Power supply on lt37hvs
  • ricosavy
    • Jul 2012
    • 457
    • united states
    I have a tv model lt37hvs .The problem I am having is everything turns on for about 10 seconds the shuts off.You hear a clicking noise when it shuts off.I looked for bad solder joints the only thing I find is a shorted Zener diode but I can not find a way to identify it so I can replace it.It seems to connect to one of the legs of 20n60c3.power supply model is aep001 9191170013 rev3.looks like a fast acting diode d22 maybe it being shorted is shutting down my power supply.any help is welcomed thanks
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: Power supply on lt37hvs
    Here pic of 20n60c3
      That is the Gate discharge diode (it is in series with R76) which there is another resistor connected in parallel with that D/R.
      That circuit is the PFC Voltage booster so if the circuit does not work then you will not have >360VDC on the main filter cap, so you need to check that voltage.
      • ricosavy
        • Jul 2012
        • 457
        • united states
        What happen if the diode is shorted
        • ricosavy
          • Jul 2012
          • 457
          • united states
          Lifted one leg the doide is not shorted I will pull my esr and check my caps
          • CapLeaker
            Leaking Member
            • 8352
            That happens, sometimes diodes shows a short in circuit, just to take it out and it may be good. That all depends on the circuit the diode is in.
              Gate drive will usually have diode in parallel wit 10 Ohms resistor.
              • fluffmeister9
                • Feb 2015
                • 24
                • usa
                I have a LT37HVS and have replaced the capacitors and while the power light comes on the minute I turn the tv on it shorts out or shuts down totally. I can unplug the tv and plug it back in and the power light comes back on but I get no picture or sound. Any hints?
                • ricosavy
                  • Jul 2012
                  • 457
                  • united states
                  This is what i found on mine the solder joints on the power supply where connectors connect had bad joints so i just resolder them also the heat sink near the power plug had bad solder joints i resoldered it and the tv stays on now.
                  • CapLeaker
                    Leaking Member
                    • 8352
                    great work!
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                      by sam_sam_sam
                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                      Found shorted diodes on main controller relays there are 3 of them that...
                      01-07-2023, 05:43 PM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
