New caps on stock
  • Behemot
    • 4845
    • CZ
    New caps on stock
    New caps arrived - Nippon Chemi-Con KZH 1000 uF/16 V in D8x20 mm (EKZH160ETC102MH20D). Finally a suitable replacement for those D8 crapxons in PSUs and some high-capacity replacement for craps in displays! Pricing coming soon, they forgot to send me invoice…well not that I would complain
    Other than that, I have samples of Rubycon YXJ 33 uF/50 V, the only low-ESR 33uF/50V caps in D5x11 mm! Anybody would be interested in these? I need other caps as well and as the distributor wants money-in-front for the first order, I have to choose which ones I will order, I don't have money for all.
  • Behemot
    • 4845
    • CZ
    Re: New caps on stock
    The price is on the web. I should also get (tomorrow or on monday) 100 pcs of NCC KXJ 10 uF/400 V in D10x16 mm, suitable into set-top boxes, satellite receivers, small SMPS AC-DC adapters, LED lights etc.
    • Behemot
      • 4845
      • CZ
      I got 135 pcs of those KXJ 10/400 D10x16 after all
      I am also able to get Rubycon MFZ 2700 uF/6,3 V ATM.
      • Behemot
        • 4845
        • CZ
        NCC KYA 3300 uF/6,3 V D10x25 mm on stock, 1000 pcs, bagged packing (no ammo-belt!).
        • Behemot
          • 4845
          • CZ
          Rubycon MFZ 2700 uF/6,3 V on stock!!
          • Behemot
            • 4845
            • CZ
            Nippon Chemi-Con KZN 3300 uF/16 V D10x40 mm on stock now!!!
            Nippon Chemi-Con KZN 1500 uF/6,3 V D8x20 mm on stock now!!
            Nippon Chemi-Con KXJ 150 uF/400 V D18x40 mm on stock now!
            • Behemot
              • 4845
              • CZ
              Rubycon YXJ 220 uF/25 V D6,3x11 mm on stock now!!
              • Behemot
                • 4845
                • CZ
                Here are some images. Note the KYA 3300/6,3 are samples with worse font quality, actual product from ordinary manufacturing line is as should be, consistent with NCCs font type.
                • Behemot
                  • 4845
                  • CZ
                  NCC KYA 1000 uF/25 V stock is running low, I have ordered KYB with slightly lower ESR and higher ripple current. KZH 680 uF/16 V D8x15 mm are also being manufactured ATM.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    I have ordered some 1000uf 16v 8mm d Kzh off you, are they suitable for motherboards ?
                    • Behemot
                      • 4845
                      • CZ
                      They are not motherboard grade, but such are not being made anymore. If that is on the input side of VRM (=output from PSU), it should work. Compared to Rubycons MBZ it is not that far.
                      However, I would not recommend overclocking or any similar way of increasing the VRMs load.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        I was going to swap the from ucc kzj to ucc kzh, I may just use the kzes I have on order.
                        • Behemot
                          • 4845
                          • CZ
                          The KZE are almost the same as KZH, the difference in ESR is only minor. Those are too power supply caps, not motherboard. But such are often used on VRM input (while sometimes there are ultra-low ESR caps instead) so it should be OK with both. Definitelly better than bulging caps
                          Got some new caps on stock, NCC KZH 680/15 D8x15 and KYB 1000/25 D10x20 instead of KYA as they have lower ESR and higher current.
                          More new caps being manufactured!
                          • Behemot
                            • 4845
                            • CZ
                            Got more KZH 1000/16 so no problem with supply. Also the RUbycons LLE 3,3/400 D8x11,5 mm.
                            But KYA 680/35 have run out, KYB 680/35 D10x20 mm are on their way (gonna get them in september or so).
                            • Behemot
                              • 4845
                              • CZ
                              All caps have been moved to Bonanza, see the news http://www.hardwareinsights.com/wp/c...one-with-ebay/
                              Maybe the most exclusive ones will be re-listed on eBay in time, but I would prefer you using Bonanza if you have to use such service in the first place as you can contact me directly and soon e-shop will be finally started (at least in testing mode).
                              As for capacitor news, I am getting some new samples around next week and in a few weeks new models will finally arrive.
                              • Behemot
                                • 4845
                                • CZ
                                New caps available! Finally got the KYB 680/35 D10x20 mm, KZH 1200/6.3 D8x15 and KYB 2200/16 D10x30 mm.
                                The KYB 2200/16 have 2.5times the life of Panasonic FK and compared to Distrelec I have them for 1/4 the price. Still going to buy overpriced crap? Digi-Key has these too, two times more expensive than me.
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  Nice!
                                  You know I need these but can't place an order for a while.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Yeah np. BTW I won't be selling on fuckbay again, they even wanted me to prove my card for fees again? They kidding? First, I don't want to give them my card at all, pricks, but german does not accept paypal. I don't even want german fuckbay registration at all but the idiots don't let you change that! So it will be all yours to sell on.
                                    BTW colleague told me we got 180 days for PP claim so he started one. After 11th we can escalate, so far nobody responded.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Colleague of mine is going to Fermilab again so if you guys in US want some caps or anything else he can take with him let me know! You got a week.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Dirty cheap KYB 1500/16 D10x20 and KZN 100/35 D6.3x11 mm have arrived!
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
