Um, wow. Just, wow.
    • 31281
    Re: Um, wow. Just, wow.
    i did until the rubber sleeves on the rollers melted
    one day i will build one for fun - i have a huge trackball from an atari missile-command arcade machine.
    i just need new bearings and shafts for it.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      How did the sleeves melt?
      Permanently Retired Systems:
      Kooky and Kool Systems
      sigpic
        • 31281
        something effected the rubber.
        i'v seen it happen to other things too.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          We're you using the mouse when you smelled melting rubber and realized it was the mouse?
          sigpic
          • SteveNielsen
            Retired Tech
            • 2327
            The rubber was probably degraded over time from the acids in skin oils.
              • 31281
              i'v seen it happen to joypad-caps, tv-remote backs, screwdrivers ec.
              it's probably interaction with skin-oil.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I use PS/2 on one of my 3 workstations (the beefy twin CPU kind)... because it only has two USB's in the back and that it seems POST a lot slower with USB + legacy support enabled. My other two have four USB's in the back so they have USB keyboards; one has a really special one too, the one microsoft made with a fingerprint scanner, with 3rd party x64 drivers/patched software.
                sigpic
                (Insert witty quote here)
                • Before Work
                  • Jul 2015
                  • 5
                  Originally posted by stj
                  screws on the left side, look in the grill.
                  it's got a passive-pfc choke.
                  Please punctuate as taught instead of typing like some lazy 2nd grader. The shift key isn't there for decoration. ")
                  • Fr3shGy
                    • Mar 2015
                    • 47
                    3.5 K Watts? What da hell?
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Only on the sticker...
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #31
                        or deet.
                        btw thats a huntkey unit and just acceptable as a 250w.
                        • NotEnough
                          Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                          by NotEnough
                          I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                          What I've Tried So Far:
                          • Reseated the cables.
                          • Reinstalled AWCC and AlienFX services.
                          • Attempted BIOS downgrade but no improvement.
                          • Inspected ribbon cables for damage.
                          • Explored the possibility of BIOS or
                          10-19-2024, 01:34 AM
                        • Deby
                          List of compatible laptop motherboards
                          by Deby
                          This is a list of compatible laptop motherboard information that I have been collecting for some time.
                          And it's still ongoing.
                          Every time I come across information that a board is compatible with another, I write it down.
                          Anyone who wants to, can continue to expand the list.
                          Packed in the rar, is an excel table that has additional information.
                          Motherboards.rar...
                          05-31-2024, 04:34 AM
                        • m4a2t0t
                          BD35231 compatible replacement
                          by m4a2t0t
                          Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
                          Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
                          Thanks for any help...
                          08-28-2025, 08:32 PM
                        • taurtnt
                          Help identifying AMCH073 regulator or finding a compatible replacement
                          by taurtnt
                          I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
                          Here’s what I’ve observed:
                          • It has a QFN-16 footprint, similar to NB670.
                          • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
                          • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
                          • Pin 8 also seems to be tied to the same GND plane.
                          • The chip only says AMCH073, no manufacturer logo or other markings....
                          08-24-2025, 03:06 PM
                        • zwect
                          RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
                          by zwect
                          I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
                          07-21-2025, 05:53 PM
