 PSU - 5v shorted after replacing caps
                                          by kotel studios
                                          Hi
                                          Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
                                          Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
                                          02-14-2025, 10:10 AM
                                        • bulkchart32
                                          are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                                          by bulkchart32
                                          nichicon
                                          1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                                          are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                                          05-14-2025, 02:12 PM
                                        • Delicieuxz
                                          Replacing caps in an old speaker system. Should I use a higher value here?
                                          by Delicieuxz
                                          I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
                                          https://youtu.be/1LRIzePlma0?t=273
                                          I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
                                          Would 680uF be good value to try in place of the 470uF originals?
                                          06-25-2023, 08:27 PM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
