Metrix 803B Oscilloscope power supply issue
  • rbarreiros
    • Nov 2016
    • Portugal
    #61
    Re: Metrix 803B Oscilloscope power supply issue
    Seems I jumped the gun, the issue I had was this one, which, like it's said in the thread, it's a bad contact in the green cable. Fixed !!
    http://www.electro-tech-online.com/t...oscope.146957/
    • rbarreiros
      • Nov 2016
      • Portugal
      #62
      Any news on the RS232 front ? I'm also curious at controlling the scope through RS232.
      Best regards,
      Rui
      Originally posted by itsthatidiotagain
      I had 5 minutes to spare today, to check the signals on J18 this is what I have so far.
      The colours in the list below are just those of the bit of ribbon cable I used, so they have no particular significance.
      Code:
      J18 Pinout - Pin1 at PSU end (same as J19)
      Pin- Colour - Signal
      1 - Blue1  -  0V slight periodic ripple (Polled output perhaps???)
      2 - Purple1 -  0V slight periodic ripple (Polled output perhaps???)
      3 - Grey1  -  0V slight periodic ripple (Polled output perhaps???)
      4 - White1  -  0V slight periodic ripple (Polled output perhaps???)
      5 - Black   -  0V slight periodic ripple (Polled output perhaps???)
      6 - Brown  -  +12V
      7 - Red    -  -12V
      8 - Orange  -  10ms +5V pulses (20ms pk to pk square wave)
      9 - Yellow  -  0V slight periodic ripple (Polled output perhaps???)
      10 - Green  -  Ground (Confirmed zero ohms to BNC Earth)
      11 - Blue2  -  0V but not tied to ground (serial port I/O perhaps???)
      12 - Purple2 -  0V but not tied to ground (serial port I/O perhaps???)
      13 - Grey2  -  +5V slight ripple (serial port I/O perhaps???))
      14 - White2 -  +5V slight ripple (serial port I/O perhaps???))
      I'll take a closer look at the signals, take a few pictures of the scope traces and probe with the multimeter to see if I can determine which are inputs and outputs when I get more time.
      Now that i know the serial port protocol and that it can use 3 wires i.e. no hardware handshake and xon/xoff I can then experiment with a TTL level 9600 baud serial signal fed to which ever I think might be the inputs, so see if I can control the front panel.
      The serial port consists of 5 wires and is described thus...
      Serial link characteristics
      Oscilloscope connector : 25-pin cannon plug
      Cable : five wires (two transmission wires, one ground wire, two
      control wires)
      Protocol : RTS
      Data rate :
      Data format :9600 bauds
      8 bits - no parity - 1 bit stop
      Protection : per EIA RS232C standard
      .. which may match up with the bottom 5 wires on J19
      I haven't found any 3V3 signals so far, so I think everything should be 5V TTL
      Pin 8 is interesting, I presume this is an accurate 50Hz pulse, which is the same frequency as the UK mains, and this might be for blanking sync perhaps for the A/D daughter cards. Pure speculation on my part of course.
      • itsthatidiotagain
        • Dec 2014
        • 39
        Very late reply, but @rbarreiros the short answer is yes. Your PSU issue sounds very similar. Follow through the thread and check/replace the parts I replaced first.
        Once you have done this, if it is still not working, check the HT side of things.
        • smdportugal
          • Mar 2021
          • Portugal
          #64
          Dear sir , i still have one Metrix OM803 that bought at about 25 years ago. It has been all types of faults . The first one when swithc on some relays goes crazy and the osciloscope coulnt start ok , i ´ve found some capacitors in the power supply unit with low capacitance and after replace it works good . After some years starts to not enter in some menus like components tester , It was a fault in a conector inside . After some more years lost the left deflection but as the transistor are smd types and cant see the reference and as i dont have the schematics i give up . I still have it here but with horizontal left deflection fault. Anybody has the Schematics diagram ?
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • KYBOSH
            Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
            by KYBOSH
            I have a floodlight-security camera that recently died on me.
            its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
            Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
            07-01-2024, 06:54 AM
          • Cookybaby
            Samsung UN60ES6500FXZA Power Supply Issue
            by Cookybaby
            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
            Make: Samsung
            Model: UN60ES6500FXZA
            Power Supply P/N: BN44-00525A
            Symptoms: The TV was...
            08-20-2023, 12:26 PM
          • lp20th
            Samsung Plasma TV Power Supply Issue
            by lp20th
            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
            11-28-2023, 10:28 AM
