Cyberpower PR1500 won't charge battery
  • Agent24
    I see dead caps
    • Oct 2007
    • 5096
    • New Zealand
    #121
    Re: Cyberpower PR1500 won't charge battery
    Sometimes chips will go faulty and overheat by themselves.
    -David VanHorn
    • electronicsuk
      • Oct 2019
      • 5
      #122
      Indeed, although probably not this time. I forgot to mention on my first post thay I also replaced the optocoupler on the SMPS. I've just checked back at some photos I took of the PCB before I started, and it looks like the opto should be a Cosmo K1010C. I've fitted a K1010B. The datasheet shows the 1010B has about 50% of the current transfer ratio of the 1010C, so I suspect it's an issue with incorrect feedback to the Viper.
      I suppose this is karma for my lazy repair technique - if I'd spent more time fault finding than replacing lots of components that *might* be the problem, I probably would never have replaced the opto in the first place!
      Sadly I can't easily get a 1010C in the UK so I've had to order some from China. I'll report back with how I get on. Will probably replace the Viper as well, just in case the thermal overload has caused any damage.
        • Jul 2011
        • 6070
        Check and make sure that you do not have a short some where in battery charging circuit or circuits that might why you are seeing the charging current going up and down might be the reason that the Viper 22A is running hot or it could a bad chip however if change it and still run hot I would looking for something low ohm short
          Can we see good clear pictures of the whole top and bottom side of the board?
            BTW, you should also make new thread since your model is not the same as OP.
            • SamNorbin
              • Apr 2013
              If someone has a schematic for a PR2200LCDRT2U, please share it. I tried using the PR1500E/2200E/3000E service manual schematic (from page 1 of this discussion) but my unit's circuitry is significantly different. The PCB silkscreen says it's for the "PRII 1000/1500/2200". Various components have 2008 date codes.
              • CamilliLa
                • Oct 2016
                • 8
                Another update. I last posted in 2016 about reviving my second PR2200 by replacing C40. [Replacing the five "usual-suspect" capacitors in my first PR2200 didn't fix it.] {I picked up two supposedly refurbished PR2200s on eBay; both defective, but with new batteries. Got a refund.} My second PR2200 failed again a few months ago. I dug out the extra capacitors that I bought in 2016; if it doesn't work, these things deserve to be recycled. These things should NOT have to be repaired every five years. The charging circuit doesn't last as long as the batteries do. [Reliable power would be nice, but that's not going to happen...]
                • redwire
                  • Dec 2010
                  • 3912
                  I don't know what value or function C40 is. What make of capacitor did you use a replacements?
                  The power supply runs 24/7 which is 8,640hrs per year, if you're using say 3,000hr parts well 5 years life is fine. The temperature is up there too in the 30's, worse if there is a shorted cell and it's stuck in high-rate charging.
                  • CamilliLa
                    • Oct 2016
                    • 8
                    So, what, exactly, is the purpose of a UPS? People use them to provide reliable power to things like computers that have uptimes of 25 years. If your electronic device has a very short life because of internal heat, maybe it needs better cooling. If it's designed with a critical component that will fail so quickly that the device won't outlast its batteries, maybe the component should be in a socket so it's easy to replace. [Or, maybe it should be like a "Flashcube" that rotates as each flashbulb is used up, sliding the next one into place.]
                    The person I compared notes with said that his oldest APC UPS is 21 years old. He's replaced the batteries multiple times on multiple units. Apparently, it is possible to design a UPS that'll outlast its batteries.
                    As far as I can tell, Cyberpower contracted out to some company in China to design and manufacture these things. They made no provision for ECOs as they learned how they fail. They made no provision for repairs. [They refuse to provide any service information to customers. There are service manuals circulating on what seems pretty much like a black market - and the manuals are inaccurate.]
                    I'd settle for them being honest and admitting that these things aren't designed to last more than five years, so potential customers can decide if they want to go another way.
                    Of course, eventually, their reputation would make it impossible for them to continue in this business, and they'd have to branch out, perhaps making PCs or something (which involves nothing but assembling commodity componets and slapping a brand name on the outside). -Wait a minute...
                    People have criticized Keurig for all of the trash that their coffee makers generate. But, how many of these unreliable UPS units are in landfills or sitting in corners, unused?
                    • rotohammer
                      • Jul 2022
                      • Hungary
                      #130
                      I just changed out C42 on my OR1500LCDRTXL2U that would not power up without batteries. Now it does power up without batteries, and its charging them fine.
                        • Jul 2011
                        • 6070
                        I would go headed and replace all the capacitors on this board that are around the area where you replace the capacitor because those capacitors might be questionable also and for good measure
                        • CamilliLa
                          • Oct 2016
                          • 8
                          Problem solved. I had four PR2000s (two new; two "refurbished" - new batteries; untested; neither charging the batteries). In one, I replaced the capacitor-most-likely-to fail and got a second three years out of it. On the others, I changed the five caps identified here. Most never revived; all were dead by about six years. Changing those capacitors didn't help.
                          After speaking with the guy with the server farm in his house and many APC UPSes (the oldest of which is 21 years old), I bought a refurbished APC commercial model (not for consumer use, which seems to mean not FCC-compliant for interference). In addition to the UPS, I bought an external battery pack to extend battery time. The external pack actually contains two of the packs like what's in the base, so I've now got three hours of battery time for my AlphaServer. [I can attach 10 external packs for a LOT of battery time.] I have it set to run self-test once a week, so when the batteries fail, I'll know - before there's a power failure. [Hot-swap OK.] Presumably, if the charging circuit fails, I'll know. It can run in pass-through mode - in which the charger charges the batteries as the batteries feed an inverter to supply power or I can run it in standby mode (like those Cyberpowers), which is a little more efficient.
                          It cost about what the new Cyberpowers cost - and has a better warranty. And, I could have paid more for a warranty that's the same as the actual lifetime I got from the longest-lived Cyberpower UPSes.
                          I still have some smaller Cyberpower UPSes around the house. One, less than a year old, has an intermittently-blinking power-on light. [I found a YouTube video that claims that the glue that Cyberpower used on some components becomes conductive with age, which causes more failures within the UPS.]
                          The PR2200s were a huge waste of time and money. [I recycled what I could.] Never again.
                          By the way, the AlphaServer has two power supplies, so I was a able to move it from an outlet to the "new" UPS without stopping it. Next step is to duplicate the APC UPS so I can have each power supply plugged into its own UPS, with each UPS on a separate line (on alternate sides of the 240/120 split) - for even more reliability.
                          • gquiring
                            • Jan 2023
                            CyberPower 1350AVR won't charge
                            I have a 1350AVR that works except for charging. I replaced the batteries, pulled the power to drain them, restored the power and they are not charging.
                            There is burnt area on the board, pictures are enclosed. The area in question is near the U3 chip and diode.
                            • gquiring
                              • Jan 2023
                              I got a better photo of the chip - VIPer22A for the 1350 UPS. Any ideas on that diode next to it? I am not sure what I should replace.
                                • Jul 2011
                                • 6070
                                One thing about changing the VIPer22A ic chip replace the capacitor next to it as well for good measure
                                You might want to check the optic sensor right next to the capacitor that I also talk about earlier
                                If you replace the diode next to the ic chip that you are replacing when installing the new leave a small space between the board and the bottom of the diode when replacing it
                                Also check an make sure that you do have a short on the wires going to the battery if not then see if you have voltage on the wires to the battery with out the battery connected
                                • Alc0pone
                                  • Feb 2023
                                  Guys, I need your help, I was changing the capacitors on the board of my PR2200 and did not see that a piece of the cut-off pin got on the pins of the P7NK80ZFP transistor. The first turn on of UPS was bright😁
                                  Of course, this transistor died immediately. Zener diode D103 and the nearby resistor R135 are also dead.
                                  In my opinion, the UC3845B PWM controller has also failed; there is a trace on its body as if from an electric shock. The resistor R101 next to it also looks bad.
                                  I have several questions for selecting replacements for failed components, I would be grateful if you can help:
                                  1. Values and sizes of resistors R135, R101 and R143
                                  2. Voltage of zener diode D103
                                  3. Is there any way to check the functionality of the UC3845B? If I buy a new one, do I need to program it?
                                  4. Are there any other electronic components that I need to pay attention to or replace with new ones?
                                  Thank you in advance​
                                  • ikalafat
                                    • Oct 2012
                                    • Croatia
                                    #137
                                    1. attached images of the board with visible values of R135, R101 and R143
                                    2. unfortunately, I don't have schematic nor I have reliable way to determine value of zener diode, so can't help here.
                                    3. it is easiest to replace it than to fiddle with oscilloscopes. programming is not needed, just replace it
                                    I've fixed 5 of 6 PR1500ELCDRT2U (230V/European, rack version) by replacing many capacitors on the board, one on hot side, other on cold.
                                    6th UPS that I have has an additional problem, with output voltage (BAT+/BAT-) being too high (58.5V), while others have output voltage significantly lower, around 54-54.5V.
                                    I don't have scope, so I can't check the waveforms, but I was considering replacing optocouplers in feedback circuit, and possibly UC3845.
                                    Has anyone had similar issue?
                                    • razenxd
                                      How can I charge that battery pack?
                                      by razenxd
                                      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                      Now, I have noticed a few things.
                                      The "dead" battery, while connected to charger and NOT Charging will...
                                      12-05-2024, 06:11 AM
                                    • ruletero
                                      Acer a515-43 low battery charge voltage
                                      by ruletero
                                      Hi
                                      Acer A515-43
                                      LA-H801P
                                      Fail: Does not charge battery, has low voltaje on connector.
                                      Laptop didn't want to turn on, only charge led blinked.
                                      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                      10-24-2022, 02:31 PM
                                    • Klevjetack
                                      Charge a L19D3PDA battery externally from the laptop
                                      by Klevjetack
                                      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                      03-05-2024, 07:26 AM
                                    • coasterghost
                                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                      by coasterghost
                                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                      System Hardware:
                                      Processor: AMD Ryzen 7 PRO 5850U
                                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                      09-08-2025, 10:46 PM
                                    • huzo
                                      Lenovo y700 not showing battery charge state
                                      by huzo
                                      The above mentioned laptop with the board NM B-163 is showing 1% battery charge in OS,but the battery holds for about 2h when unplugged from the charger ....when plugged in the windows says plugged in,the voltage goes up from 13.6V when empty to 15.7V when full,nominal voltage is 14.8V for that battery....SO it does charge and it does deplete, but it doesn't show charging or goes up from 1% on the battery meter....Here is the schematic for the battery charge connector, how should i test data and clock lines? They are connected to the EC on the mentioned pins,so no brekage,i don't have an oscilloscope...
                                      11-21-2025, 07:36 AM
