Chinese Power Supplies some good some bad (problem solved! :) )
  • Hagis2k
    • Jul 2006
    • 66
    Anyway i thought i share the problems i had with a cheap chinese power supply i did buy:
    I was in need for a power supply for my small Sony netbook style mini laptop,
    so i bought one that i thought should be "decent" but buying from china is like a lottery lol!
    So anyway i got the power supply like a week ago and when i plugged it in the little laptop started behaving very strangely locking up touchpad not responding so i was like wtf now i unplugged the new psu.
    And the laptop started working like normal so then i just decided to look how the dc voltage looks like grabbed the oscilloscope and i was a bit shocked at first glance i thought i did something wrong when i measured it was just WAY to much spikes and noise:
    But it gave me spiked and noise like mad i even tried changing the capacitors on the secondary side without any change so i gave up was thinking of putting an inductor between the capacitors on the output to try to suppress the spikes.
    No input filter emi/rfi poorly built and since i don't own a insulation transformer at the moment but i shall wind one my self soon, i didn't feel for measuring the noise on the switch transistor probably that one who causes it shall save the unit until later and play with it a bit.
    Some pictures of the power supply:
    Notice the RHOS text hahaha chinese people they can clone anything
    I quickly sketched up the secondary side for fun c10/c11 are not 3nF but the rest of the values should be correct.
    So anyway i did crack another laptop charger open and took it a part looking around in the circuit and i found a voltage divider that at 19V left pin2 with 2.5V so i did some basic calculations and figured out that if i place a 14K resistor on R60 place:
    R60 is 16.5Kohm here
    R60 changed to 14Kohm
    Changed the capacitors as well (and lol i see the little hole in the solder on one cap i fixed it after the pic was taken. same with the cables)
    So at last correct voltage 0.26V over what i did calculate so not to bad and the laptop is happy now
    So this did work now i have a power supply that feeds 16.76V out instead of 19V changed the cable and now everything works just fine.
    So cheap chinese power supplies can be both win / fail lol
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Chinese Power Supplies some good some bad (problem solved! )
    What do the o'scope pix look like after the mod?
    • iMic
      Vintage AT Power Supplies - Selecting Capacitors
      by iMic
      Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
      The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
      02-19-2023, 06:45 PM
    • valente222
      help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
      by valente222
      Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
      05-12-2025, 03:42 PM
    • itsthatidiotagain
      CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
      by itsthatidiotagain
      CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
      There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
      I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
      A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
      06-23-2025, 03:22 AM
    • EazyBone
      Onn 100044717 Black screen 75 *Solved
      by EazyBone
      Got this ONN 100044717 75 inch TV which shows a black screen when turned on. In a dim room or if you take a flashlight too it you will still see a picture. TV has sound also.
      The defect is the power board capacitor near the backlight connection. It is the same defect. Look for a bulged cap. Read this thread for more info as it's same defect.
      https://www.badcaps.net/forum/troubl...solved-70-inch
      03-31-2025, 12:23 PM
    • NanoTesting
      Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
      by NanoTesting
      This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
      Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
      02-21-2025, 12:33 AM
