Snubber in LiteOn PS-5281-7VR
  • everell
    • Jan 2009
    • 1514
    I have recently acquired a LiteOn PS-5281-7VR 250 watt atx power supply. This is the second LiteOn power supply I have seen with an electrolytic capacitor in the snubber circuit. Capacitor value is 2.2 uF/450 volts. Measured capacitance is 1.98 uF and esr is 8.0.
    So what's the beef? Every other power supply I have looked at has a ceramic capacitor in this circuit. Seems like an electrolytic in this location is just asking for trouble. The first one I saw had a bulging capacitor. Replacing the capacitor fixed the power supply. This one is not bulging, and the power supply is operational.
    I thought that the proper value would be more like .1 uF, which is one tenth of the value. Here are some pictures and a drawing of the snubber. What do you think?
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Snubber in LiteOn PS-5281-7VR
    Was the bulging capacitor an LTEC by any chance? Or a Chemi-con, Nichicon, Rubycon, or something? Or OST or Taicon? Since most of those brands aren't esteemed and don't deal well with stress.
    • everell
      • Jan 2009
      • 1514
      The bulging cap incident was a few years ago, so I don't remember the brand. I only remember that it was unusual to see an aluminum electrolytic capacitor in this circuit. And I still think it is unusual......and maybe a time bomb.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        What were the symptoms of the power supply that had this cap failed? Just refused to power up or unstable power? Or ticking? I'm just curious because I have a few LiteON PSUs as well. I think one or two of them are still in service.
        And yes, an electrolytic in that spot almost seems like planned obsolescence. Or just poor design.
          • 31015
          is the polarity marked on the pcb?
          maybe it was designed for a film cap and they decided the electrolytic was cheaper.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            everell is right. This is not random at all. Lite on does that.
            See this thread for example:
            https://www.badcaps.net/forum/showth...331#post377331
            There is a 2.2uF 400V capacitor among the big pink resistor and the mosfet. That cap has gone high esr and I replaced it back then with 2.2uF 450V Nichicon PW if I remember correct.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              +1
              Looks like they might have not had enough room to put a film cap in.
              I do agree, a film or ceramic cap would be better.
              I'm not a PSU design expert (I want to be one some day though :P), but I think that is normal. I've seen some with 10nF caps, up to 1 or 2uF!!! And I've seen some with varying snubber resistor values, from 33K up to 100K, or maybe more. Hm, I don't recall them well enough to see if there is a relationship between either the frequency, topology, DC bus voltage, or wattage, and the capacitance/resistance.
              -Ben
              Muh-soggy-knee
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                I guess I will be looking at my LiteON PSUs when I get back home. Might even try a little experiment. I'm thinking, just open up one of my STF HiPro or Bestec PSUs and just copy the snubber circuit from that.
                Now let me go out a bit with my bike today. I saw a few busted TVs two days ago on the side of the road here. Could definitely come in handy for the parts .
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  good luck momaka!
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                  • CMCM
                    Russound CA4 Power Supply Repair
                    by CMCM
                    Hello Everybody,
                    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                    The outputs marked 12v and 20v are all measuring only 1v.
                    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                    The capacitors physically look clean (no bludgesor leaks) and...
                    07-03-2025, 01:12 PM
