Snubber in LiteOn PS-5281-7VR
  • everell
    • Jan 2009
    • 1514
    I have recently acquired a LiteOn PS-5281-7VR 250 watt atx power supply. This is the second LiteOn power supply I have seen with an electrolytic capacitor in the snubber circuit. Capacitor value is 2.2 uF/450 volts. Measured capacitance is 1.98 uF and esr is 8.0.
    So what's the beef? Every other power supply I have looked at has a ceramic capacitor in this circuit. Seems like an electrolytic in this location is just asking for trouble. The first one I saw had a bulging capacitor. Replacing the capacitor fixed the power supply. This one is not bulging, and the power supply is operational.
    I thought that the proper value would be more like .1 uF, which is one tenth of the value. Here are some pictures and a drawing of the snubber. What do you think?
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Snubber in LiteOn PS-5281-7VR
    Was the bulging capacitor an LTEC by any chance? Or a Chemi-con, Nichicon, Rubycon, or something? Or OST or Taicon? Since most of those brands aren't esteemed and don't deal well with stress.
    • everell
      • Jan 2009
      • 1514
      The bulging cap incident was a few years ago, so I don't remember the brand. I only remember that it was unusual to see an aluminum electrolytic capacitor in this circuit. And I still think it is unusual......and maybe a time bomb.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        What were the symptoms of the power supply that had this cap failed? Just refused to power up or unstable power? Or ticking? I'm just curious because I have a few LiteON PSUs as well. I think one or two of them are still in service.
        And yes, an electrolytic in that spot almost seems like planned obsolescence. Or just poor design.
          • 31163
          is the polarity marked on the pcb?
          maybe it was designed for a film cap and they decided the electrolytic was cheaper.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            everell is right. This is not random at all. Lite on does that.
            See this thread for example:
            https://www.badcaps.net/forum/showth...331#post377331
            There is a 2.2uF 400V capacitor among the big pink resistor and the mosfet. That cap has gone high esr and I replaced it back then with 2.2uF 450V Nichicon PW if I remember correct.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              +1
              Looks like they might have not had enough room to put a film cap in.
              I do agree, a film or ceramic cap would be better.
              I'm not a PSU design expert (I want to be one some day though :P), but I think that is normal. I've seen some with 10nF caps, up to 1 or 2uF!!! And I've seen some with varying snubber resistor values, from 33K up to 100K, or maybe more. Hm, I don't recall them well enough to see if there is a relationship between either the frequency, topology, DC bus voltage, or wattage, and the capacitance/resistance.
              -Ben
              Muh-soggy-knee
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                I guess I will be looking at my LiteON PSUs when I get back home. Might even try a little experiment. I'm thinking, just open up one of my STF HiPro or Bestec PSUs and just copy the snubber circuit from that.
                Now let me go out a bit with my bike today. I saw a few busted TVs two days ago on the side of the road here. Could definitely come in handy for the parts .
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  good luck momaka!
                  • hikomalek
                    SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                    by hikomalek
                    Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                    When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                    Transformer:
                    |Info| Primary | Aux | AB | CD|
                    |Ratio|1|25|40|12|
                    |Voltage AC|230V|9.2V|5.8V|19V|
                    |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                    I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                    09-19-2025, 03:30 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
