Fortron FSP300-60GLS: starts/spins/dies
  • goriath
    • 9
    Hi everybody,
    I own this PSU, FSP 300-60GLS but is not working. As soon as I power the PSU on the fan starts but immediately stops afterwards, nothing else happens. In my experience this is a classic for a PSU.
    Initially I opened the PSU and I got two brand caps; while the majority are OST there are two CrapXon as well. The very fisrt thing I noticed was a cap slightly bulged, CapXon 2200uF 6.3V. Other caps are in perfect cosmetic conditions but since the CapXon are crap, just for troubleshooting, I decided to replace both with what I had available at the moment, two KSC same capacity but 10V. Nothing changed.
    Now, the question is very simple. I should keep to replace all the caps with good ones? There is any chance that this problem involves caps or is it about something else?
    Thank you in advance
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Fortron FSP300-60GLS: starts/spins/dies
    Originally posted by goriath
    Hi everybody,
    It could be caps. Also, if you are testing this without anything else connected, it might be because it needs a minimum load. Don't use anything you want to keep, like a good motherboard, to load it. I use lightbulbs and resistors. I do have a dual channel constant current load, but it can only do 150W per channel.
    Muh-soggy-knee
    • goriath
      • 9
      I always start PSUs with a minimum load like fans or FDDs, this was also the case but the PSU's fan stops immediately to spin anyway...
      I think that even if others caps are apparently in good condition, maybe some of them are failing and need to be replaced anyway, or at least I hope so. But I wanted discuss the issue first to, eventually, buy new caps for nothing.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Well it's impossible to say if new caps would definitely fix it. If it doesn't work, you could always un-solder them and keep them for use in something that works.
        -Ben
        Muh-soggy-knee
          • 31246
          replace the small ones.
          and look real hard, those FSP supplies often have caps hidden inside heatshrink tubing.
          • goriath
            • 9
            Absolutely true. Those Fortron PSU need also special size caps, those very slim 8mm caps, damn...
            Vey true. I found two sleeved caps, one CapXon and one OST, those closest the heatsink; cannot told what they were until I cutted the sleaves.
            If I'm not wrong until now I have localized these caps:
            x8 OST 1000uF - 16V RLP
            x2 CapXon 2200uF - 6.3V KF
            x2 OST 22uF 50V RLG
            x1 tiny OST unknown capacity and voltage - RMH series - I cannot tell more since the only way to know is desolder it - it is the smallest one
            What do you mean for small ones? 22uF and the unknown tiny one?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Yeah, probably the 22uF, and any other 5mm or 6.3mm diameter caps. Probably in the range of 1uF to 47uF.
              Muh-soggy-knee
                • 31246
                if you need 8mm then look at panasonic FK series.
                • goriath
                  • 9
                  The tiny cap turned out to be 2.2uF 50V - I noticed one thing, I don't know if it is relevant but on the top of this cap there is a little sign of a bluish substance, I don't know if it is a leak or whatever; the first time I saw it I didn't give it so much importance since I thinked it was a sign of a blue marker that sometimes you find on caps. I attached a picture of it:
                  I started to replace this but, again, nothing changed.
                  Must try with the two 22uF but I have only one replacement for these in this moment.
                  Thank you for the hint.
                    • 31246
                    the blue is ink from a pen,
                    you often find caps marked by the factory for whatever reason.
                    • goriath
                      • 9
                      I decided to try to replace all caps with good ones.
                      The caps I have to replace are:
                      x2 CapXon 2200uF 6.3V KF series - 8mmx25mm
                      x8 OST 1000uF 16V RLP series - 8mmx20mm
                      x2 OST 22uF 50V RLG series - 5mmx10mm
                      x1 OST 2.2uF 50V RMH series - 4mmx7mm
                      Do you have good alternatives (like nichicon, rubycon or similar...) for these?
                      P.S. I searched for Panasonic FK; I found FR instead...are they good as well?
                        • 31246
                        FR are best, but sometimes you cant get one physically small enough.
                        for really small values like 1uf and 2.2uf you may have to use FC series because i dont think FR come smaller than 4.7uf.
                        atleast not last time i looked.
                        • goriath
                          • 9
                          OK I found from a single shop:
                          2.2uF from Panasonic FC series (5x11mm) <- how about FC?
                          22uF from Panasonic FR series (5x11mm)
                          1000uF from Nichicon HM series (8x20mm)
                          2200uF from Nichicon HM series (8x20mm)
                          For less than 20 euro shipped
                          How good is this selection?
                          P.S. I don't know if I can ask here (if not, don't mind) but where can I buy good caps here in europe (I live in Italy)?
                            • 31246
                            Europe, Farnell is good.
                            http://it.farnell.com
                            why the nichi's ?
                            • Behemot
                              • 4845
                              • CZ
                              I have NCC KZH 1000/16 D8 and KZN 1500/6,3 D8 especially for these SFX units and also standard GLN. This si just GLN (Blue Storm II) in smaller package. Have a box filled with these units here, all of them have caps bloated hard. Nichicon Hm are no way for power supply.
                              stj: you are omitting me on purpose or why are you still pushing Farnell which is three times as expensive as me?
                              • Bungz
                                • May 2013
                                • 133
                                There becomes a point where buying a brand new version of this PSU (they are not £) would also be easier as defeatist as that may sound, you do not know for certain that caps are the problem with your unit.
                                  • 31246
                                  you dont have a website / stocklist.
                                  or do you????
                                    • 31246
                                    but then you still have to recap it because the new psu's have such shity caps you cant trust them to last more than a couple of years.
                                    i have recapped several new psu's so they can be trusted afterwards.
                                    • goriath
                                      • 9
                                      why the nichi's ?
                                      I selected the nichi only because they are the only 8mm caps available from the shop I found - but yeah, I think they aren't so good afterall.
                                      Unfortunately farnell has the same problem for 2200uF capacity; they have only those HM nichicon for 8mm diameter.
                                      Yep. Since you seem know this PSU, do you have a good cap selection for this PSU recapping?
                                      Obviously your POV as people that tipically consider this kind of work is not worth it is absolutely legit. Well, I think that if I replace those caps with good ones I can have a better PSU for an affordable price afterall and the trouble of getting the PSU work again is something I have already considered and to which I am willing to. But you are absolutely right when you say that I don't know if the caps are the problem or not, so I must find spare replacement first to buying a good kit of caps (I'm looking in the stuff I have at home, old motherboards and similar...).
                                      Indeed, what you said is what I think too.
                                      I forgot to say that I got this PSU for free, so I'm willing to have some "fun" with it.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        or do you????
                                        https://www.badcaps.net/forum/showthread.php?t=39123
                                        http://www.hwworld.cz/index.php?opti...ory&Itemid=102
                                        goriath: yep, those KZH 1000/16 and KZN 1500/6.3. I have already done one unit to check everything works. You can squeeze a 6pin PCIe in there with little drilling, that's what I've done. Needs at least a single hard drive to have some output on +5 V rail otherwise it does not handle heavy crossload well (group regulated, modern systems with SSD draw close to nothing @ +3,3/+5 V rails).
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • arabex21
                                          Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
                                          by arabex21
                                          Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
                                          I have a problem with this configuration:
                                          ASUS PRIME B450M-A
                                          RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
                                          When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
                                          09-19-2024, 03:05 AM
                                        • master3112
                                          Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
                                          by master3112
                                          I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
                                          UT5 pin 3 (SNK_PS_EN) =0V
                                          RPT3 Pin1+2 LDO 3V3 present
                                          I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
                                          08-02-2025, 12:30 PM
                                        • Shobos
                                          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                          by Shobos
                                          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                          Any help is welcome. Thanks !
                                          07-29-2025, 03:53 PM
                                        • JohnML1975
                                          LG 49UK7550PTA - after couple of hours screen starts to blink
                                          by JohnML1975
                                          Hello Forum team
                                          Have this TV; searched for the model and could not anything so thought I would share in here
                                          Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
                                          Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
                                          So I removed the covers, and could not see anything visibly
                                          Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
                                          07-25-2025, 10:48 PM
