Linksys AD12V/1A-SW Power Supply for Linksys WRT54G - No power output
  • cage
    • Jun 2011
    • 23
    Re: Linksys AD12V/1A-SW Power Supply for Linksys WRT54G - No power output
    My multimeter doesn't have a capacitance setting.
    I did notice that when I measured to other two green capacitors in ohm mode that the numbers would slowly rise. I tried this on the large one (C1) and the reading stays at 1.
      Remove the cap and test it off the board. Try reversing the meter leads also. i expect the meter to show very high circuit resistance at least.
        • 31246
        it's probably a good idea to check the resistance of the big pink resistor too.
        it should be very low - almost a short circuit.
