Yep, I definitely have a soft spot for these old Macron's. But they're very respectable units. This one, when I got it, had seen better days. Even the Power Logic ball bearing fan was getting tired. Just about every cap in this thing failed. They only consist of 12Kuang Jin and CEC International. I can't really blame the CS caps too much for failing, their date codes are all from January, 2003 and the unit saw about 55,000 hours of running time in a very hot office with an Athlon XP machine. Every filtering cap was CS, and every single one was bulged and leaking except oddly enough one (Not pictured...) The 470uF 25V one on the 5VSB auxiliary tested perfect, 472uF 0.02Ω ESR. All the CEC caps tested good, but they only ranged from 1-22uF 50V. I replaced them all anyways.
Another strange thing, the two input caps were CS 680uF 200V. They both looked like they were bulging underneath the plastic discs over the top. Sure enough, they were. However....they tested perfectly in spec. ~720uF 0.13Ω ESR. Do you think they were tricking my meter? I ended up replacing them anyways. I upgraded the 12V rectifier from the stock 16A ultra fast to that 30A schottky. 12V runs very strong. It could handle a Pentium 4 3.6GHz and 9600GT under full load all day long and stay at a firm 12.16V compared to 11.83V before with the same load. I also noticed that the snubber resistor on the primary was cooking the film cap for the switchers. Since I have so many lying around, I replaced the 1uF stock one with a 2.2uF part. I also removed the primary heatsink to tighten the screws.
I also moved around or replaced the minimum load resistors on the 5V and 3.3V. 12V didn't have one, so didn't have to worry about that. The ones on the 5V and 3.3V were way too low. I can't remember exactly but I think the new ones I put on the 5V and 3.3V were 100Ω. One of the stock ones was 22Ω and the other 47Ω
Also replaced the stock fan with that oiled sleeve bearing fan and added a SATA power cable. It's very silent even under heavy load. The thing looks great now!
						 Those are the ones I was referring to. They too were bulged once I pulled out the plastic pieces, but they too, tested in spec on my meter.
