Coolermaster Recap
  • Neo2_000
    • Apr 2005
    • 180
    Coolermaster Recap
    Hey Guys,
    Need some advice from the electronic engineers amongst you.
    My PC went flaky last night.
    The fan had failed on the PSU and half a dozen caps were bulging.
    It's not a cheapie and has served well for 4 years so I am hoping to redeem it.
    I have the correct value caps except for the two new blue Ruby's under the heatsink beside the coil.
    The originals were 680uF x 16V Capxons.
    Would it be OK to use 1000uF x 16V as replacements here?
    I am hoping precise values are not critical.
    Thanks in advance for your help.
    Brett.
    • 31032
    Re: Coolermaster Recap
    what series of caps are you fitting?
    blue ruby's are mcz arent they?
    • Neo2_000
      • Apr 2005
      • 180
      The two blue Ruby's are MBZ series.
        • 31032
        well the esr on those is way to low for a psu.
        you need something like a panasonic FC,FM,FK or FR preferably FR
        mbz should only be used on stuff like motherboards.
        • Behemot
          • 4845
          • CZ
          PX are general purpose, not good for SMPS. I can provide you with Samxons RS 3300/16 and Chemi-Cons KYA 3300/6,3, both D10. Than I have KZH 1000/16 D8.
          • c_hegge
            • Sep 2009
            • 5219
            1000uF caps will work fine there. And yes, Ruby PX are indeed unsuitable for PSU use. They might work OK for a bit, but it will make the ripple much worse, and they won't last as long. Use Panny FK if you need 2200uF 16V in 10mm diameter (http://au.rs-online.com/web/p/alumin...itors/0571606/)
            Also, replace the other two CapXons there, as they won't be far off failing (and may well have already failed without visible showing it these would do fine for them - http://au.rs-online.com/web/p/alumin...itors/7083572/
            • Neo2_000
              • Apr 2005
              • 180
              Thanks for all your help guys. Seems I sure could use it. I have been using mobo series caps without realising these were unsuitable.
              Just had a bright idea. I no longer recap motherboards and have quite a lot of mostly Ruby's, some Saxon's and Nichicons in popular mobo values. I live in Australia.
              Would anyone be interested in doing a swap or alternately purchasing these? (see attachments)
              Here is what I need for my current project but I really should stock up on PSU repair caps now so would be interested in acquiring more.
              Coolermaster Power Supply Unit (Originals were Capxons)
              Looking for quality replacements such as suggested Panasonics etc.
              10mm x35mm
              2- 4700 x10V
              2- 3300 x10V
              4- 2200 x16V
              10mm x20mm~
              2- 2200 x10 short
              8mm
              4- 680 x16
              Thanks again,
              Brett.
              • c_hegge
                • Sep 2009
                • 5219
                I'm pretty sure I actually have all of the values you need. I'll check again. By the way, no one actually makes 4700uF 10V caps in 10mm diameter. Someone here actually tested some brand new ones and they were only about 3300uF, so you can safely replace the 4700uF caps with 3300uF 6.3V. I've done it on a similar PSU to yours before.
                EDIT: Nope. I don't have enough 2200uF 16V or enough 680uF 16V caps. Looks like I'll have to order some more just in case I get another PSU to recap in the near future. I just noticed, though, that looks like the MBZs you used are on the -12V and 5vsb rails. You can get away with it there. It's more likely to be a problem if you use them on the main rails from which feedback is taken (and even then, some PSUs aren't all that picky). It's the PXs which I'd be more concerned about.
                I'm in a pretty similar boat to you when it comes to motherboard recaps, though. These days, the only boards I see with bad caps are pre-C2D era, which are too old to be worth fixing or keeping.
                • Behemot
                  • 4845
                  • CZ
                  You can use Samxons RS there just fine…
                  There are still some 754, 939, AM2(+) boards with bloated caps you can use that for, but not really many. They often get bad because of chipset anyway.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Not necessarily. Some PSUs will be fine with bumping up the capacitance to 3300uF. Some won't. I've had some PSUs where the feedback loop becomes unstable at high loads (200W+) with Samxon RS 3300uF caps on the main rails. My rule of thumb is that you can bump up the capacitance on really cheap PSUs (as the low capacitance is only used to save cost, not because anything is tuned to it). On a decent PSU like this, though, leave the capacitance as it is on the main rails.
                    • Neo2_000
                      • Apr 2005
                      • 180
                      I was baulking at ordering from RS Components but now I see that they are offering free delivery for Australia?
                      Any strings attached to this?
                      If not, I might give it a go.
                        • 31032
                        usually there is a minimum order value for free delivery
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Nope. It's just free delivery for all online orders, no questions asked. I order from RS all the time. Element14 also have free delivery, but only for orders over $50.
                          • Neo2_000
                            • Apr 2005
                            • 180
                            RS sells in lots of 5 so it would be good to be versatile.
                            Cap voltages generally range from 6.3V to 16V.
                            Assuming we maintain the minimum voltage spec for a given cap, is there any downside to ordering say five 16V caps to cover lower voltage caps of the same uF value?
                            • Neo2_000
                              • Apr 2005
                              • 180
                              https://www.mikesarcade.com/cgi-bin/...e=psrepair.txt
                              Hey, what do you guys think of this. For an engineering illiterate like myself, I found it to be great info.
                              I am just wondering how pertinent it is today as it is a bit dated. At least it answered my question:
                              Remember, you can always substitute a capacitor of higher voltage when replacing filter capacitors. E.G. A 1000 microfarad, 16 volt capacitor
                              can be replaced with a 1000 microfarad, 25 volt.
                              But also this: (What are your thoughts?)
                              I recommend that you order just two different capacitors for use as replacements for the output filter capacitors in the "Peter Chou" style power supply. It helps a great deal when you have the part numbers. For the +5 VDC output, use 3300 microfarad, 16 VDC capacitors. The Nichicon part number is UVX1C332M. Each power supply requires two of these.
                              To make ordering and stocking easier, I use the same capacitor for both
                              the +12 VDC and the -5 VDC outputs. It's a 1000 microfarad, 25 volt
                              capacitor. The Nichicon part number is UVX1E102M. Although some power
                              supplies use a 2200 microfarad capacitor for the +12 VDC output, I have
                              found the 1000 microfarad to be perfectly satisfactory.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Re: Coolermaster PSU Recap Help
                                A code on the transformer shows that it was manufactured in 2006, so a lot older than 4 years old.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • Behemot
                                  • 4845
                                  • CZ
                                  Depends on the units, some can only take D8 caps, some D10.
                                  I can send ya some Samxons RS 3300/16 D10x30 (those you can use instead of 6,3V too as they have same size) and KZH 1000/16 D10x20 mm if you want. These would do for complete recap of this unit you have.
                                  • Neo2_000
                                    • Apr 2005
                                    • 180
                                    Yeah, was wasting space at work for quite a while till I swapped it for a coral trout
                                    I had replaced the fan once on this but four years service life is better than average.
                                    Speaking of which, any recommendations for a quality fan which will go the distance?
                                    Preferably an Australian source please.
                                    • Neo2_000
                                      • Apr 2005
                                      • 180
                                      Sent you a PM Behemot.
                                      • Neo2_000
                                        • Apr 2005
                                        • 180
                                        Looks like they have finally caught up with the 21st century. Would never order from them in the past because freight was a killer.
                                        Doesn't look like they have the higher values I need in a 10mm can though unfortunately.
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                          no-name Radeon 9600 XT recap and cooler
                                          by momaka
                                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                          This one was actually suggested to me by ChaosLegionnaire....
                                          11-06-2020, 07:54 PM
                                        • varunviolin007
                                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                          by varunviolin007
                                          Hi guys,
                                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                          Looking for someone experienced with older PC boards who uses...
                                          07-29-2025, 11:53 PM
                                        • Foetuss
                                          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                          by Foetuss
                                          Hi all
                                          Hope this is in the correct place.
                                          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                          Could use some double checking to see if I'm not doing something stupid .
                                          Pictures of the boards are attached.
                                          What I will be replacing with what : (planned)
                                          Soltek Golden ::
                                          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                          01-18-2025, 11:44 AM
